Abracon - Part Numbers
ABM10W-16.3840MHZ-4-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 4pF
ABM10W-16.3840MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 4pF
ABM10W-16.3840MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 4pF
ABM10W-16.3840MHZ-6-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 6pF
ABM10W-16.3840MHZ-6-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 6pF
ABM10W-16.3840MHZ-6-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 6pF
ABM10W-16.3840MHZ-6-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 6pF
ABM10W-16.3840MHZ-6-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 6pF
ABM10W-16.3840MHZ-6-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 6pF
ABM10W-16.3840MHZ-7-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 7pF
ABM10W-16.3840MHZ-7-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 7pF
ABM10W-16.3840MHZ-7-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 7pF
ABM10W-16.3840MHZ-7-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 7pF
ABM10W-16.3840MHZ-7-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 7pF
ABM10W-16.3840MHZ-7-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 7pF
ABM10W-16.3840MHZ-8-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 8pF
ABM10W-16.3840MHZ-8-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 8pF
ABM10W-16.3840MHZ-8-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 8pF
ABM10W-16.3840MHZ-8-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 8pF
ABM10W-16.3840MHZ-8-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 8pF
ABM10W-16.3840MHZ-8-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.3840 MHz, 8pF
ABM10W-16.6667MHZ-4-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 4pF
ABM10W-16.6667MHZ-4-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 4pF
ABM10W-16.6667MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 4pF
ABM10W-16.6667MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 4pF
ABM10W-16.6667MHZ-4-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 4pF
ABM10W-16.6667MHZ-4-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 4pF
ABM10W-16.6667MHZ-6-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 6pF
ABM10W-16.6667MHZ-6-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 6pF
ABM10W-16.6667MHZ-6-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 6pF
ABM10W-16.6667MHZ-6-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 6pF
ABM10W-16.6667MHZ-6-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 6pF
ABM10W-16.6667MHZ-6-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 6pF
ABM10W-16.6667MHZ-7-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 7pF
ABM10W-16.6667MHZ-7-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 7pF
ABM10W-16.6667MHZ-7-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 7pF
ABM10W-16.6667MHZ-7-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 7pF
ABM10W-16.6667MHZ-7-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 7pF
ABM10W-16.6667MHZ-7-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 7pF
ABM10W-16.6667MHZ-8-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 8pF
ABM10W-16.6667MHZ-8-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 8pF
ABM10W-16.6667MHZ-8-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 8pF
ABM10W-16.6667MHZ-8-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 8pF
ABM10W-16.6667MHZ-8-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 8pF
ABM10W-16.6667MHZ-8-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.6667 MHz, 8pF
ABM10W-16.8000MHZ-4-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 4pF
ABM10W-16.8000MHZ-4-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 4pF
ABM10W-16.8000MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 4pF
ABM10W-16.8000MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 4pF
ABM10W-16.8000MHZ-4-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 4pF
ABM10W-16.8000MHZ-4-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 4pF
ABM10W-16.8000MHZ-6-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 6pF
ABM10W-16.8000MHZ-6-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 6pF
ABM10W-16.8000MHZ-6-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 6pF
ABM10W-16.8000MHZ-6-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 6pF
ABM10W-16.8000MHZ-6-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 6pF
ABM10W-16.8000MHZ-6-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 6pF
ABM10W-16.8000MHZ-7-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 7pF
ABM10W-16.8000MHZ-7-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 7pF
ABM10W-16.8000MHZ-7-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 7pF
ABM10W-16.8000MHZ-7-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 7pF
ABM10W-16.8000MHZ-7-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 7pF
ABM10W-16.8000MHZ-7-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 7pF
ABM10W-16.8000MHZ-8-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 8pF
ABM10W-16.8000MHZ-8-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 8pF
ABM10W-16.8000MHZ-8-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 8pF
ABM10W-16.8000MHZ-8-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 8pF
ABM10W-16.8000MHZ-8-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 8pF
ABM10W-16.8000MHZ-8-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.8000 MHz, 8pF
ABM10W-16.9340MHZ-4-D1X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.9340 MHz, 4pF
ABM10W-16.9340MHZ-4-D2X-T3 Crystal, IOT Optimized Low Profile Quartz, 16.9340 MHz, 4pF
ABM10W-16.9340MHZ-4-J1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.9340 MHz, 4pF
ABM10W-16.9340MHZ-4-J2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.9340 MHz, 4pF
ABM10W-16.9340MHZ-4-K1Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.9340 MHz, 4pF
ABM10W-16.9340MHZ-4-K2Z-T3 Crystal, IOT Optimized Low Profile Quartz, 16.9340 MHz, 4pF
Page 2 of 29
