Analog Devices - Part Numbers
LT1491AIS#TR IC, Dual, Quad Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1491AIS#TRPBF IC, Dual, Quad Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1491CS IC, Dual and Quad Micropower Rail to Rail Input and Output Op Amp
LT1491CS#PBF IC, Dual and Quad Micropower Rail to Rail Input and Output Op Amp
LT1491CS#TRPBF IC, Dual and Quad Micropower Rail to Rail Input and Output Op Amp
LT1491IS IC, Dual and Quad Micropower Rail to Rail Input and Output Op Amp
LT1491IS#PBF IC, Dual and Quad Micropower Rail to Rail Input and Output Op Amp
LT1491IS#TRPBF IC, Dual and Quad Micropower Rail to Rail Input and Output Op Amp
LT1496CS IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1496CS#PBF IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1496CS#TR IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1496CS#TRPBF IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1496HS IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1496HS#PBF IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1496HS#TR IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1496HS#TRPBF IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1496IS IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1496IS#PBF IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1496IS#TR IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1496IS#TRPBF IC, 1.5A Max Single, Dual and Quad Precision Rail to Rail Input and Output Op Amp
LT1499CS IC, 10MHz, 6V, Dual, Quad Rail to Rail Input and Output Precision C Load Op Amp
LT1499CS#PBF IC, 10MHz, 6V, Dual, Quad Rail to Rail Input and Output Precision C Load Op Amp
LT1499CS#TR IC, 10MHz, 6V, Dual, Quad Rail to Rail Input and Output Precision C Load Op Amp
LT1499CS#TRPBF IC, 10MHz, 6V, Dual, Quad Rail to Rail Input and Output Precision C Load Op Amp
LT1499HS#PBF IC, 10MHz, 6V, Dual, Quad Rail to Rail Input and Output Precision C Load Op Amp
LT1499HS#TRPBF IC, 10MHz, 6V, Dual, Quad Rail to Rail Input and Output Precision C Load Op Amp
LT1499IS IC, 10MHz, 6V, Dual, Quad Rail to Rail Input and Output Precision C Load Op Amp
LT1499IS#PBF IC, 10MHz, 6V, Dual, Quad Rail to Rail Input and Output Precision C Load Op Amp
LT1499IS#TR IC, 10MHz, 6V, Dual, Quad Rail to Rail Input and Output Precision C Load Op Amp
LT1499IS#TRPBF IC, 10MHz, 6V, Dual, Quad Rail to Rail Input and Output Precision C Load Op Amp
LT1631CS IC, 30MHz, 10V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1631CS#PBF IC, 30MHz, 10V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1631CS#TR IC, 30MHz, 10V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1631CS#TRPBF IC, 30MHz, 10V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1631IS IC, 30MHz, 10V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1631IS#PBF IC, 30MHz, 10V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1631IS#TR IC, 30MHz, 10V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1631IS#TRPBF IC, 30MHz, 10V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1633CS IC, 45MHz, 45V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1633CS#PBF IC, 45MHz, 45V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1633CS#TR IC, 45MHz, 45V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1633CS#TRPBF IC, 45MHz, 45V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1633IS IC, 45MHz, 45V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1633IS#PBF IC, 45MHz, 45V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1633IS#TR IC, 45MHz, 45V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1633IS#TRPBF IC, 45MHz, 45V, Dual, Quad Rail to Rail Input and Output Precision Op Amp
LT1639CS IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1639CS#PBF IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1639CS#TR IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1639CS#TRPBF IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1639HS IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1639HS#PBF IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1639HS#TR IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1639HS#TRPBF IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1639IS IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1639IS#PBF IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1639IS#TR IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1639IS#TRPBF IC, 1.2MHz, 0.4V, us Over The Top Micropower Rail to Rail Input and Output Op Amp
LT1674CS#PBF IC, 2A Max, Av 5 Single, Dual and Quad Over The Top Precision Rail to Rail Input and Output Op Amp
LT1674CS#TR IC, 2A Max, Av 5 Single, Dual and Quad Over The Top Precision Rail to Rail Input and Output Op Amp
LT1674CS#TRPBF IC, 2A Max, Av 5 Single, Dual and Quad Over The Top Precision Rail to Rail Input and Output Op Amp
LT1674IS#PBF IC, 2A Max, Av 5 Single, Dual and Quad Over The Top Precision Rail to Rail Input and Output Op Amp
LT1674IS#TR IC, 2A Max, Av 5 Single, Dual and Quad Over The Top Precision Rail to Rail Input and Output Op Amp
LT1674IS#TRPBF IC, 2A Max, Av 5 Single, Dual and Quad Over The Top Precision Rail to Rail Input and Output Op Amp
LT1679CS IC, Dual, Quad Low Noise, Rail to Rail, Precision Op Amp
LT1679CS#PBF IC, Dual, Quad Low Noise, Rail to Rail, Precision Op Amp
LT1679CS#TR IC, Dual, Quad Low Noise, Rail to Rail, Precision Op Amp
LT1679CS#TRPBF IC, Dual, Quad Low Noise, Rail to Rail, Precision Op Amp
LT1679IS IC, Dual, Quad Low Noise, Rail to Rail, Precision Op Amp
LT1679IS#PBF IC, Dual, Quad Low Noise, Rail to Rail, Precision Op Amp
LT1679IS#TR IC, Dual, Quad Low Noise, Rail to Rail, Precision Op Amp
LT1679IS#TRPBF IC, Dual, Quad Low Noise, Rail to Rail, Precision Op Amp
LT1684CS IC, Micropower Ring Tone Generator
LT1684CS#PBF IC, Micropower Ring Tone Generator
LT1684CS#TR IC, Micropower Ring Tone Generator
Page 2 of 6
