Abracon - Part Numbers
ABM11W-19.2000MHZ-8-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2000 MHz, 8pF
ABM11W-19.2000MHZ-8-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2000 MHz, 8pF
ABM11W-19.2000MHZ-8-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2000 MHz, 8pF
ABM11W-19.2000MHZ-8-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2000 MHz, 8pF
ABM11W-19.2000MHZ-8-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2000 MHz, 8pF
ABM11W-19.2000MHZ-8-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2000 MHz, 8pF
ABM11W-19.2800MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 4pF
ABM11W-19.2800MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 4pF
ABM11W-19.2800MHZ-6-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 6pF
ABM11W-19.2800MHZ-6-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 6pF
ABM11W-19.2800MHZ-6-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 6pF
ABM11W-19.2800MHZ-6-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 6pF
ABM11W-19.2800MHZ-6-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 6pF
ABM11W-19.2800MHZ-6-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 6pF
ABM11W-19.2800MHZ-7-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 7pF
ABM11W-19.2800MHZ-7-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 7pF
ABM11W-19.2800MHZ-7-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 7pF
ABM11W-19.2800MHZ-7-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 7pF
ABM11W-19.2800MHZ-7-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 7pF
ABM11W-19.2800MHZ-8-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 8pF
ABM11W-19.2800MHZ-8-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 8pF
ABM11W-19.2800MHZ-8-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 8pF
ABM11W-19.2800MHZ-8-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 8pF
ABM11W-19.2800MHZ-8-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 8pF
ABM11W-19.2800MHZ-8-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.2800 MHz, 8pF
ABM11W-19.4400MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 4pF
ABM11W-19.4400MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 4pF
ABM11W-19.4400MHZ-6-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 6pF
ABM11W-19.4400MHZ-6-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 6pF
ABM11W-19.4400MHZ-6-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 6pF
ABM11W-19.4400MHZ-6-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 6pF
ABM11W-19.4400MHZ-6-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 6pF
ABM11W-19.4400MHZ-6-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 6pF
ABM11W-19.4400MHZ-7-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 7pF
ABM11W-19.4400MHZ-7-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 7pF
ABM11W-19.4400MHZ-7-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 7pF
ABM11W-19.4400MHZ-7-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 7pF
ABM11W-19.4400MHZ-7-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 7pF
ABM11W-19.4400MHZ-8-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 8pF
ABM11W-19.4400MHZ-8-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 8pF
ABM11W-19.4400MHZ-8-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 8pF
ABM11W-19.4400MHZ-8-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 8pF
ABM11W-19.4400MHZ-8-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 8pF
ABM11W-19.4400MHZ-8-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.4400 MHz, 8pF
ABM11W-19.6608MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.6608 MHz, 4pF
ABM11W-19.6608MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.6608 MHz, 4pF
ABM11W-19.6800MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.6800 MHz, 4pF
ABM11W-19.6800MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.6800 MHz, 4pF
ABM11W-19.6875MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.6875 MHz, 4pF
ABM11W-19.6875MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.6875 MHz, 4pF
ABM11W-19.7079MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.7079 MHz, 4pF
ABM11W-19.7079MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.7079 MHz, 4pF
ABM11W-19.8000MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.8000 MHz, 4pF
ABM11W-19.8000MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.8000 MHz, 4pF
ABM11W-19.9680MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 4pF
ABM11W-19.9680MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 4pF
ABM11W-19.9680MHZ-6-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 6pF
ABM11W-19.9680MHZ-6-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 6pF
ABM11W-19.9680MHZ-6-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 6pF
ABM11W-19.9680MHZ-6-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 6pF
ABM11W-19.9680MHZ-6-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 6pF
ABM11W-19.9680MHZ-6-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 6pF
ABM11W-19.9680MHZ-7-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 7pF
ABM11W-19.9680MHZ-7-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 7pF
ABM11W-19.9680MHZ-7-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 7pF
ABM11W-19.9680MHZ-7-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 7pF
ABM11W-19.9680MHZ-7-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 7pF
ABM11W-19.9680MHZ-8-B1U-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 8pF
ABM11W-19.9680MHZ-8-B2U-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 8pF
ABM11W-19.9680MHZ-8-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 8pF
ABM11W-19.9680MHZ-8-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 8pF
ABM11W-19.9680MHZ-8-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 8pF
ABM11W-19.9680MHZ-8-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 19.9680 MHz, 8pF
ABM11W-20.0000MHZ-4-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 20.0000 MHz, 4pF
ABM11W-20.0000MHZ-4-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 20.0000 MHz, 4pF
Page 2 of 20
