Analog Devices - Part Numbers
LT1076IT-5 IC, 5Vtep Down Switching Regulator
LT1076IT-5#PBF IC, 5Vtep Down Switching Regulator
LT1082CT IC, 1A High Voltage, Efficiency Switching Voltage Regulator
LT1082CT#06 IC, 1A High Voltage, Efficiency Switching Voltage Regulator
LT1082CT#06PBF IC, Regulator Multiple Configurations Inverting ISO
LT1082CT#PBF IC, 1A High Voltage, Efficiency Switching Voltage Regulator
LT1082IT IC, 1A High Voltage, Efficiency Switching Voltage Regulator
LT1082IT#30PBF IC, 1A High Voltage, Efficiency Switching Voltage Regulator
LT1082IT#PBF IC, 1A High Voltage, Efficiency Switching Voltage Regulator
LT1129CT IC, Micropower Low Dropout Regulator with Shutdown
LT1129CT#PBF IC, Micropower Low Dropout Regulator with Shutdown
LT1129CT-3.3 IC, Micropower Low Dropout Regulator with Shutdown
LT1129CT-3.3#06PBF IC, Micropower Low Dropout Regulator with Shutdown
LT1129CT-3.3#PBF IC, Micropower Low Dropout Regulator with Shutdown
LT1129CT-5 IC, Micropower Low Dropout Regulator with Shutdown
LT1129CT-5#06PBF IC, Micropower Low Dropout Regulator with Shutdown
LT1129CT-5#PBF IC, Micropower Low Dropout Regulator with Shutdown
LT1129IT IC, Micropower Low Dropout Regulator with Shutdown
LT1129IT#06PBF IC, Micropower Low Dropout Regulator with Shutdown
LT1129IT#PBF IC, Micropower Low Dropout Regulator with Shutdown
LT1129IT-3.3 IC, Micropower Low Dropout Regulator with Shutdown
LT1129IT-3.3#PBF IC, Micropower Low Dropout Regulator with Shutdown
LT1129IT-5 IC, Micropower Low Dropout Regulator with Shutdown
LT1129IT-5#06PBF IC, Micropower Low Dropout Regulator with Shutdown
LT1129IT-5#PBF IC, Micropower Low Dropout Regulator with Shutdown
LT1170CT IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170CT#06PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170CT#30PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170CT#PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170HVCT IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170HVCT#06PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170HVCT#30PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170HVCT#PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170HVIT IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170HVIT#31PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170HVIT#PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170IT IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1170IT#PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1171CT IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1171CT#06PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1171CT#PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1171HVCT IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1171HVCT#30PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1171HVCT#PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1171HVIT IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1171HVIT#PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1171IT IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1171IT#PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1172CT IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1172CT#06PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1172CT#31PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1172CT#PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1172HVCT#06PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1172HVCT#30PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1172HVCT#31PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1172HVCT#PBF IC, 100KHz, 5A, 2.5A, and 1.25A High Efficiency Switching Regulator
LT1175CT IC, 500mA, Negative Low Dropout Micropower Regulator
LT1175CT#06PBF IC, 500mA, Negative Low Dropout Micropower Regulator
LT1175CT#PBF IC, 500mA, Negative Low Dropout Micropower Regulator
LT1175CT-5 IC, 500mA, Negative Low Dropout Micropower Regulator
LT1175CT-5#06PBF IC, 500mA, Negative Low Dropout Micropower Regulator
LT1175CT-5#PBF IC, 500mA, Negative Low Dropout Micropower Regulator
LT1175IT IC, 500mA, Negative Low Dropout Micropower Regulator
LT1175IT#PBF IC, 500mA, Negative Low Dropout Micropower Regulator
LT1175IT-5 IC, 500mA, Negative Low Dropout Micropower Regulator
LT1175IT-5#PBF IC, 500mA, Negative Low Dropout Micropower Regulator
LT1185CT IC, Low Dropout Regulator
LT1185CT#06PBF IC, Low Dropout Regulator
LT1185CT#30PBF IC, Low Dropout Regulator
LT1185CT#33PBF IC, Low Dropout Regulator
LT1185CT#PBF IC, Low Dropout Regulator
LT1185IT IC, Low Dropout Regulator
LT1185IT#06PBF IC, Low Dropout Regulator
LT1185IT#30PBF IC, Low Dropout Regulator
LT1185IT#31PBF IC, Low Dropout Regulator
Page 2 of 4
