Pad Shapes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Pad Shapes
Surface Mount
Oblong
Recommended by IPC-7351
D-Shape
Recommended by some component manufacturers
Rectangle
Recommended by most component manufacturers
Square
Used on Land Grid Arrays (LGA)
Rounded Rectangle
Recommended by assembly shops for better stencil release; the default corner radius is 0.10 mm
Round
Used on Grid Arrays (BGA. CGA and LGA)
Through-hole
Square
Used on Pin 1 for Polarity on Diodes and Polarized Capacitors
Round
Used on all through-hole parts
Rounded Rectangle
FP Designer Surface Mount
  • FP designer includes all calculator pad shapes. These are the custom pad stacks available in FP Designer.
  • Rectangle and square pad shapes can be chamfered in 2 corners on the Top, Bottom, Left and Right sides.
Top Chamfer
Chamfered on one Corner in Upper Left, Lower Left, Upper Left, Upper Right.
Upper Left
Chamfered Lower Left with Radius Corners
FP Designer Through-hole
Slotted Hole
Non-Plated Hole
Offset Slotted Hole
Chamfered Square
Round Hole with Oblong Pad
Chamfered Rectangle with Offset Hole
Call us - 847-557-2300
This page was generated in 0.098 seconds.
