Through-hole Component Families
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Through-hole Component Families
Axial Leaded Components
A type of through-hole electronic package featuring a symmetrical body with conductive wire leads extending from opposite ends along its longitudinal axis. This straight-line design creates a distinct "arm-like" look that sets it apart from radial components, whose leads emerge parallel from a single side like legs.
JEDEC: DO-007, DO-014, DO-015, DO-016, DO-026, DO-029, DO-032, DO-034, DO-035, DO-039, DO-041
Core Geometry and Structure
  • The Body: The central housing is typically cylindrical or bar-shaped. It protects the internal active or passive element (such as a ceramic formula, carbon composition, or semiconductor junction).
  • The Leads: Two solid, single-strand tinned copper wires extend outward in opposite directions along the exact center line of the body. For heavy-current applications like high-capacity fuses, these leads may occasionally feature stranded or braided wire.
Typical Markings and Identification
  • Resistors: The body features concentric, brightly colored rings. These rings utilize a standardized color code to explicitly define the component's resistance, multiplier, and tolerance values.
  • Diodes: A single, high-contrast solid stripe or band is painted near one edge. This band explicitly marks the cathode (negative terminal) to prevent incorrect orientation during assembly.
  • Capacitors: Cylindrical axial capacitors often print specifications - such as capacitance (uF) and voltage limits - directly onto the outer sleeve. Polarity is indicated by a chamfered edge, an indented groove, or a minus sign (-) arrow pointing toward the negative terminal.
Mechanical Installation Forms
Axial components are highly adaptable and require manual or automated lead-forming before insertion into a printed circuit board:
  • Horizontal Mount (Standard): The leads are bent 90° downward at equal distances from the body. The body sits flat or slightly elevated, resting snugly and parallel to the board surface between two distinct through-holes.
  • Vertical Mount (Goalpost / Panasert): One lead is bent entirely backward 180° to run parallel alongside the component body. This effectively mimics a radial component layout, reducing the total board surface area used at the expense of vertical overhead clearance
Radial Leaded Components
A through-hole electronic package where all conductive leads emerge from a single surface, typically the bottom of the component body. This architecture allows the part to stand upright on a printed circuit board (PCB), taking up significantly less surface area than an axial component.
Dipped
A through-hole component characterized by an irregular, bulbous, organic-shaped body formed by liquid encapsulation. Instead of being housed in rigid plastic boxes or molded cylindrical cans, these capacitors are manufactured by submersing the raw internal element into a protective liquid bath. Both wire terminals emerge parallel to each other from the bottom of the component base.
JEDEC: MO-001, MO-015, MO-016, MO-024, MO-036, MO-037, MO-038, MO-039, MO-043, MO-095, MO-103, MO-122, MS-001, MS-010, MS-011, MS-015, MS-019, MS-020, MS-021, MS-030, MS-031, MS-032
Outer Coating and Texture
  • The "Dip" Finish: The body is encapsulated in a conformal coating of epoxy resin or phenolic resin. This liquid application gives the component smoothed, teardrop, or pebble-like rounded edges that take the shape of the underlying internal dielectric layers.
  • Visual Thickness Variance: The coating thickens significantly near the base, forming a characteristic resin droplet bead right where the copper wire leads enter the component body.
  • Colors: They are most commonly coated in distinctive glossy or matte industrial colors, including vibrant blue, golden-yellow, dark amber, orange, or deep green
Geometry and Common Types
The underlying internal dielectric structure directly determines the shape of the outer dipped shell:
Capacitor Type
Physical Shell Shape
Visual Features
Dipped Tantalum
Teardrop or Oval
Asymmetrical, bulbous bead with a hard, glossy finish.
Multilayer Ceramic (MLCC)
Squarish or Rounded Rectangle
Compact pillow-shape; small footprint.
Dipped Silver Mica
Flat, Broad Pillow
Distinctly wide, compressed body with sharp edge transitions.
Dipped Film
Puffy, Wide Slab
Chunky, elongated rectangle with smoothed, heavily rounded corners.
Lead and Component Markings
  • Polarity (Dipped Tantalum): Dipped tantalum capacitors are strictly polarized. Polarity is indicated by a printed plus sign (+) or a small vertical stripe near the anode terminal. The anode (+) lead wire is manufactured noticeably longer than the cathode lead.
  • Non-Polarized Markings (Ceramic/Mica/Film): These variations are non-polarized. They use a 3-digit numerical EIA code ("104" representing 100,000pF or 0.1uF) followed by a single capitalized letter denoting the manufacturing tolerance rating (J = +/-5%, K = +/-10%).
  • Voltage and Voltage Lines: Rated operating voltages (50V, 1KV) are printed directly under the capacitance value code.
Lead Form and Footprint Characteristics
  • Lead Pitch Spacing: The parallel leads typically exit the base with a standardized pitch grid spacing of 2.54 mm or 5.08 mm.
  • Crimped / Kinked Leads: The wire terminal leads frequently feature factory-formed kinks or offsets right beneath the resin body. These crimps act as mechanical standoffs, preventing the uneven resin bead from seating inside the PCB through-holes, ensuring a level assembly and proper gas venting during automated wave soldering.
Disk
Disk: A flat, circular, coin-like body. They resemble a small lollipop with two thin, parallel wire leads extending from the bottom edge of the disk.
  • The Body: Features a flat, rigid, wafer-thin circular profile. The edges are rounded but the face is completely flat to allow for easy part-number printing.
  • Material Coating: Encapsulated in a matte, brittle ceramic or epoxy coating. The texture is slightly rough, powdery, or chalky to the touch, unlike the glossy finish of dipped capacitors.
  • Colors: They are overwhelmingly manufactured in bright orange, tan, dark brown, or sky blue.
Lead and Structural Features
  • Parallel Leads: Two solid, unshielded wire leads protrude from the bottom edge of the circle.
  • Non-Polarized: The component is non-polarized. Both leads are manufactured to the exact same length, and the part can be inserted into a PCB in either direction.
  • Resin Incursion: The ceramic coating often bleeds slightly down onto the tops of the metal leads. To prevent short circuits or seating issues, the leads are frequently formed with a kink or hockey-stick bend to keep the coated section safely above the PCB surface.
Because the body is flat, information is stamped cleanly across one or both faces using high-contrast black or white ink:
  • Capacitance Code: Uses a three-digit EIA code. The first two digits are the value, and the third is the multiplier in picofarads (103 equals 10,000pF or 0.01uF).
  • Tolerance Letter: A single letter follows the digits (K = +/-10%, M = +/-20%), Z = +80% -20%).
  • Voltage Rating: Clear numeric stamps designate the maximum voltage threshold (50V, 1KV, or 2KV). High-voltage disk capacitors are significantly thicker and larger in diameter.
Disk With Offset Leads
Disk With Offset Leads: An "out-side kink" or "formed lead" disk capacitor) features the same flat, coin-shaped body as a standard disk capacitor, but its parallel wire leads are mechanically bent outward immediately below the resin coating before dropping vertically into the board. This built-in structural modification is specifically designed to wider the lead spacing and mechanically lock the component onto a printed circuit board (PCB).
The Offset Lead Geometry
  • The "Hockey Stick" or "Kink" Bend: The two wire leads emerge from the circular base close together, flare outward sharply at an angle, and then bend straight down again. This creates a distinct "Z" or hockey-stick shape on each lead.
  • Lead Pitch Widening: The primary physical purpose of this offset is to expand the spacing between the wires. For example, it often stretches a narrow 2.54 mm body exit spacing out to a wider, standard 5.05 mm footprint pitch on the PCB.
  • Mechanical Standoff: The horizontal section of the bent wire acts as a built-in shelf. This shelf physically prevents the capacitor body from sliding too deep into the PCB through-holes.
Body Coating and Resin Control
  • Resin Incursion Prevention: On standard straight-lead disk capacitors, the brittle coating material often bleeds unpredictably down the leads. The sharp offset bend acts as a physical barrier that stops this non-solderable resin coating from reaching the solder pads.
  • Stable Seating: Because the bends rest perfectly flat against the top surface of the circuit board, they ensure the flat, circular disk stands perfectly upright and uniform across production lines.
Identification, Texture, and Sizing
  • Symmetry: While the leads are bent outward, the offsets are perfectly symmetrical. Because ceramic disk capacitors are non-polarized, the component remains completely bi-directional.
  • Physical Profile: The outer casing retains its signature matte, slightly chalky ceramic finish - typically in bright orange, tan, or safety-certified blue.
  • High-Voltage Variants: Safety capacitors (X/Y class) and high-voltage disks heavily utilize offset leads to maximize the physical distance between the bare wires, preventing electrical arcing across the surface of the PCB.
Electrolytic
Electrolytic: Upright, metallic, cylindrical canister design. Unlike ceramic capacitors, these parts are strictly polarized and hold much higher capacitance values, making them a staple for power filtering on printed circuit boards.
Through-Hole (Radial) Type: Through-hole variations stand tall on the board like miniature silos. Their structure includes:
  • The Can: An aluminum cylinder wrapped in a tight plastic insulating sleeve (usually colored black, dark blue, green, or brown) with technical specifications printed in high-contrast text.
  • The Rubber Bung: The bottom of the aluminum can is sealed with a dense, black rubber plug. Both wire leads pierce through this bung to exit parallel out of the base.
  • Unequal Leads: To prevent reverse insertion, the positive lead (anode) is visibly longer than the negative lead (cathode).
Key Visual and Safety Markings: Regardless of the mounting style, specific markings ensure safety and proper layout alignment:
  • The Polarity Stripe: A thick, vertical, contrasting band runs down the full height of the outer plastic wrap. This stripe features repeated minus symbols (-) to explicitly identify the negative lead directly beneath it.
  • The Safety Vent: The top face of the aluminum cylinder features a distinct stamped groove pattern (typically an "X", "Y", or "+" shape). If the capacitor fails or overheats, this score line acts as a pressure relief vent, splitting open cleanly to release gas safely rather than exploding violently.
  • Explicit Ratings: Text stamped on the body clearly states the maximum temperature rating (typically 85°C or 105°C), the direct capacitance value in microfarads (uF), and the working voltage threshold (16V, 25V, 50V).
Inductor
Inductor: A through-hole component easily recognized by its exposed wire coil structure or a characteristic hour-glass drum body enclosed in heat-shrink tubing. Unlike multi-terminal transformers, it features exactly two parallel conductive wire leads protruding downward from its base, allowing it to stand vertically to minimize its PCB footprint.
Common Physical Forms
  • Unshielded Drum / Bobbin Inductor: The most recognizable type features a distinct dumbbell or hourglass-shaped ferrite core wrapped in tightly wound enameled copper wire. The entire cylinder is encased in a protective matte-black or colored polyolefin heat-shrink sleeve, giving it a textured, slightly rubbery look with a dimple or taper in the middle.
  • Toroidal Radial Inductor: Features a doughnut-shaped ferrite ring with thick enameled wire coiled around its entire radius. To mount radially, the two wire ends terminate downward. Larger units are glued or mechanically fastened down to a small flat square or rectangular plastic structural base tray equipped with fixed metal pins to ensure stable mounting.
  • Shielded Radial Inductor: Designed to prevent electromagnetic interference (EMI), this style encapsulates the internal coil in a rigid, completely smooth molded plastic or ferrite cylinder housing. The top face is perfectly flat, and the entire assembly resembles a miniaturized, boxier version of an aluminum electrolytic capacitor but without any safety vent stamps.
Geometry and Lead Features
  • The Body: Typically a squat, thick cylinder where the height is often roughly equal to or slightly greater than the diameter (6 x 8 mm or 8 x 10 mm sizes).
  • The Leads: Two stiff, uninsulated tinned copper wires extend from the flat bottom base. Because inductors are non-polarized components, both leads are cut to the exact same length and can be soldered onto the PCB in either direction.
  • Lead Separation (Pitch): The parallel wires exit the base with standardized, wide industrial grids commonly 5.08 mm or 7.50 mm to safely accommodate thicker high-current wire.
Core Markings and Values
  • Numeric Code Stamps: The flat top surface of the heat-shrink sleeve or plastic casing is often printed with a white or silver 3-digit marking code denoting the value in microhenries (uH). For example, 221 translates to 220uH, and 102 denotes 1,000uH (1mH).
  • Tolerance Designator: A capitalized letter frequently follows the three digits to specify structural tolerance (J = +/-5%, K = +/-10%, L = +/-15%).
Molded
Molded: A through-hole electronic component housing where the active or passive device is encapsulated in a rigid, precision-molded plastic or epoxy shell with all leads exiting from a single flat surface.
Unlike the irregular, bulbous shape of "dipped" components, molded bodies are formed using high-pressure injection molding. This process creates crisp, geometric shapes with uniform dimensions optimized for automated pick-and-place machines and robotic PCB assembly.
Common Body Shapes and Geometry: Molded body packages are engineered to standard industrial dimensions and generally fall into three geometric profiles:
  • Molded Box / Rectangular: A perfect rectangular cuboid (often called a "box" package). The walls are flat, smooth, and meet at sharp 90° angles, common for film capacitors and specialized resistors.
  • Molded Cylinder: A perfectly straight, rigid plastic column with a flat top and a flat bottom base, often used for molded inductors or specialized diodes.
  • Molded Tear-Drop / Wedge: A smooth, uniform block that tapers slightly toward the top, typical for modern molded solid tantalum capacitors.
Core Material and Texture
  • The Shell: Made of a hard, brittle, thermosetting plastic or epoxy resin (frequently glass-fiber reinforced).
  • Texture: The surface is completely uniform, matte or semi-glossy, and entirely free of the liquid runs or droplet beads found on dipped components.
  • Colors: They are overwhelmingly molded in deep matte black, dark grey, or vibrant red/box-car yellow (highly characteristic of specialized film capacitors).
Lead Configuration and Base Features
  • Parallel Pins: Solid, rigid tinned copper or alloy leads protrude straight down from the flat bottom surface.
  • Built-in Standoff Feet: The molded plastic base often features small, integrated molded bumps or ridges (bosses). These tiny feet lift the main component body roughly 0.50 mm off the PCB surface. This gap ensures that flux and solder gases can escape cleanly during wave soldering and allows cleaning solvents to pass underneath.
  • Lead Pitch Grid: Leads are spaced at highly precise, standardized intervals - typically 2.54 mm, 5.08 mm, or 7.50 mm - matching standard PCB CAD layout grids exactly.
Component Markings and Alignment: Because the faces of a molded body are perfectly flat, technical details are clearly printed or laser-etched onto the top or broad side:
  • Polarity Keying: For polarized components (like molded radial tantalum capacitors), a beveled/chamfered edge is molded into the top corner corresponding to the positive (+) lead, often accompanied by a printed laser stripe. Non-polarized versions (like film capacitors) feature perfectly symmetrical square corners.
  • Laser Etching: Text including the manufacturer's logo, part series, capacitance/inductance values, and voltage ratings are permanently etched with high precision, ensuring readability even on tiny components.
LED
LED: A polarized optoelectronic component easily recognized by its clear or tinted dome-shaped plastic body and two parallel wire leads extending from its base. It stands vertically on a printed circuit board (PCB) to project light upward or outward.
Depending on the application, they are manufactured in standard sizes like 3 mm (T-1), 5 mm (T-1 ¾), and 10 mm, all sharing a highly standardized physical profile.
The Optical Body Geometry
  • Body Shapes: Round or Rectangle
  • The Epoxy Lens: The main body is a solid, rigid cylinder topped with a hemispherical dome that acts as a focusing lens. The plastic can be completely water-clear, diffused (milky), or color-tinted to match the LED's output light.
  • The Flat Edge (Cathode Indicator): The most distinct mechanical feature of the circular base is a prominent flat notch or shaved edge on the plastic rim. This flat side always corresponds to the negative terminal (cathode).
  • The Base Flange: A small, raised plastic ridge or rim runs around the very bottom of the cylinder, used by automated insertion machinery to grip the component during assembly.
Lead Configuration and Anvil Anatomy: Because LEDs are highly polarity-sensitive and will not illuminate if reversed, the package features three separate physical keys to differentiate the terminals:
Feature
Anode (+)
Cathode (-)
Lead Length
Noticeably Longer
Shorter
Plastic Body
Rounded side
Flat / Shaved side
Internal Frame
Smaller post (Pin)
Triangular block
Interior Construction (Visible Profile): When looking through a clear or translucent LED body, you can see the internal lead-frame:
  • The Anvil: The negative lead connects to a wide, flat triangular frame. The tiny semiconductor LED die sits inside a reflective cavity on top of this anvil.
  • The Post & Wire Bond: The positive lead extends up as a thin post. A microscopic gold wire bonds the top of this post to the semiconductor die resting on the anvil.
PCB Mounting Variations
  • Standard Vertical Mount: The leads go straight into the PCB, resting the flange flush against the board or slightly elevated on a plastic spacer to ensure perfect alignment.
  • Right-Angle Mount: The leads are bent 90° right below the plastic base (often encased in a black plastic housing block) so the dome lens points horizontally toward the edge of the enclosure to serve as an indicator light.
Crystal (HC49)
Crystal (HC49): A radial, passive quartz resonator housed in a distinct metallic, capsule-like canister. It features an elongated, oval-profile body with two stiff wire leads exiting from a hermetically sealed glass base.
Commonly used to generate reliable reference clock frequencies for microcontrollers, it stands upright or lies flat against a printed circuit board (PCB).
Standard Profiles (HC49/U vs. HC49/S): The term "HC49" encompasses two primary height profiles that share identical footprint spacings but dictate vertical clearance:
  • Full-Height (HC49/U): The traditional, tall profile. The metal body stands roughly 13.20 mm to 13.50 mm high, mimicking a tall metal silo on the circuit board.
  • Low-Profile / Half-Height (HC49/S or HC49/US): The modern, horizontally squashed equivalent. It restricts the package height to a compact 3.50 mm to 4.20 mm, preventing interference with stacked shield boards or tight enclosures.
Physical Dimensions and Structure
  • The Metallic Can: Constructed from nickel-plated or tin-plated steel, providing rugged structural armor and vital electromagnetic shielding against radio-frequency noise.
  • Oval Cross-Section: The body footprint is a distinct flattened oval (stadium shape) measuring roughly 11.40 mm to 11.50 mm in length and 4.70 mm in width.
  • The Resistance-Weld Flange: A prominent, sharp metal lip or rim projects outward around the lower edge where the cap joins the header. This flange seals the internal quartz crystal wafer in a pure vacuum or dry nitrogen environment.
Base Elements and Lead Configuration
  • Glass-to-Metal Seal: The base of the container features a flat metal header with two tiny glass eyelets. These glass beads insulate the conductive pins from the metal canister while maintaining the airtight seal.
  • Symmetrical Radial Leads: Two rigid, uninsulated tinned copper wires pass through the glass seals to extend parallel down into the board. Crystals are non-polarized components, meaning the leads are identical in length and can be installed facing either direction.
  • Lead Spacing (Pitch): The center-to-center lead spacing is highly precise, fixed at a standardized 4.88 mm pitch grid.
Mechanical Mounting Variants: Due to its heavy metallic shell, mounting requires distinct configurations based on vibration limits and height profiles:
  • Vertical Stand-Up (Standard): The pins slide directly through the PCB holes, dropping the resistance-weld lip right over the copper traces.
  • Horizontal Lay-Down: In space-constrained layouts or high-vibration applications, a tall HC49/U can is often bent 90° horizontally. It is laid flat against the board surface and anchored with a dollop of adhesive or a small mechanical metal strap soldered to a ground trace.
  • The Mylar Spacer Pad: Because the entire outer canister is metallic and conductive, components are frequently supplied with a thin, pre-installed plastic or Mylar insulating spacer resting over the pins against the base. This prevents the metal body from causing unexpected electrical short-circuits across bare board traces routed directly beneath the crystal.
TO-92
TO-92: A highly ubiquitous, low-cost through-hole radial plastic package most commonly used for low-power transistors, voltage regulators, and signal sensors. It is instantly recognizable by its compact, semi-cylindrical, "D-shaped" body with three distinct parallel wire leads emerging from its base.
JEDEC: TO-226
Geometric Body Anatomy
  • The "D-Shape" Profile: If viewed from directly above, the plastic body forms a distinct capital letter "D". It features one perfectly flat front face and a smoothly rounded, semi-circular back wall.
  • The Plastic Shell: The encapsulation consists of a hard, rigid, matte-black epoxy compound that protects the sensitive internal silicon semiconductor die from moisture and physical damage.
  • Compact Dimensions: It is a small package, typically measuring roughly 4.50 mm to 5 mm in height, with a width and depth of about 4 mm to 5 mm.
Lead Configuration and Lead Formats: The TO-92 traditionally features three solid, uninsulated tinned alloy leads protruding straight down from the flat bottom base. Depending on production needs, these leads are shipped in two common layout styles:
  • Straight Inline Leads (TO-92 Bulk): All three pins exit in a tight, perfectly straight line with a very narrow center-to-center pitch of just 1.27 mm.
  • Spread / Bent Leads (TO-92 Tape & Reel): For automated insertion and to reduce solder-bridging short circuits, the middle lead stays straight while the two outer leads flare outward. This transforms the tight line into a wider, triangular triangular arrangement with a standard 2.54 mm grid pitch.
Pin Identification and Markings
  • Laser-Etched Front Face: Part numbers (such as 2N3904 or LM78L05) along with manufacturer logos and batch codes are laser-etched directly onto the flat face of the "D" shape.
  • Strict Pin Orientation: Pin ordering is asymmetrical and highly critical. When holding the package at eye level with the flat face directly facing you and the leads pointing downward, the pins are counted from left to right as Pin 1, Pin 2, and Pin 3.
  • For standard Bipolar Junction Transistors (BJTs), this sequence typically maps to Emitter-Base-Collector (E-B-C) or Source-Gate-Drain (S-G-D), depending on the specific part registry.
PCB Layout and Assembly Realities
  • Silkscreen Alignment: The PCB silkscreen outline for a TO-92 is drawn as a clear "D" shape to show the assembler which way the flat face must point, preventing catastrophic reverse installation.
  • Thermal Limitations: Because the package is entirely plastic and lacks a dedicated metal cooling tab (unlike the larger TO-220), it relies solely on the surrounding air and its thin wire leads to shed heat. It is strictly limited to low-power applications, typically under 1 Watt.
TO Cylindrical Style
TO Cylindrical Style: A highly durable, hermetically sealed through-hole component casing. The "TO" stands for Transistor Outline, and these cylindrical variants represent some of the earliest and most robust designs in semiconductor packaging history.
They are widely used for precision small-signal transistors (like the classic Central Semiconductor 2N2222A), operational amplifiers, legacy integrated circuits, and optoelectronic sensors.
JEDEC: MO-002, MO-006, TO-205, TO-206
Core Geometry and Construction
  • The Metal Can Cap: The component is enclosed in a perfectly smooth, unpainted cylindrical shell made of nickel-plated steel, aluminum, or Kovar. This cap acts as an integrated Faraday cage, providing exceptional electromagnetic interference (EMI) shielding.
  • The Header Base Plate: The bottom of the package is a flat, thick metal disc (the header). The internal silicon semiconductor die is mounted directly onto this base plate for rigid mechanical support.
  • Glass-to-Metal Seals: To prevent short-circuits, the metal leads pass through the header via individual, tiny beads of insulated glass. These beads are fused under extreme heat, maintaining an airtight (hermetic) vacuum or nitrogen-filled chamber inside the can to shield the die from atmospheric moisture and contaminants.
Common Size Variants: Cylindrical TO packages share the same design language but scale drastically depending on pin counts and heat dissipation needs:
  • TO-18: The smallest standard metal can, measuring roughly 4.70 mm to 5.40 mm in diameter. It usually features 3 leads arranged in a tight circular cluster and is the premium, rugged alternative to the plastic TO-92 package.
  • TO-5 / TO-39: A medium-sized cylinder with a base diameter of approximately 8.90 mm. While TO-39 typically features 3 pins for medium-power transistors, the TO-5 header can house anywhere from 2 up to 10 pins arranged in a circular array, commonly used for vintage multi-pin op-amps.
  • TO-8: A much larger, flat cylindrical format designed to handle higher operational power and internal circuitry, often housing multi-pin micro-sensors or hybrid modules.
Pin Orientation and The Alignment Tab: Because the package is perfectly circular, it requires a physical feature to indicate pin assignments:
  • The Indexing Tab: A tiny, sharp metal tongue or ridge projects outward from the bottom rim of the header base plate.
  • Pin 1 Identification: When looking directly at the bottom base of the package with the leads pointing at your face, the indexing tab is used as the orientation key. The pin positioned immediately clockwise from the tab is Pin 1 (frequently the Emitter on standard 3-pin transistors). The rest of the pins are numbered sequentially following a clockwise circle.
  • Case Grounding: In many RF and high-frequency applications, one specific pin is welded directly to the metal header base plate instead of passing through an insulating glass bead, automatically grounding the metal outer shield to the PCB ground plane.
PCB Footprint and Mounting Styles
  • The Pin Circle Array: On a circuit board, the through-hole landing pads are arranged in a perfect circular pitch layout rather than a straight line. For instance, a TO-18 typically uses a 2.54 mm diameter pin circle, while a TO-5 expands to a 5.08 mm pin circle.
  • Lead Splaying: Because the circular pin pattern is so compact, assembly technicians or automated machines often flare the leads outward into a wider triangular configuration before dropping them into the PCB to prevent solder bridges.
  • Silkscreen Target: The PCB silkscreen outline mimics a circle with a tiny notch on the perimeter, matching the layout of the physical orientation tab exactly to avoid reverse insertion.
Flange Mount (TO) Horizontal & Vertical
Flange Mount (TO) Horizontal & Vertical Mount: A high-power semiconductor housing designed with a built-in mechanical metal tab, wing, or extended base (the flange). The primary purpose of this design is to allow the component to be rigidly bolted or clamped directly to an external heatsink or metal chassis, optimizing thermal transfer for components generating high waste heat.
The "TO" designation stands for Transistor Outline, and flange mount variants bridge the gap between delicate board circuitry and heavy-duty mechanical thermal management. They are split into two primary design families: Tabbed In-line Packages and Diamond/Flange Base Packages.
JEDEC (Vertical): MO-048, MO-168, MO-218, TO-247
JEDEC (Horizontal): TO-220, TO-254, TO-257, TO-267
Tabbed In-line Family (TO-220, TO-247): The most modern and common type of flange mount, where the component stands vertically or lies flat on the board:
  • The Tab Flange: A prominent, flat exposed metal tab extends from the top or back of the rectangular plastic body. It features a single, centralized mounting hole (typically sized for a #4-40 or M3 screw).
  • Electrical Caveat: The metal tab is typically an expansion of the internal lead frame and is electrically live (usually tied to the Center Pin / Collector / Drain).
  • Variations (Full-Pack): Isolated variations, such as the TO-220FP, encase the metal flange entirely in a thin layer of over-molded plastic. This eliminates the need for an external mica insulator during installation, though it reduces thermal efficiency slightly.
Diamond / Metal Plate Family (TO-3): A legacy, heavy-duty "metal can" package designed for extreme current and rugged reliability:
  • The Diamond Flange: The base of the package is a thick, rigid diamond-shaped metal plate. It features two mounting holes positioned on opposite wings along the long diagonal line of the diamond.
  • The Cap: A cylindrical metal hat is welded to the center of the diamond plate, protecting the silicon die in a hermetic vacuum.
  • Body as a Terminal: Only two pins (typically Base and Emitter) protrude through glass seals on the bottom. The massive metal flange body is the third electrical connection (the Collector), requiring the mounting screws themselves to pass current to the PCB traces via eyelet lugs.
Mechanical Installation Realities: Because flange mount packages are mechanically fastened, their physical footprint layout requires strict adherence to assembly guidelines:
  • Thermal Interface Materials (TIM): To prevent electrical short-circuits to a grounded heatsink, the flange is often sandwiched between a silicone/mica insulating pad and a plastic insulating shoulder washer inserted inside the screw hole. Thermal grease is applied to fill microscopic air gaps.
  • Lead Stress Prevention: When bending the pins of a TO-220 to mount it flat against a board, the leads must be clamped tightly before the bend is made. Bending forces must never pull against the plastic body, or the internal wire bonds will break.
  • Torque Control: Screws must be tightened to specific torque limits (roughly 0.5 to 0.8 N) for a TO-220). Excessive torque will warp the flat metal flange, causing it to bow upward and lose thermal contact with the heatsink.
Oscillator
Oscillator: A through-hole radial lead crystal oscillator (commonly called a clock oscillator or active crystal) is a fully self-contained timing circuit housed in a metallic, rectangular canister with exactly four parallel pins protruding from its base.
Unlike passive 2-pin quartz crystals that require external capacitors and inverter circuits to function, active oscillators combine the quartz wafer, a built-in oscillation circuit, and load capacitors into a single powered module. They stand vertically on a printed circuit board (PCB) to feed a clean, pre-stabilized square-wave clock signal directly into microprocessors.
Standard Geometric Profiles
: Through-hole active oscillators are built around legacy Dual In-line Package (DIP) footprints. Although they only possess 4 pins, their metal cans span the exact outer dimensions of standard 8-pin or 14-pin integrated circuits:
  • Full-Size (DIP-14 Package): A long, distinct rectangular block mimicking a 14-pin chip footprint. Standard dimensions are roughly 20.40 mm x 12.90 mm with a height of 5.5mm.
  • Half-Size (DIP-8 Package): A compact, perfectly square variant mimicking an 8-pin chip footprint. Standard dimensions are roughly 12.70 mm x 12.70 mm with a height of 5.50 mm.
Canister Shell Construction
  • Hermetically Sealed Can: The body consists of a nickel-plated or tin-plated steel cover. It is resistance-welded to a flat metal header plate, shielding the fragile internal micro-circuit from environmental humidity and electromagnetic interference (EMI).
  • Rounded and Sharp Geometry: The upper edges of the metallic shell are smoothly rounded, but one specific corner on the base is manufactured with a sharp 90° angle or index dot to serve as a visual key for orientation.
Pin Layout and Identification (The "Missing Pins" Phenomenon): Even though the metal enclosure matches a standard 8-pin or 14-pin IC frame, only four physical corner leads are present. The empty spaces where intermediate pins would normally be completely smooth and sealed off.
When looking directly at the top face of the oscillator with the sharp/indexed corner oriented at the bottom-left, the active pins drop into the layout grid as follows:
Pin Designation
Full-Size
(DIP-14) Location
Half-Size
(DIP-8) Location
Pin 1
Bottom-Left Corner
Bottom-Left Corner
Pin 7 / 4
Bottom-Right Corner
(Pin 7)
Bottom-Right Corner
(Pin 4)
Pin 8 / 5
Top-Right Corner
(Pin 8)
Top-Right Corner
(Pin 5)
Pin 14 / 8
Top-Left Corner
(Pin 14)
Top-Left Corner
(Pin 8)
PCB Footprint and Installation Characteristics
  • Lead Pitch: The four corner pins maintain standard DIP spacing. Row-to-row spacing is 7.62 mm, while side-to-side pin spacing spans either 15.25 mm for Full-Size or 7.62 mm for Half-Size.
  • Glass-to-Metal Insulation: The pins protrude out of the flat metal bottom plate through microscopic, insulating glass beads.
  • Case Grounding: To minimize radio-frequency radiation, Pin 7 (or Pin 4 on half-size) is intentionally welded directly to the interior metal header wall. This structural link automatically connects the massive metal outer shield directly to the PCB ground plane when soldered.
Single In-Line Package (SIP)
Single In-Line Package (SIP): a flat, rectangular, wafer-thin body with a single row of straight conductive pins protruding from its bottom edge.
Because it stands perfectly upright - like a small fence on the printed circuit board - it is highly favored for space-constrained layouts. It is most commonly used for resistor networks, legacy memory modules (SIMMs), diodes, and low-power power management modules.
JEDEC: MO-068
Geometric Profile and Texture
  • The Body: Features an elongated, narrow rectangular profile. It has a very small depth (thickness) relative to its length and height, maximizing available board space.
  • Material Encapsulation: Typically constructed from a rigid, matte-black thermosetting plastic or a smooth molded epoxy resin.
  • Profiles: They exist in low-profile, medium, and high-profile configurations depending on the internal circuitry, ranging from 4 mm to 12 mm in total height.
Lead Arrangement and Pitch
  • The Single Row: Unlike a Dual In-line Package (DIP) which uses two parallel rows of legs, a SIP features exactly one straight line of parallel metal pins.
  • Pin Count Variability: A SIP can have anywhere from 2 to over 40 pins along its single axis, though 4-pin to 10-pin variants are the most common in standard commercial hardware.
  • Standardized Grid Pitch: The center-to-center pin spacing is manufactured to a highly precise, industry-standard 2.54 mm linear pitch, perfectly matching the default grid lines of standard prototyping breadboards and CAD software.
Pin Identification and Keying
Because a single row of pins can easily be accidentally flipped 180° during manual assembly, the package features distinct visual orientation keys:
  • The Indexing Dot / Chamfer: A molded recess dot, a printed stripe, or a beveled corner is placed on the body directly adjacent to Pin 1.
  • Pin Numbering: Pin assignment is counted sequentially in a straight line from left to right (Pin 1, 2, 3, 4...) when viewing the front printed face of the component with the leads pointing downward.
  • Common Pin (Resistor Networks): In bussed resistor networks, Pin 1 acts as the "Common" connection point for all internal resistors, while the remaining pins connect to individual resistors.
PCB Mechanical Realities
  • High Structural Leverage: Because SIPs stand tall on a single narrow line of legs, they are highly vulnerable to physical impacts, vibration, and tipping during wave soldering.
  • Standoff Bumps: The base of the plastic housing often features tiny, built-in molded spacer feet to keep the body slightly raised above the board. This gap ensures solder gases can escape and cleaning chemicals can wash away any residual manufacturing flux.
  • The Zig-Zag Variant (ZIP): To achieve even higher density, some packages utilize a Zig-zag In-line Package (ZIP) lead form, where the pins alternate bending slightly forward and backward, transforming the single row into a staggered, dual-line footprint on the PCB.
Dual In-Line Package (DIP)
Dual In-Line Package (DIP): A rectangular housing with two parallel rows of downward-pointing conductive pins protruding from its longer sides.
Widely used for integrated circuits (ICs), microcontrollers, operational amplifiers, and optocouplers, its design resembles a mechanical "bug" or "centipede" standing over the printed circuit board (PCB).
Geometric Profile and Construction
  • The Body: A rigid, elongated rectangular block. The most standard version is a Plastic DIP (PDIP) molded from a matte-black thermosetting epoxy. For high-reliability, aerospace, or vintage military gear, a Ceramic DIP (CDIP) is used, recognizable by its smooth, chalky purple-grey or white body.
  • The Two Lead Rows: Pins emerge horizontally from both long sides of the body before bending sharply 90° downward. This creates two identical, parallel rows of legs flanking the main chip housing.
  • Inward Lead Flare: Before soldering, the legs flare outward at a slight angle (8° to 15°) so they act like springs. This flair holds the chip firmly inside the PCB through-holes during manufacturing, so it does not fall out before reaching the soldering machine.
Standard Sizing and Pitch Dimensions: DIP spacing adheres to rigid JEDEC industry standards to guarantee compatibility with prototyping breadboards and standard IC sockets:
  • Linear Pin Pitch: The center-to-center distance between individual pins along a single row is exactly 2.54 mm.
  • Row-to-Row Spacing: The width between the two rows of legs scales based on the size of the chip:
    • Narrow DIP (7.62 mm): The standard for small chips ranging from 8 pins up to 28 pins.
    • Wide DIP (15.24 mm): Used for large, dense integrated circuits ranging from 24 pins up to 64 pins.
    • Skinny DIP (10.60 mm): A rare, intermediate hybrid width used on specialized memory chips.
Orientation Keys and Pin Numbering Protocol: Because reversing an integrated circuit can instantly destroy it when powered up, the DIP standard enforces a strict physical layout keying system:
  • The Orientation Notch: One of the two short, narrow ends of the rectangular body features a semi-circular notch or U-shaped indentation. On some smaller chips, this notch is replaced or supplemented by a small molded circular dot placed directly in the top corner next to Pin 1.
  • The Counter-Clockwise Counting Rule: Pin numbering is determined relative to the notch. Place the chip flat in front of you so that the orientation notch is facing up (pointing away from you):
    • Pin 1 is the very first pin located at the top-left corner, immediately to the left of the notch.
    • Numbering proceeds straight down the left row sequentially (Pin 1, 2, 3, 4...).
    • Upon reaching the bottom of the left row, the numbering jumps across to the right side and wraps up the right row from bottom to top.
    • The highest-numbered pin on the chip will always sit at the top-right corner, directly across from Pin 1.
PCB Assembly and Sockets
  • Direct Soldering vs. Sockets: DIP chips can be soldered directly into the PCB through-holes. However, they are frequently pushed into a plastic DIP IC Socket that has been pre-soldered to the board. This allows for quick, toolless replacement of a failed chip without risking thermal damage to the PCB traces from a desoldering iron.
  • Standoff Shoulders: Each metal leg features a wider "shoulder" section right where it emerges from the plastic body. These shoulders act as physical stoppers, preventing the plastic housing from resting flush against the PCB. This leaves a critical air gap underneath for flux removal, cleaning solvents, and thermal air cooling.
Dual In-Line Package (DIP Socket)
Dual In-Line Package (DIP Socket): A specialized through-hole connector permanently soldered to a printed circuit board (PCB) to hold a DIP integrated circuit (IC) without soldering the chip itself. It mirrors the exact rectangular footprint, row spacing, and pin count of the specific DIP chip it is designed to accommodate, acting as an intermediary mechanical and electrical bridge.
Depending on reliability requirements, they are manufactured in two primary styles: Stamped-Contact (Economy) and Machined-Contact (Turned-Pin/Premium).
Structural Frame and Geometry
  • The Body: A rigid, ladder-like frame molded from black, glass-reinforced thermoplastic. It consists of two long outer parallel rails connected by one or more thin cross-beams (struts). This open, skeletal layout leaves the PCB surface underneath visible for routing traces or placing decoupling capacitors.
  • The Orientation Notch: Like the ICs they hold, one short end of the socket frame features a molded U-shaped notch or indentation. This notch aligns perfectly with the chip's orientation key to ensure it is not inserted backwards.
  • Stand-off Feet: The bottom of the plastic frame features small, molded-in spacer nubs. These lift the plastic body roughly 0.50 mm off the PCB, allowing manufacturing gases to escape during wave soldering and flux cleaning solvents to pass underneath.
Dual Contact Technologies
The top face of the socket rails features two rows of small entry holes containing hidden internal metal spring clips. These contacts grip the IC legs when the chip is pushed into the socket:
  • Stamped / Dual-Leaf Contacts (Economy): The internal terminals are stamped from flat sheets of phosphor bronze or brass and plated with tin. They feature two flat, spring-loaded leaves that pinch the wide flat sides of the IC pin. While highly cost-effective, they are prone to losing tension over multiple insertions or loosening under heavy vibration.
  • Machined / Turned-Pin Contacts (Premium): The contact outer shells are individually machined on high-precision lathes into solid, gold-plated or tin-plated cylindrical tubes. Inside each tube sits a stamped, multi-finger beryllium-copper spring clip (resembling an internal crown). These provide gas-tight electrical contact and maximum mechanical retention, making them the standard for aerospace, military, and high-vibration applications.
Pin and Dimensional Matrix: DIP sockets precisely duplicate the exact standardized pitch layout of JEDEC DIP standards to guarantee drop-in compatibility:
  • Linear Pin Pitch: The center-to-center distance between adjacent entry holes down a single row is exactly 2.54 mm.
  • Row-to-Row Spacing (Width): Sockets are manufactured in two standard industrial widths:
    • 7.62 mm: For standard narrow chips (typically 8, 14, 16, 18, 20, 24, or 28 pins).
    • 15.24 mm: For wide integrated circuits and microprocessors (typically 24, 28, 40, or 48 pins).
  • The PCB Pins: Protruding out the bottom of the socket are solid, uninsulated tinned alloy pins. On stamped sockets, these pins are flat, rectangular tabs; on machined sockets, they are perfectly smooth, solid cylinders tapering to a point to slip effortlessly into PCB drill holes.
Pin Grid Array (PGA)
Pin Grid Array (PGA): A high-pin-count, through-hole integrated circuit housing characterized by a square or rectangular body with a dense matrix (grid) of parallel conductive pins covering its entire bottom surface.
Unlike a DIP or SIP package where pins are restricted only to the outer edges, a PGA utilizes the complete floor space of the component base. This architecture allows it to route hundreds of electrical connections. It was the dominant package design for high-performance microprocessors (such as the Intel 80486 and early AMD Athlon/Phenom CPUs) before surface mount and Land Grid Array (LGA) formats took over.
JEDEC: MO-066, MO-067, MO-083, MO-145, MS-017
Structural Materials and Anatomy
  • The Carrier Body: PGAs are traditionally square wafers built from one of two rigid materials:
  • Ceramic PGA (CPGA): A heavy, chalky, multi-layer ceramic plate (often purple, white, or dark grey) topped with a shiny gold or silver metal heat-spreader cap. These offer premium thermal management and hermetic sealing.
  • Plastic PGA (PPGA): A lighter, cost-effective alternative made from a dense organic polymer resin, often colored black or deep green.
  • The Pin Matrix: The bottom face is populated by an array of thin, solid, gold-plated or tin-alloy pins protruding straight down. These pins are highly fragile and easily bent if mishandled.
Grid Array Geometry and Keying
  • The "Interstitial" Layout: Pins are arranged in an even grid pattern, typically spaced at a standard linear pitch of 2.54 mm or a tighter 1.27 mm on denser, modern iterations.
  • The Center Void: To save cost and leave space for the silicon die and internal decoupling capacitors, the center of the grid is almost always left empty (devoid of pins), creating a hollow square frame pattern.
  • Physical Orientation Keying: Because reversing a high-power processor can immediately destroy it, PGAs enforce strict physical keying. One or more corners of the array will feature a missing pin, a staggered corner pin, or a beveled 45° corner on the plastic/ceramic package. This layout forces a single, correct installation alignment.
PCB Installation and ZIF Sockets
  • The ZIF Intermediary: Due to the massive insertion force required to push hundreds of pins into a tight circuit board simultaneously, PGAs are rarely soldered directly into a PCB. Instead, they are dropped into a Zero Insertion Force (ZIF) Socket pre-soldered to the board.
  • The Locking Lever: A ZIF socket features a small mechanical arm. When the arm is raised, the internal socket contacts open completely, allowing the PGA pins to drop in freely with zero resistance. Lowering and clamping the lever slides the internal socket matrix horizontally, firmly gripping every pin to establish a gas-tight electrical bond.
Header, Right Angle Post
Header, Right Angle Post: a board-level connector featuring a single or multi-row array of rigid square metal pins bent at a sharp 90° angle.
This specific component is structurally engineered to allow multi-wire cables, daughterboard modules, or ribbon connectors to plug into the host printed circuit board (PCB) parallel to the board surface. It provides a low-profile connection that prevents wire strain and keeps vertical clearance to a minimum.
The Pin Anatomy and the 90° Bend: The component is built using solid, square-cut wire posts (typically made of brass or phosphor bronze) that are plated with tin or gold. Each pin is physically divided into three distinct segments by its bend:
  • The Solder Tail: The shorter, vertical end of the pin that passes down through the PCB plated through-holes to be soldered on the underside of the board.
  • The Right-Angle Bend: A precision factory-formed 90° corner situated immediately beneath the plastic insulator strip.
  • The Mating Post: The longer, horizontal segment of the pin that projects outward past the edge of the PCB. This is the active terminal that slides into a mating female housing or jumper wire.
The Plastic Insulator Strip (The "Backbone")
  • Material Construction: The pins are held uniformly in place by a narrow, rigid strip of high-temperature plastic (such as Nylon, PBT, or LCP) capable of withstanding the heat of wave soldering or manual rework.
  • Breakaway Design (Unshrouded): On basic unshrouded versions, the plastic strip features small notches or score lines between each pin cavity. This allows assembly technicians to easily snap long 40-pin master strips down to any custom pin count needed (a 2-pin or 4-pin block) without specialized cutting tools.
Array Variations and Matrix Configurations: Right-angle post headers are highly modular and scale across standard layout configurations:
  • Single-Row (1xN): A single line of parallel horizontal pins protruding from the plastic housing.
  • Dual-Row (2xN): Two parallel lines of horizontal pins stacked vertically. The bottom row passes straight through the plastic into the PCB, while the upper row features longer vertical bends to step over the lower row, ensuring both sets of pins line up perfectly on the horizontal mating plane.
  • Multi-Row: Stacking configurations up to 3 or 4 rows deep are utilized in high-density backplanes or legacy computing buses (3 x 40 arrays).
Dimensional and Pitch Standards
To maintain universal compatibility with external connector families, right-angle post headers are tightly tied to standardized industrial grids:
  • Pitch Spacing: The center-to-center linear distance between pins is most commonly a standard 2.54 mm pitch. Denser, more compact electronics use sub-miniature pitches of 2.00 mm, 1.27 mm or even 1.00 mm.
  • Square Post Thickness: In the dominant 2.54 mm family, each metal post is cut to a precise cross-sectional dimension of 0.64 mm square.
Unshrouded vs. Shrouded Variations
  • Unshrouded Headers: The bare pins are completely exposed. This offers the lowest cost and smallest physical layout footprint but leaves the pins vulnerable to bending if bumped or mishandled.
  • Shrouded / Boxed Headers: The plastic housing extends outward to create a rigid plastic box or wall around the mating posts. This shroud incorporates physical mating notches (polarization slots) to ensure an external wire harness can only be plugged in facing the correct direction, preventing catastrophic reverse-voltage connections.
Header, Right Angle Receptacle
Header, Right Angle Receptacle: A right-angle female header or socket strip) is a board-level connector featuring a single or multi-row plastic housing filled with internal spring contacts and pins bent at a sharp 90° angle.
While a post header features exposed male pins, a receptacle header contains recessed female entry holes. This design allows a daughterboard or a male pin wire harness to plug directly into the host printed circuit board (PCB) parallel to the board surface, keeping vertical overhead clearance to an absolute minimum.
Geometric Profile and Structural Features
  • The Connector Body: A long, rigid rectangular block molded from a high-temperature thermoplastic (such as Nylon or PBT). The front-facing edge contains a row of tiny, square entry ports to receive male pins, while the back or bottom edge is sealed.
  • The Right-Angle Solder Tails: Stiff metal pins emerge from the back of the plastic housing, bend sharply 90° downward, and pass vertically into the PCB plated through-holes.
  • Flush or Edge Mounting: The plastic body rests flat on the board surface, often positioned right along the physical edge of the PCB so an external device can slide horizontally into the assembly.
Internal Contact Architecture
  • Dual-Leaf Spring Contacts: Inside each plastic entry port sits a hidden, stamped metal terminal made of phosphor bronze or brass, heavily plated with gold or tin.
  • Wiping Action: These internal contacts act like tiny tuning forks or spring clamps. When a male pin enters the socket, it pushes these leaf springs apart. This mechanical pressure ensures a constant, low-resistance, vibration-resistant electrical connection.
Dimensional Matrix and Pitch Standards: Receptacle headers are engineered to perfectly mirror standard male pin layout dimensions:
  • Standard Linear Pitch: The center-to-center spacing between the internal socket cavities is most commonly an industry-standard 2.54 mm. More compact systems feature tighter sub-miniature grids like 2.00 mm or 1.27 mm.
  • Mating Compatibility: In the standard 2.54 mm pitch family, the internal sockets are precision-sized to accept standard 0.64 mm square male posts.
Array Configurations
  • Single-Row (1xN): A single horizontal line of entry sockets running parallel to the circuit board.
  • Dual-Row (2xN): Two horizontal rows of entry sockets stacked vertically. To translate this into a PCB footprint, the pins from the upper row are manufactured with longer, stepped 90° legs that jump over the lower row's pins, creating two distinct, staggered rows of solder tails on the PCB landing pad.
Header, Right Angle Shrouded
Header, Right Angle Shrouded: A male multi-pin board connector where the conductive pins are completely enclosed by a four-walled plastic protective casing (the shroud), with the solder tails bent at a sharp 90° angle.
This specific configuration allows external wire harnesses - such as IDC ribbon cables - to plug into the printed circuit board (PCB) parallel to the board surface. This design is heavily favored in space-constrained industrial systems, telecom gear, and computing mainboards to provide maximum mechanical stability and low vertical clearance.
Structural Anatomy of the Shroud (The "Box")
Unlike basic unshrouded headers where bare metal pins are fully exposed, the shrouded header surrounds its pins with a rigid, injection-molded rectangular plastic fortress:
  • Four-Wall Protection: The plastic wall physically safeguards the inner pins against accidental bending, dust, and electrical short-circuits caused by debris or loose wires.
  • The Polarization Slot (Notch): The center of one long outer wall features a vertical cutout or indentation channel. This slot matches a corresponding plastic key on the female cable socket, physically preventing the cable from being plugged in backwards.
  • Mating Windows: The interior floor of the shroud often features tiny slots or windows that help center and guide the female terminal contacts during blind mating cycles.
90° Lead Arrangement and PCB Seating
  • The Flat-Laying Profile: The main plastic shroud sits flat and horizontally directly against the top surface of the circuit board.
  • The Right-Angle Solder Tails: Rigid metal pins emerge from the inner back wall of the shroud, pass through the plastic base, bend exactly 90° downward, and plunge straight through the PCB's plated through-holes to be soldered underneath.
  • Standoff Bosses: The bottom face of the plastic frame features microscopic molded feet that raise the connector body roughly 0.50 mm off the circuit traces, ensuring cleaning solvents can clear out leftover manufacturing flux.
Dimensional Standards and Pitch Matrix: Right-angle shrouded headers adhere to precise, industry-standard grid layouts to ensure global cross-compatibility with external mating harnesses:
  • The Dominant 2.54 mm Matrix: In standard electronics (like 3M 3000 Series Box Headers), the pins are spaced at a 2.54 mm linear and row-to-row pitch. The individual posts are precision-cut 0.64 mm square metal wires.
  • Sub-Miniature Pitches: High-density modern computing hardware scales down to tighter standard grids, including 2.00 mm or 1.27 mm pitches.
  • Pin Counts: Sockets are overwhelmingly manufactured as dual-row (2xN) configurations hosting standardized even pin arrangements such as 10 (2 x 5), 14, 16, 20, 26, 34, 40, or 50 positions.
Specialized Retention Features: To prevent loose connections in heavy-machinery or high-vibration systems, the outer plastic housing can feature mechanical locking upgrades:
  • Ejector Latches (Long/Short Ears): Pivoting plastic mechanical arms are often molded onto the two short outer ends of the shroud. When the female connector is pressed inside, these ears click shut to lock it down. Pressing the tabs outward automatically ejects the cable without straining the wire.
  • Friction Lock Ramps: Smaller pitch headers (like the Molex Micro-Fit 3.0 Series) use an integrated clip ramp on top of the shroud that mechanically snaps into a flexible thumb latch on the wire housing.
Header, Vertical (All Types)
Header, Vertical (All Types): A straight pin header or male header strip) is a board-level connector featuring one or more parallel rows of rigid, completely straight metal pins held uniformly by a plastic insulating strip.
This component is structurally engineered to allow multi-wire cables, daughterboards, or test probes to plug into the printed circuit board (PCB) perpendicular (90°) to the board surface, standing straight up like a tiny metal fence.
Pin Anatomy and Plating: The component is constructed using solid, square-cut wire posts (typically brass or phosphor bronze) that are heavily plated with tin, gold, or selective gold-flashing on the mating tips. Each straight pin is physically divided into three zones by its plastic carrier:
  • The Solder Tail: The shorter end of the pin that passes down through the PCB's plated through-holes to be permanently soldered on the underside of the board.
  • The Insulator Zone: The middle section of the metal post that is press-fit tightly inside the plastic housing.
  • The Mating Post: The longer end of the pin that extends straight up into the air, serving as the active terminal that slides into a mating female wire harness or jumper.
  • High-Temperature Material: The pins are held in perfect alignment by a narrow, rigid strip of high-temperature thermoplastic (such as Nylon, PBT, or LCP) capable of withstanding wave soldering or manual iron heat without melting.
  • Breakaway Design (Unshrouded): On basic unshrouded versions, the plastic strip features small structural notches or score lines between each pin cavity. This allows assembly technicians to easily snap long 40-pin master strips down to any custom pin count needed (e.g., a 3-pin or 5-pin block) with their fingers or a pair of pliers.
Dimensional Standards and Pitch Matrix: Vertical post headers strictly follow standardized industrial grids to ensure universal compatibility with third-party jumper wires and test gear:
The Standard 2.54 mm Pitch: In the most dominant connector family, the center-to-center linear distance between pins is exactly 2.54 mm. Each metal post has a precise cross-sectional dimension of 0.64 mm square.
  • Sub-Miniature Grids: Compact consumer electronics utilize tighter standardized configurations, including 2.00 mm, 1.27 mm or 1.00 mm pitches, which feature significantly thinner, more fragile pins.
  • Single-Row (1xN): A single, straight line of vertical pins.
  • Dual-Row (2xN): Two identical parallel rows of vertical pins running side-by-side. The linear pitch and row-to-row spacing are identical (2.54 mm x 2.54 mm).
  • Three / Four-Row: Highly dense blocks used for specialized jumper matrices or legacy backplane systems.
Assembly and Mounting Features
  • Built-In Standoffs: The bottom face of the plastic insulator strip is molded with tiny feet or a raised channel. This creates a small gap between the plastic and the PCB surface, allowing manufacturing flux gases to escape during soldering and ensuring cleaning solvents can wash underneath.
  • Unshrouded vs. Shrouded: Unshrouded headers offer the lowest cost and smallest layout footprint but leave pins vulnerable to bending. Shrouded (box) versions enclose the vertical pins inside a four-walled plastic box with a keyway notch to prevent a cable from being plugged in backwards or shifted by one pin.
Mounting Hole
Mounting Hole: A precision mechanical feature integrated directly into the substrate of a printed circuit board. Unlike component through-holes, its primary function is structural, allowing screws, bolts, standoffs, or plastic rivets to securely anchor the PCB to an enclosure, chassis, or another circuit board.
Depending on grounding, shielding, and isolation requirements, mounting holes are strictly categorized into two physical styles: Plated (Grounded) and Non-Plated (Isolated). Plated could also include supporting vias.
Plated Mounting Holes (Grounded / Chassis Connections): Plated mounting holes provide simultaneous mechanical fastening and electrical conductivity. They connect the mounting hardware directly to the internal circuitry, typically for chassis grounding or shielding.
  • The Barrel: The interior wall of the drilled hole is chemically lined with a thin, continuous layer of electroplated copper, creating a conductive cylinder.
  • The Annular Ring Pad: A circular copper ring surrounds the hole on both the top and bottom layers of the PCB. This copper ring is left unmasked (bare metal without solder mask) and is plated with a surface finish like HASL, ENIG, or tin to provide a smooth, low-resistance contact plane for the screw head or metal standoff.
  • Stitching Vias (The "Via Corona"): High-reliability or high-frequency designs surround the main hole with a ring of smaller, tightly spaced via holes. This via corona "stitches" the top and bottom copper pads to internal ground planes, reinforcing the barrel against mechanical crushing forces and creating a robust, low-impedance path to shield against electromagnetic interference (EMI).
Non-Plated Mounting Holes (NPTH / Isolated): Non-plated mounting holes provide purely mechanical support with absolute electrical isolation.
  • The Barrel: The interior wall consists of raw, bare fiberglass substrate (FR-4) without any metal plating.
  • The Clearance Zone: To ensure the metal screw head, washer, or nut does not accidentally bite into nearby traces or cause an electrical short-circuit, a wide keep-out area is strictly enforced. Solder mask covers the surrounding area, and all copper traces, ground planes, and components are swept back outside the physical diameter of the fastening hardware.
Dimensional Standards and Layout Anatomy
Mounting holes scale precisely with standard industrial hardware fasteners (such as metric M-series or unified standard #UNC screws):
  • Drill Diameter: The actual physical hole is drilled slightly larger than the nominal screw size to provide structural clearance and accommodate manufacturing plating tolerances (an M3 screw typically uses a 3.20 mm or 3.50 mm drill hole).
  • The Keep-Out Area: This defines the total physical boundary reserved for the screw head or assembly tools (like a socket wrench or screwdriver tip). Circuit board designers must leave this circle entirely free of surface components to prevent a screwdriver from slipping and shearing off adjacent resistors or capacitors during enclosure assembly.
Specialized Variant: Slotted Mounting Holes: While standard mounting holes are perfectly circular, some high-stress or heavy-duty environments use elongated, oval-shaped slots:
  • The Slot Profile: A continuous oval channel routed into the board substrate.
  • Purpose: Slotted holes allow the PCB to slide or shift slightly along a single axis. This manual adjustment window accounts for real-world sheet metal manufacturing tolerances in large enclosures or accommodates thermal expansion and contraction in high-temperature operating environments.
Call us - 847-557-2300
