Analog Devices - Part Numbers
AD7794BRU IC, 6 Channel, Low Noise, Low Power, 24, 16 Bit Analog to Digital Converters with On Chip InAmp and Reference
AD7794BRUZ IC, 6 Channel, Low Noise, Low Power, 24, 16 Bit Analog to Digital Converters with On Chip InAmp and Reference
AD7794CRUZ IC, 6 Channel, Low Noise, Low Power, 24, 16 Bit Analog to Digital Converters with On Chip InAmp and Reference
AD7795BRUZ IC, 6 Channel, Low Noise, Low Power, 24, 16 Bit Analog to Digital Converters with On Chip InAmp and Reference
AD7825BRUZ IC, 3V, 5V, 2 MSPS, 8 Bit, 1, 4, 8 Channel Sampling Analog to Digital Converters
AD8183ARUZ IC, 380MHz, 25mA Triple 2, 1 Multiplexers
AD8185ARUZ IC, 380MHz, 25mA Triple 2, 1 Multiplexers
AD8186ARUZ IC, 480MHz Single Supply 5V Triple 2, 1 Multiplexers
AD8186ARUZ-R7 IC, 480MHz Single Supply 5V Triple 2, 1 Multiplexers
AD8186ARUZ-RL IC, 480MHz Single Supply 5V Triple 2, 1 Multiplexers
AD8187ARUZ IC, 480MHz Single Supply 5V Triple 2, 1 Multiplexers
AD8188ARUZ IC, 350MHz Single Supply 5V Triple 2, 1 Multiplexers
AD8188ARUZ-R7 IC, 350MHz Single Supply 5V Triple 2, 1 Multiplexers
AD8188ARUZ-RL IC, 350MHz Single Supply 5V Triple 2, 1 Multiplexers
AD8189ARUZ IC, 350MHz Single Supply 5V Triple 2, 1 Multiplexers
AD8189ARUZ-R7 IC, 350MHz Single Supply 5V Triple 2, 1 Multiplexers
AD8189ARUZ-RL IC, 350MHz Single Supply 5V Triple 2, 1 Multiplexers
AD8403ARU1 IC, 1, 2, 4 Channel Digital Potentiometers
AD8403ARU10 IC, 1, 2, 4 Channel Digital Potentiometers
AD8403ARU100 IC, 1, 2, 4 Channel Digital Potentiometers
AD8403ARUZ1 IC, 1, 2, 4 Channel Digital Potentiometers
AD8403ARUZ10 IC, 1, 2, 4 Channel Digital Potentiometers
AD8403ARUZ100 IC, 1, 2, 4 Channel Digital Potentiometers
AD8403ARUZ50 IC, 1, 2, 4 Channel Digital Potentiometers
ADD8506WRUZ IC, 4, 5, 6 Channel, Muxed Input Line Inversion LCD Gamma Buffers
ADD8506WWARUZR7 IC, 4, 5, 6 Channel, Muxed Input Line Inversion LCD Gamma Buffers
ADF7010BRUZ IC, High Performance ISM Band ASK, FSK, GFSK Transmitter
ADF7011BRUZ IC, High Performance ISM Band ASK, FSK, GFSK Transmitter
ADF7011BRUZ-RL IC, High Performance ISM Band ASK, FSK, GFSK Transmitter
ADF7011BRUZ-RL7 IC, High Performance ISM Band ASK, FSK, GFSK Transmitter
ADF7012BRUZ IC, Multi Channel ISM Band FSK, GFSK, OOK, GOOK,ASK Transmitter
ADF7012BRUZ-RL IC, Multi Channel ISM Band FSK, GFSK, OOK, GOOK,ASK Transmitter
ADF7012BRUZ-RL7 IC, Multi Channel ISM Band FSK, GFSK, OOK, GOOK,ASK Transmitter
ADF7901BRUZ IC, High Performance ISM Band OOK, FSK Transmitter
ADF7901BRUZ-RL IC, High Performance ISM Band OOK, FSK Transmitter
ADF7901BRUZ-RL7 IC, High Performance ISM Band OOK, FSK Transmitter
ADG1414BRUZ IC, 9.5 RON 15V, 12V, 5V iCMOS Serially Controlled Octal SPST Switches
ADG3246BRUZ IC, 2.5V, 3.3V, 10 Bit, 2 Port Level Translating, Bus Switch
ADG714BRUZ IC, CMOS, Low Voltage Serially Controlled, Octal SPST Switches
ADG715BRU IC, CMOS, Low Voltage Serially Controlled, Octal SPST Switches
ADG715BRUZ IC, CMOS, Low Voltage Serially Controlled, Octal SPST Switches
ADM207EARU IC, EMC Compliant, 15KV, ESD Protected, RS 232 Line Drivers, Receivers
ADM207EARUZ IC, EMC Compliant, 15KV, ESD Protected, RS 232 Line Drivers, Receivers
ADM208EARU IC, EMC Compliant, 15KV, ESD Protected, RS 232 Line Drivers, Receivers
ADM208EARUZ IC, EMC Compliant, 15KV, ESD Protected, RS 232 Line Drivers, Receivers
ADM3312EARU IC, 15KV ESD Protected, 2.7V to 3.6V Serial Port Transceivers with Green Idle
ADM3312EARUZ IC, 15KV ESD Protected, 2.7V to 3.6V Serial Port Transceivers with Green Idle
ADM3315EARU IC, 15KV ESD Protected, 2.7V to 3.6V Serial Port Transceivers with Green Idle
ADM3315EARUZ IC, 15KV ESD Protected, 2.7V to 3.6V Serial Port Transceivers with Green Idle
ADV7127JRUZ240 IC, CMS 240MHz, 10 Bit High SpeedVideo Digital to Analog Converter
ADV7127KRU140 IC, CMS 240MHz, 10 Bit High SpeedVideo Digital to Analog Converter
ADV7127KRU50 IC, CMS 240MHz, 10 Bit High SpeedVideo Digital to Analog Converter
ADV7127KRUZ140 IC, CMS 240MHz, 10 Bit High SpeedVideo Digital to Analog Converter
ADV7127KRUZ50 IC, CMS 240MHz, 10 Bit High SpeedVideo Digital to Analog Converter
Page 2 of 2
