  New Posts New Posts RSS Feed - PCBL Footprint Naming Convention: Surface Mount
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: PCBL Footprint Naming Convention: Surface Mount
    Posted: 15 Aug 2026 at 11:00am
Common package types and their respective naming conventions are listed below.
Ball Grid Array’s with Alphanumeric Rows
BGA + Pin Qty. + C or N + P Pitch _ Ball Columns X Ball Rows _ Body Length X Width X Height + B Ball Diameter
Ball Grid Array’s with Alphanumeric Columns
BGA + Pin Qty. + C or N + P Pitch + A + Ball Columns X Ball Rows _ Body Length X Width X Height + B Ball Diameter
BGA w/Dual Pitch
BGA + Pin Qty. + C or N + P Col Pitch X Row Pitch _ Ball Columns X Ball Rows _ Body Length X Width X Height + B Ball Diameter
BGA w/Staggered Pins
BGAS + Pin Qty. + C or N + P Pitch _ Ball Columns X Ball Rows _ Body Length X Width X Height + B Ball Diameter
Capacitors, Aluminum Electrolytic
CAPAE + Base Body Size X Height + L Lead Length X Width
Capacitors, Chip, Array, Concave
CAPCAV + Pin Qty. + P Pitch _ + Body Length X Width X Height + L Lead Length X Width
Capacitors, Chip, Array, Flat
CAPCAF + Pin Qty. + P Pitch _ + Body Length X Width X Height + L Lead Length X Width
Capacitors, Chip
CAPC + Body Length X Width X Height + L Lead Length
Capacitors, Dual Flat No-lead
CAPDFN + Body Length X Width X Height + L Lead Length X Width
Capacitors, Molded
CAPM + Lead Span X Body Width X Height + L Lead Length X Width
Capacitors, Polarized, Chip
CAPPC + Body Length X Width X Height + L Lead Length
Capacitors, Polarized, Dual Flat No-lead
CAPPDFN + Body Length X Width X Height + L Lead Length X Width
Capacitors, Polarized, Molded
CAPPM + Lead Span X Body Width X Height + L Lead Length X Width
Capacitors, Side Concave, 2 Pin
CAPSC + Body Length X Height + L Lead Length X Width
Ceramic Flat Packages
CFP + Pin Qty. + P Pitch _ Body Length X Lead Span X Height + L Lead Length X Width
Column Grid Array, Circular Lead
CGA + Pin Qty. P Pitch _ Pin Columns X Pin Rows _ Body Length X Width X Height + L Diameter
Pillar Column Grid Array
PCGA + Pin Qty. P Pitch _ Pin Columns X Pin Rows _ Body Length X Width X Height + L Diameter
Crystals (2 leads)
XTAL + Body Length X Width X Height + L Lead Length X Width
Crystals, Dual Flat No-lead
XTALDFN + Body Length X Width X Height + L Lead Length X Width
Crystals, Side Concave
XTALSC + Body Length X Height + L Lead Length X Width
Diodes, Chip
DIOC + Body Length X Width X Height + L Lead Length
Diodes, Dual Flat No-lead
DIODFN + Pin Qty. _ Body Length X Width X Height + L Lead Length X Width
Diodes, Molded
DIOM + Lead Span X Body Width X Height + L Lead Length X Width
Diodes, Non-polarized, Chip
DIONC + Lead Span X Body Width X Height + L Lead Length
Diodes, Non-polarized, Dual Flat No-lead
DIONDFN + Pin Qty. _ Body Length X Width X Height + L Lead Length X Width
Diodes, Non-polarized, Molded
DIONM + Lead Span X Body Width X Height + L Lead Length X Width
Diodes, MELF
DIOMELF + Body Length + Diameter + L Lead Length
Diodes, Side Concave
DIOSC + Body Length X Width X Height + L Lead Length
Diodes, Side Concave, 4 Pin
DIOSC4 + P Pitch _ Body Length X Width X Height + L Lead Length
Diodes, Small Outline Flat Lead, 2 Pin
SODFL + Lead Span X Body Width X Height + L Lead Length X Width
Diodes, Small Outline Flat Lead, 3 - 6 Pin
DIOSOFL + Pin Qty. + P Pitch _ + Lead Span X Body Height + L Lead Length X Width
DPAK
DPAK + Pin Qty. + P Pitch _ Lead Span X Height + L Lead Length X Width + T Thermal Tab Pad Length X Width
Ferrite Bead, Chip
BEADC + Body Length X Width X Height + L Lead Length
Fuses, Chip
FUSC + Body Length X Width X Height + L Lead Length
Fuses, Dual Flat No-Lead
FUSDFN + Body Length X Width X Height + L Lead Length X Lead Width
Fuses, Molded
FUSM + Lead Span X Body Width X Height + L Lead Length X Lead Width
Fuses, Side Concave
FUSSC + Body Length X Height + L Lead Length X Width
IC, Small Outline Package, Flat Lead
SOPFL + Pin Qty. + P Pitch _ + Lead Span X Body Height + L Lead Length X Width
Inductors, Chip
INDC + Body Length X Width X Height + L Lead Length
Inductors, Chip, Array, Concave
INDCAV + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width
Inductors, Chip, Array, Flat
INDCAF + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width
Inductors, Dual Flat No-lead
INDDFN + Body Length X Width X Height + L Lead Length X Width
Inductors, Molded
INDM + Lead Span X Body Width X Height + L Lead Length X Width
Inductors, Precision, Molded
INDPM + Lead Span X Body Width X Height + L Lead Length X Width
Inductors, Side Concave
INDSC + Body Length X Height + L Lead Length X Width
Integrated Circuit, Small Outline, Flat Lead, 3 - 6 pin
ICSOFL + Pin Qty. + P Pitch _ + Lead Span X Body Height + L Lead Length X Width
Land Grid Array, Circular Lead
LGA + Pin Qty. + C + P Pitch _ Pin Columns X Pin Rows _ Body Length X Width X Height + L Lead Diameter
Land Grid Array, Square Lead
LGA + Pin Qty. + S + P Pitch _ Pin Columns X Pin Rows _ Body Length X Width X Height + L Lead Size
LED’s, Chip
LEDC + Body Length + Width X Height + L Lead Length
LED’s, Dual Flat No-lead
LEDDFN + Body Length X Width X Height + L Lead Length X Width
LED’s, Molded
LEDM + Lead Span X Body Width X Height + L Lead Length X Width
LED’s, Side Concave
LEDSC + Body Length X Height + L Lead Length X Width
LED’s, Side Concave, 4 Pin
LEDSC4 + P Pitch _ Body Length X Height + L Lead Length X Width
Oscillators, Dual Flat No-Lead (4-pin)
OSCDFN4 _ Body Length X Width X Height + L Lead Length X Width
Oscillators, Side Concave
OSCSC + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width
Oscillators, Side Flat
OSCSF + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width
Oscillators, J-Lead
OSCJ + Pin Qty. + P Pitch _ Body Length X Lead Span X Height + L Lead Width
Oscillators, L-Bend Lead
OSCL + Pin Qty. + P Pitch _ Body Length X Lead Span X Height + L Lead Length X Width
Oscillators, Corner Concave
OSCCC + Body Length X Width X Height + L Lead Length X Width
Plastic Leaded Chip Carriers
PLCC + Pin Qty. + P Pitch _ Lead Span L1 X Lead Span L2 Nominal X Height + L Lead Width
Plastic Leaded Chip Carrier Sockets Square
PLCCS + Pin Qty. + P Pitch _ Lead Span L1 X Lead Span L2 Nominal X Height + L Lead Width
Pull-back Small Outline No-lead
PSON + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width + T Thermal Pad Length X Width
Pull-back Quad Flat No-lead
PQFN + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width + T Thermal Pad Length X Width
Quad Flat Packages
QFP + Pin Qty. + P Pitch _ Lead Span L1 X Lead Span L2 Nominal X Height + L Lead Length X Width + T Thermal Pad Length X Width
Ceramic Quad Flat Packages
CQFP + Pin Qty. + P Pitch _ Lead Span L1 X Lead Span L2 Nominal X Height + L Lead Length X Width
Quad Flat No-lead
Quad Leadless Ceramic Chip Carriers
LCC + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width
Quad Leadless Ceramic Chip Carriers (Pin 1 on Side)
LCCS + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width
Resistors, Chip
RESC + Body Length X Width X Height + L Lead Width
Resistors, Chip, Array, Concave
RESCAV + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width
Resistors, Chip, Array, Convex, E-Version (Even Pin Size)
RESCAXE + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width
Resistors, Chip, Array, Convex, S-Version (Side Pins Diff)
RESCAXS + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width
Resistors, Chip, Array, Flat
RESCAF + Pin Qty. + P Pitch _ Body Length X Width X Height + L Lead Length X Width
Resistors, Dual Flat No-lead
RESDFN + Pin Qty. _ Body Length X Width X Height + L Lead Length X Width
Resistors, MELF
RESMELF + Body Length + Diameter + L Lead Width
Resistors, Molded
RESM + Lead Span X Body Width X Height + L Lead Length X Width
Resistors, Side Concave
RESSC + Body Length X Width X Height + L Lead Length X Width
Small Outline IC, J-Leaded
SOJ + Pin Qty. + P Pitch _ Body Length X Lead Span X Height + L Lead Length X Width
Small Outline IC, L-Leaded
SOL + Pin Qty. + P Pitch _ Body Length X Lead Span X Height + L Lead Length X Width
Small Outline Integrated Circuit, (50 mil Pitch SOIC)
SOIC + Pin Qty. + P Pitch _ Body Length X Lead Span X Height + L Lead Length X Width
Small Outline Packages
SOP + Pin Qty. + P Pitch _ Body Length X Lead Span X Body Height + L Lead Length X Width + T Thermal Pad Length X Width
Small Outline Diode
SOD + Lead Span X Body Width X Height + L Lead Length X Width
SOT143
SOT143 + P Pitch _ Body Length X Lead Span X Body Height + L Lead Length X Width
SOT223
SOT223 + Pin Qty. + P Pitch _ Body Length X Lead Span X Body Height + L Lead Length X Width
Thermistors, Chip
THRMC + Body Length + Width X Height + L Lead Width
Transistors, Small Outline, Flat Lead, 3 - 6 pin
TRXSOFL + Pin Qty. + P Pitch _ + Lead Span X Body Length X Body Height + L Lead Length X Width
Transistors, Dual Flat No-lead
TRXDFN + Pin Qty. _ Body Length X Body Width X Height + L Lead Length X Width
Varistors, Chip
VARC + Body Length X Width X Height + L Lead Width
SOT23 Form Factor Packages (EIA SOT & JEITA SC)
SOT23-3
SOT23-3P95 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SC59-3
SC59-3P95 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SOT23-5
SOT23-5P95 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SC59-5
SC59-5P95 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SOT23-6
SOT23-6P95 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SC74
SC74-6P95 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SOT28
SOT28-8P65 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SC70-8
SC70-8P65 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SOT323
SOT323-3P65 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SC70
SC70-3P65 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SOT346
SOT346-3P95 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SC59A
SOT346T
SOT346T-3P95 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SC96
SC96-3P95 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SOT353
SOT353 -5P65 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SC88A
SC88A-5P65 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SOT363
SOT363-6P65 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SC88
SC88-6P65 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SOT416
SOT416-3P50 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SC75
SC75-3P50 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SOT753
SOT753 -5P95 _ Body Length X Lead Span X Body Height + L Lead Length X Width
SC74A
SC74A-5P95 _ Body Length X Lead Span X Body Height + L Lead Length X Width
Note: All footprint dimensional values are Nominal except Height is Maximum
  • All dimensions are in Metric Units
  • All Lead Span and Height numbers go two places past the decimal point and "include" trailing Zero
  • All Lead Span and Body Sizes go two place before the decimal point and "remove" leading Zeros
  • All Chip Component Body Sizes are one place to each side of the decimal point
  • Pitch Values are two places to the right & left of decimal point with no leading Zeros but include trailing zeros
Land Pattern Naming Convention: Each land pattern in IPC-7351 is specified by a unique name that must convey the package family type, pin quantity, pin pitch, body length and width dimensions, terminal lead span, terminal lead length and width and thermal pad dimensions whenever applicable. Other fields in a land pattern name are optional and are discussed below.
The following notes provide guidance on using the tables above. Specific characters are reserved for use in the naming convention to denote or separate certain fields:
  • P : Prefixes pin pitch.  For example, P80 specifies a 0.80 mm pitch between terminations.
  • L : Prefixes nominal lead dimensions
  • T : Prefixes thermal tab dimensions
  • X : Dimension separator. For example, 0.80 mm by 1.50 mm is denoted 80X150
  • C, N : Denote Collapsing and Non-collapsing balls respectively when specifying a BGA land pattern
  • : Underscore is a field separator between pin quantity and/or pin pitch and the package body dimensions
  • : Dash is a field separator between pin quantity in hidden and deleted pin components
  • + : Plus denotes "in addition to".  The plus "+" symbol does not actually appear in the land pattern name, it is only used to assist in reading the information.
Additional notes:
  • All dimensions are metric units
  • All dimensions are nominal except height is maximum
  • All numeric values are two places before and after the decimal point and "remove" leading Zeros
  • If there is no pin quantity in the Land Pattern Name it is assumed that the pin quantity is 2
  • Thermal Tabs are included in the Pin Quantity
Additional and Optional Fields:
The suffix letters "L", "M", and "N" are used to signify when the land protrusion is at their minimum (least), maximum (most), or median (nominal) protrusion and appear as the last character. The 3 Density Levels are defined as follows:
  • M = Maximum (Most) Material Condition (Density Level A)
  • N = Median (Nominal) Material Condition (Density Level B)
  • L = Minimum (Least) Material Condition (Density Level C)
If no Density Level suffix is provided, then the land pattern either follows the component manufacturer's recommended pattern or a custom land pattern for use with multiple component manufacturer’s packages in the same component family.
Additional suffices for JEDEC Standard parts that have several alternate packages are as follows:
AA, AB, AC JEDEC Component Identifier (used primarily on Semiconductor packages).
Additional suffixes for alternate components that do not follow the JEDEC standard are as follows (these are located before the Density Level suffix):
"A" - Alternate Component letter is used when component package nominal dimensions are the same for two packages but the package tolerances are different enough to create a unique land pattern to avoid land pattern name duplication.
Ball Grid Array (BGA) packages may require land pattern names that indicate a difference in pitch between balls in the rows vs. balls in the columns. These are often referred to as a “dual pitch BGA”. For example, the BGA land pattern name of BGA48C80X100P6X8_900X1200X120 conveys that the pitch 0.80 mm between columns and 0.10 mm between rows.
Note: In this example, Pin A1 is assumed to be located in the Lower left when viewing the package from the top view. A 90 rotation of the BGA swaps the definition of Rows and Columns.
A pin order or pin quantity modifier shall be added to the component package type specification to convey reverse pin ordering, hidden pins, or deleted pins.
  • SOP20R: 20 pin part, Reverse Pin Order
  • SOT143R: Reverse Pin Order
  • SOP20-24:  20 pin part in a 24 pin package. The pins are numbered 1 – 24 the hidden pins are skipped over. The schematic symbol displays up to 24 pins.
  • SOP24-20: 20 pin part in a 24 pin package. The pins are numbered 1 – 20 the deleted pins are removed. The schematic symbol displays 20 pins.
Land Pattern Naming for Non-conforming Packages: A large number of component packages are unique, non-standard packages or unique connectors. These component packages do not fit into a standard land pattern name due to their unique features. Therefore, in order to have a single land pat tern naming convention that covers every component package in the electronics industry, the land pattern name must be associated with the component manufacturer and their part number or case code as shown below:
ManufacturerNameAbbreviation_ManufacturerPartNumber or
ManufacturerNameAbbreviation_ManufacturerCaseCode
All special characters used in the part number will be replaced with a hyphen "-" except periods "." will be replaced with an underscore "_".
If the component package or connector is unique and has a single manufacturer part number, then Part Number would be used to generate the Land Pattern Name
The component is a standard package and is associated with multiple manufacturer part numbers then manufacturer Case Code would be used to generate the Land Pattern Name
Examples:
FOXCONN_JFM38U1A-2PVT-4F TI_RKG41 CK_CRD16CM0SB
MOLEX_67503-1020 MAXIM_L1053-H2 ABRACON_ABM11
SAMTEC_QTH-060-01-L-D-A CUI_SJ-3566AN AMPHENOL_101-00565-64
For reference, various unique footprints are shown below that are non-conforming with Tables above.
This is the footprint of SAMTEC_QTH-060-01-L-D-A, an connector with plated mounting and non-plated alignment holes.
This page was generated in 2.047 seconds.
