Analog Devices - Part Numbers
LTC3719EG#TR IC, 2 Phase, High Efficiency, Step Down Controller for AMD Opteron CPU
LTC3719EG#TRPBF IC, 2 Phase, High Efficiency, Step Down Controller for AMD Opteron CPU
LTC3730CG IC, 3 Phase, 5 Bit Intel Mobile VID, 600KHz, Synchronous Buck Controller
LTC3730CG#PBF IC, 3 Phase, 5 Bit Intel Mobile VID, 600KHz, Synchronous Buck Controller
LTC3730CG#TR IC, 3 Phase, 5 Bit Intel Mobile VID, 600KHz, Synchronous Buck Controller
LTC3730CG#TRPBF IC, 3 Phase, 5 Bit Intel Mobile VID, 600KHz, Synchronous Buck Controller
LTC3731CG IC, 3 Phase, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3731CG#PBF IC, 3 Phase, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3731CG#TR IC, 3 Phase, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3731CG#TRPBF IC, 3 Phase, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3731HG IC, 3 Phase, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3731HG#PBF IC, 3 Phase, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3731HG#TR IC, 3 Phase, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3731HG#TRPBF IC, 3 Phase, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3731IG#PBF IC, 3 Phase, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3731IG#TRPBF IC, 3 Phase, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3732CG IC, 3 Phase, 5 Bit VID, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3732CG#PBF IC, 3 Phase, 5 Bit VID, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3732CG#TR IC, 3 Phase, 5 Bit VID, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3732CG#TRPBF IC, 3 Phase, 5 Bit VID, 600KHz, Synchronous Buck Switching Regulator Controller
LTC3733CG IC, 3 Phase, Buck Controllers for AMD CPUs
LTC3733CG#PBF IC, 3 Phase, Buck Controllers for AMD CPUs
LTC3733CG#TR IC, 3 Phase, Buck Controllers for AMD CPUs
LTC3733CG#TRPBF IC, 3 Phase, Buck Controllers for AMD CPUs
LTC3735EG IC, 2 Phase, High Efficiency DC, DC Controller for Intel Mobile CPU
LTC3735EG#PBF IC, 2 Phase, High Efficiency DC, DC Controller for Intel Mobile CPU
LTC3735EG#TR IC, 2 Phase, High Efficiency DC, DC Controller for Intel Mobile CPU
LTC3735EG#TRPBF IC, 2 Phase, High Efficiency DC, DC Controller for Intel Mobile CPU
LTC3773EG#PBF IC, Triple Output Synchronous 3 Phase DC, DC Controller with Up, Down Tracking
LTC3773EG#TRPBF IC, Triple Output Synchronous 3 Phase DC, DC Controller with Up, Down Tracking
LTC3811EG#PBF IC, High Speed Dual, Multiphase Step Down DC, DC Controller
LTC3811EG#TRPBF IC, High Speed Dual, Multiphase Step Down DC, DC Controller
LTC3819EG#PBF IC, 2 Phase, High Efficiency, Step Down Controller for Sun Server CPU
LTC3819EG#TRPBF IC, 2 Phase, High Efficiency, Step Down Controller for Sun Server CPU
LTC4222CG#PBF IC, Dual Hot Swap Controller with I2C Compatible Monitoring
LTC4222CG#TRPBF IC, Dual Hot Swap Controller with I2C Compatible Monitoring
LTC4222IG#PBF IC, Dual Hot Swap Controller with I2C Compatible Monitoring
LTC4222IG#TRPBF IC, Dual Hot Swap Controller with I2C Compatible Monitoring
LTC4242CG#PBF IC, Dual Slot Hot Swap Controller for PCI Express
LTC4242CG#TRPBF IC, Dual Slot Hot Swap Controller for PCI Express
LTC4242IG#PBF IC, Dual Slot Hot Swap Controller for PCI Express
LTC4242IG#TRPBF IC, Dual Slot Hot Swap Controller for PCI Express
LTC4245CG#PBF IC, Multiple Supply Hot Swap Controller with I2C Compatible Monitoring
LTC4245CG#TRPBF IC, Multiple Supply Hot Swap Controller with I2C Compatible Monitoring
LTC4245IG#PBF IC, Multiple Supply Hot Swap Controller with I2C Compatible Monitoring
LTC4245IG#TRPBF IC, Multiple Supply Hot Swap Controller with I2C Compatible Monitoring
LTC6801HG#PBF IC, Independent Multicell Battery Stack Fault Monitor
LTC6801HG#TRPBF IC, Independent Multicell Battery Stack Fault Monitor
LTC6801IG#PBF IC, Independent Multicell Battery Stack Fault Monitor
LTC6801IG#TRPBF IC, Independent Multicell Battery Stack Fault Monitor
Page 3 of 3
