Abracon - Part Numbers
ABM8W-49.1520MHZ-7-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 49.1520 MHz, 7pF
ABM8W-49.1520MHZ-7-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 49.1520 MHz, 7pF
ABM8W-49.1520MHZ-8-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 49.1520 MHz, 8pF
ABM8W-49.1520MHZ-8-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 49.1520 MHz, 8pF
ABM8W-49.1520MHZ-8-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 49.1520 MHz, 8pF
ABM8W-49.1520MHZ-8-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 49.1520 MHz, 8pF
ABM8W-49.1520MHZ-8-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 49.1520 MHz, 8pF
ABM8W-49.1520MHZ-8-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 49.1520 MHz, 8pF
ABM8W-49.1520MHZ-8-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 49.1520 MHz, 8pF
ABM8W-49.1520MHZ-8-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 49.1520 MHz, 8pF
ABM8W-50.0000MHZ-4-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 4pF
ABM8W-50.0000MHZ-4-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 4pF
ABM8W-50.0000MHZ-4-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 4pF
ABM8W-50.0000MHZ-4-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 4pF
ABM8W-50.0000MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 4pF
ABM8W-50.0000MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 4pF
ABM8W-50.0000MHZ-6-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 6pF
ABM8W-50.0000MHZ-6-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 6pF
ABM8W-50.0000MHZ-6-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 6pF
ABM8W-50.0000MHZ-6-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 6pF
ABM8W-50.0000MHZ-6-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 6pF
ABM8W-50.0000MHZ-6-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 6pF
ABM8W-50.0000MHZ-6-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 6pF
ABM8W-50.0000MHZ-6-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 6pF
ABM8W-50.0000MHZ-7-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 7pF
ABM8W-50.0000MHZ-7-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 7pF
ABM8W-50.0000MHZ-7-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 7pF
ABM8W-50.0000MHZ-7-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 7pF
ABM8W-50.0000MHZ-7-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 7pF
ABM8W-50.0000MHZ-7-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 7pF
ABM8W-50.0000MHZ-7-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 7pF
ABM8W-50.0000MHZ-7-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 7pF
ABM8W-50.0000MHZ-8-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 8pF
ABM8W-50.0000MHZ-8-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 8pF
ABM8W-50.0000MHZ-8-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 8pF
ABM8W-50.0000MHZ-8-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 8pF
ABM8W-50.0000MHZ-8-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 8pF
ABM8W-50.0000MHZ-8-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 8pF
ABM8W-50.0000MHZ-8-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 8pF
ABM8W-50.0000MHZ-8-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 50.0000 MHz, 8pF
ABM8W-52.0000MHZ-4-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 4pF
ABM8W-52.0000MHZ-4-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 4pF
ABM8W-52.0000MHZ-4-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 4pF
ABM8W-52.0000MHZ-6-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 6pF
ABM8W-52.0000MHZ-6-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 6pF
ABM8W-52.0000MHZ-6-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 6pF
ABM8W-52.0000MHZ-6-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 6pF
ABM8W-52.0000MHZ-6-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 6pF
ABM8W-52.0000MHZ-6-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 6pF
ABM8W-52.0000MHZ-6-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 6pF
ABM8W-52.0000MHZ-6-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 6pF
ABM8W-52.0000MHZ-7-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 7pF
ABM8W-52.0000MHZ-7-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 7pF
ABM8W-52.0000MHZ-7-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 7pF
ABM8W-52.0000MHZ-7-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 7pF
ABM8W-52.0000MHZ-7-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 7pF
ABM8W-52.0000MHZ-7-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 7pF
ABM8W-52.0000MHZ-7-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 7pF
ABM8W-52.0000MHZ-7-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 7pF
ABM8W-52.0000MHZ-8-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 8pF
ABM8W-52.0000MHZ-8-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 8pF
ABM8W-52.0000MHZ-8-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 8pF
ABM8W-52.0000MHZ-8-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 8pF
ABM8W-52.0000MHZ-8-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 8pF
ABM8W-52.0000MHZ-8-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 8pF
ABM8W-52.0000MHZ-8-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 8pF
ABM8W-52.0000MHZ-8-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 52.0000 MHz, 8pF
ABM8W-54.0000MHZ-4-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 54.0000 MHz, 4pF
ABM8W-54.0000MHZ-4-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 54.0000 MHz, 4pF
ABM8W-54.0000MHZ-6-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 54.0000 MHz, 6pF
ABM8W-54.0000MHZ-6-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 54.0000 MHz, 6pF
ABM8W-54.0000MHZ-6-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 54.0000 MHz, 6pF
ABM8W-54.0000MHZ-6-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 54.0000 MHz, 6pF
ABM8W-54.0000MHZ-6-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 54.0000 MHz, 6pF
ABM8W-54.0000MHZ-6-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 54.0000 MHz, 6pF
Page 35 of 36
