Analog Devices - Part Numbers
LTC1148HVCS#PBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVCS#TR IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVCS#TRPBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVCS-3.3 IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVCS-3.3#PBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVCS-3.3#TR IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVCS-3.3#TRPBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVCS-5 IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVCS-5#PBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVCS-5#TR IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVCS-5#TRPBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVIS-5 IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVIS-5#PBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVIS-5#TR IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148HVIS-5#TRPBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148LCS IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148LCS#PBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148LCS#TR IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148LCS#TRPBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148LCS-3.3 IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148LCS-3.3#PBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148LCS-3.3#TR IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1148LCS-3.3#TRPBF IC, High Efficiency Synchronous Step Down Switching Regulator
LTC1261CS IC, Switched Capacitor Regulated Voltage Inverter
LTC1261CS#PBF IC, Switched Capacitor Regulated Voltage Inverter
LTC1261CS#TR IC, Switched Capacitor Regulated Voltage Inverter
LTC1261CS#TRPBF IC, Switched Capacitor Regulated Voltage Inverter
LTC1265CS IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265CS#PBF IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265CS#TR IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265CS#TRPBF IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265CS-3.3 IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265CS-3.3#PBF IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265CS-3.3#TR IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265CS-3.3#TRPBF IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265CS-5 IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265CS-5#PBF IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265CS-5#TR IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265CS-5#TRPBF IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265IS IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265IS#PBF IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265IS#TR IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1265IS#TRPBF IC, 1.2A, High Efficiency Step Down DC, DC Converter
LTC1314CS IC, PCMCIA Switching Matrixwith Built In N Channel VsubCC, sub Switch Driver
LTC1314CS#PBF IC, PCMCIA Switching Matrixwith Built In N Channel VsubCC, sub Switch Driver
LTC1314CS#TR IC, PCMCIA Switching Matrixwith Built In N Channel VsubCC, sub Switch Driver
LTC1314CS#TRPBF IC, PCMCIA Switching Matrixwith Built In N Channel VsubCC, sub Switch Driver
LTC1645CS IC, Dual Channel Hot Swap Controller, Power Sequencer
LTC1645CS#PBF IC, Dual Channel Hot Swap Controller, Power Sequencer
LTC1645CS#TR IC, Dual Channel Hot Swap Controller, Power Sequencer
LTC1645CS#TRPBF IC, Dual Channel Hot Swap Controller, Power Sequencer
LTC1645IS IC, Dual Channel Hot Swap Controller, Power Sequencer
LTC1645IS#PBF IC, Dual Channel Hot Swap Controller, Power Sequencer
LTC1645IS#TR IC, Dual Channel Hot Swap Controller, Power Sequencer
LTC1645IS#TRPBF IC, Dual Channel Hot Swap Controller, Power Sequencer
LTC1687CS IC, 52Mbps Precision Delay RS485 Fail Safe Transceiver
LTC1687CS#PBF IC, 52Mbps Precision Delay RS485 Fail Safe Transceiver
LTC1687CS#TR IC, 52Mbps Precision Delay RS485 Fail Safe Transceiver
LTC1687CS#TRPBF IC, 52Mbps Precision Delay RS485 Fail Safe Transceiver
LTC1687IS IC, 52Mbps Precision Delay RS485 Fail Safe Transceiver
LTC1687IS#PBF IC, 52Mbps Precision Delay RS485 Fail Safe Transceiver
LTC1687IS#TR IC, 52Mbps Precision Delay RS485 Fail Safe Transceiver
LTC1687IS#TRPBF IC, 52Mbps Precision Delay RS485 Fail Safe Transceiver
LTC2052CS IC, Dual, Quad Zero Drift Operational Amplifier
LTC2052CS#PBF IC, Dual, Quad Zero Drift Operational Amplifier
LTC2052CS#TR IC, Dual, Quad Zero Drift Operational Amplifier
LTC2052CS#TRPBF IC, Dual, Quad Zero Drift Operational Amplifier
LTC2052HS IC, Dual, Quad Zero Drift Operational Amplifier
LTC2052HS#PBF IC, Dual, Quad Zero Drift Operational Amplifier
LTC2052HS#TR IC, Dual, Quad Zero Drift Operational Amplifier
LTC2052HS#TRPBF IC, Dual, Quad Zero Drift Operational Amplifier
LTC2052HVCS IC, Dual, Quad Zero Drift Operational Amplifier
LTC2052HVCS#PBF IC, Dual, Quad Zero Drift Operational Amplifier
LTC2052HVCS#TR IC, Dual, Quad Zero Drift Operational Amplifier
LTC2052HVCS#TRPBF IC, Dual, Quad Zero Drift Operational Amplifier
Page 5 of 6
