Surface Mount Component Families
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Surface Mount Component Families
Chips
Chips: An ultra-compact rectangular housing designed specifically for surface mount discrete passive or semiconductor devices containing exactly two electrical terminals. Electrical contacts are located at opposite ends of the body, wrapping around the edges to form metallized soldering pads. Most 2-pin passive chips are physically symmetrical, allowing automated pick-and-place systems to orient them easily without top-to-bottom or front-to-back errors. The body typically consists of a single block of ceramic (for capacitors), thick-film substrate (for resistors), or molded plastic/glass (for diodes).
Monolithic Structure: The body typically consists of a single block of ceramic (for capacitors), thick-film substrate (for resistors), or molded plastic/glass (for diodes).
Rectangular or Square End-Cap Terminations: Electrical contacts are located at opposite ends of the body, wrapping around the edges to form metallized soldering pads.
Symmetrical Design: Most 2-pin passive chips are physically symmetrical, allowing automated pick-and-place systems to orient them easily without top-to-bottom or front-to-back errors.
EIA: PDP-100
Chip Size Codes with Inch Dimensions
EIA Inch (IEC Metric)
Inch Dimensions
01005 (0402)
0.0157 in × 0.0079 in
0201 (0603)
0.024 in × 0.012 in
0402 (1005)
0.039 in × 0.020 in
0603 (1608)
0.063 in × 0.031 in
0805 (2012)
0.079 in × 0.049 in
1008 (2520)
0.098 in × 0.079 in
1206 (3216)
0.126 in × 0.063 in
1210 (3225)
0.126 in × 0.098 in
1806 (4516)
0.177 in × 0.063 in
1812 (4532)
0.180 in × 0.130 in
2010 (5025)
0.197 in × 0.098 in
2512 (6332)
0.250 in × 0.130 in
2920 (7451)
0.290 in × 0.200 in
Chip Size Codes with Metric Dimensions
IEC Metric (EIA Inch)
Metric Dimensions
0402 (01005)
0.40 mm × 0.20 mm
0603 (0201)
0.60 mm × 0.30 mm
1005 (0402)
1.00 mm × 0.50 mm
1608 (0603)
1.60 mm × 0.80 mm
2012 (0805)
2.00 mm × 1.25 mm
2520 (1008)
2.50 mm × 2.00 mm
3216 (1206)
3.20 mm × 1.60 mm
3225 (1210)
3.20 mm × 2.50 mm
4516 (1806)
4.50 mm × 1.60 mm
4532 (1812)
4.50 mm × 3.20 mm
5025 (2010)
5.00 mm × 2.50 mm
6332 (2512)
6.40 mm × 3.20 mm
7451 (2920)
7.40 mm × 5.10 mm
Performance & Manufacturing Challenges
Tombstoning Risk: Because these chips have only two terminals, an imbalance in surface tension during solder reflow can cause the component to lift off one pad and stand vertically like a tombstone. This is minimized by maintaining perfectly symmetrical landing pads and thermal reliefs.
Ultra-Low Parasitics: The absence of long lead wires reduces parasitic inductance and capacitance, making these packages ideal for high-speed signal integrity and high-frequency RF layouts.
High-Speed Placement: Their flat, symmetrical shapes make them highly optimized for automated vacuum pick-and-place nozzles, allowing assembly machines to shoot thousands of these components per minute.
Molded Body
Molded Body: Electronic component housings formed by encapsulating internal elements (such as a silicon die, a capacitor element, or a lead frame) in a solid, injection-molded thermoset plastic or epoxy resin. Unlike generic ceramic or open-frame structures, these packages provide an airtight, structurally rigid shield that safeguards components against moisture, physical impact, and operational vibration.
Inward L-Bend Lead: The leads curl tightly underneath the molded plastic shell. This saves valuable PCB area, though it hides the solder joints from easy optical inspection.
Heel and Toe Goals: IPC guidelines dictate robust calculation values for the Toe (outer edge) and Heel (inner edge) of the pad. These parameters ensure that the solder fillet achieves high mechanical joint strength.
Side Goal Omission: For many molded body components - specifically those utilizing Inward L-Bends - IPC standards omit a side-joint goal requirement. Adding extra pad width along the sides does not increase mechanical hold. Furthermore, excess side solder can cause the component to float or rotate out of alignment during the reflow oven cycle.
JEDEC: DO-214
Common Molded Body Tantalum Capacitors
EIA Size Code
Package Dimensions
KEMET Code
AVX Code
2012-12
2.00 x 1.30 x 1.20
R
R
3216-10
3.20 x 1.60 x 1.00
I
K
3216-12
3.20 x 1.60 x 1.20
S
S
3216-18
3.20 x 1.60 x 1.80
A
A
3528-12
3.50 x 2.80 x 1.20
T
T
3528-21
3.50 x 2.80 x 2.10
B
B
6032-15
6.00 x 3.20 x 1.50
U
W
6032-28
6.00 x 3.20 x 2.80
C
C
7260-38
7.30 x 6.00 x 3.80
E
V
7343-20
7.30 x 4.30 x 2.00
V
Y
7343-31
7.30 x 4.30 x 3.10
D
D
7343-43
7.30 x 4.30 x 4.30
X
E
Key Physical Features
  • Fully Encapsulated Core: Thermoset epoxy compound forms a solid protective layer on all sides, completely insulating the sensitive inner structures (such as silicon dies, wound wires, or sintered tantalum pellets) from environmental elements.
  • Integrated Polarity Markers: Because the body is formed in an injection-molding process, bevels, chamfered corner notches, or deep laser-etched bands are built directly into the plastic to indicate polarity (essential for diodes and tantalum caps).
  • Wrap-Around or Inward Terminations: Leads typically exit the bottom or centerline of the plastic molding and are bent flat against the body ends or tucked flush as leadless bottom contacts.
  • Classifications & Examples: Molded body packages use unique design rules and prefixes to accurately map their footprint requirements.
Tantalum Capacitors (CAPMP / EIA Standard): Features highly standardized molded packages categorized by standard uppercase lettering.
  • A Case (3216 Metric): 3.20 mm x 1.60 mm nominal
  • B Case (3528 Metric): 3.50 mm x 2.80 mm nominal
  • C Case (6032 Metric): 6.00 mm x 3.20 mm nominal
  • D Case (7343 Metric): 7.30 mm x 4.30 mm nominal
Diodes (DIOM / JEDEC DO-214): Molded discrete diodes leverage robust, wide wrap-around terminal feet built to absorb thermal stress.
  • SMA (DO-214AC): Smallest common molded diode variant
  • SMB (DO-214AA): Medium profile option
  • SMC (DO-214AB): Largest footprint format supporting high power surge ratings
Engineering Design Parameters: When laying out a footprint for a molded body part with Footprint Expert use distinct math models.
  • Molded Body Side Goal: Footprint generation tools use a unique variable known as the "Molded Body Side Goal" to ensure the copper landing pads extend far enough beyond the side boundaries of the plastic block, keeping the solder joint from bridging or starving.
  • Heel Fillet Compensation (Jh): Because molded leads often tuck close or underneath the plastic shell, the heel fillet calculations must account for package chamfering to prevent cold solder joints or component tilt.
  • Robust Placement Courtyard: Since the molding process can incur minor edge tolerances (+/-0.2 mm package deviations), the IPC placement courtyard boundary must be generous enough to account for physical variations during automated assembly pick-and-place tracking.
Performance Advantages
  • High Moisture Resistance: Direct plastic encapsulation eliminates internal air pockets, effectively blocking moisture ingress and saving parts from internal corrosion or short circuits.
  • Structural Resistance to Shock: The solid core cushions internal components from physical drops, heavy vibrations, and handling damage during rapid assembly lines.
  • Perfect Coplanarity Control: Flat molded bottoms provide a highly stable seating plane during reflow, significantly reducing defects like skewing or uneven floating.
  • Cost Efficiency: Plastic transfer molding remains the most affordable, mass-producible chip encapsulation method in modern electronics manufacturing
Metal Electrode Leadless Face (MELF)
Metal Electrode Leadless Face (MELF): A specialized surface mount component package characterized by a cylindrical body with metallized round end caps. Unlike standard rectangular chip components, MELF packages are round and do not use traditional leads. They are primarily used for high-reliability resistors, fuses and diodes where superior thermal stability, low noise, and excellent moisture resistance are required.
JEDEC: DO-213
Cylindrical Body: The housing is a glass or ceramic tube, making it highly resistant to thermal shock and moisture
Leadless Endcaps: Metal caps wrap around the circular edges on both ends, serving as the soldering terminals.
No Orientation Issues: Because it is perfectly round, the component can rotate along its long axis during placement without affecting its electrical connection.
Superior Reliability: MELF components offer exceptionally low failure rates and excellent long-term stability under harsh conditions.
High Thermal & Power Handling: The cylindrical shape provides a larger surface area than flat chips, allowing better heat dissipation and higher power ratings.
Low Noise & Parasitic: Excellent for high-frequency or high-precision circuits due to minimal structural inductance and capacitance.
Common MELF Package Sizes
Common Case Names
Size Code
Package Dimensions
MicroMelf (MMU)
0102
2.20 L x 1.10 Dia.
MiniMelf (MMA)
0204
3.60 L x 1.40 Dia.
Melf (MMB)
0207
5.80 L x 2.20 Dia.
Small Outline Diode (SOD) with Gullwing Leads
Small Outline Diode (SOD) with Gullwing Leads: A standard surface mount semiconductor package designed for discrete components like switching, Schottky, and Zener diodes.
JEDEC: DO-215
Lead Design: The "Gullwing" description means the metal leads bent downward and then outward.
Soldering & Assembly: These leads provide solid footing on the copper pads during assembly. They are ideal for automated pick-and-place and reflow soldering but are also large enough to allow for relatively easy hand soldering.
Package Variants: This package style comes in various standardized sizes to accommodate different thermal requirements and spatial limitations.
Common Applications Include: Smartphones and wearable devices, IoT modules and compact consumer electronics, Power supply circuits and automotive modules, LED lighting drivers and signal conditioning.
Common Small Outline Diode (SOD) Sizes
Case Code
Package Dimensions
SOD-123
3.68 mm x 1.17 mm x 1.60 mm
SOD-128
5.00 mm x 2.70 mm x 1.10 mm
SOD-323
1.70 mm x 1.25 mm x 0.95 mm
SOD-523
1.25 mm x 0.85 mm x 0.65 mm
SOD-723
1.40 mm x 0.60 mm x 0.59 mm
Small Outline Diode Flat Lead (SODFL)
Small Outline Diode Flat Lead (SODFL): A compact, ultra-low-profile surface mount technology (SMT) semiconductor housing designed to replace standard Gullwing SOD packages. By utilizing flat, folded metal ribbons that lie completely flush beneath the bottom of the device rather than curve outward, it maximizes board space, increases power handling, and significantly lowers the component profile.
JEDEC: DO-219, DO-221, DO-222
Core Advantages Over Gullwing Variants:
  • Space Saving: Eliminating extending Gullwing leads shrinks the necessary circuit board footprint. For example, an SOD-123FL serves as a direct drop-in replacement on existing pads but reduces physical component clearance.
  • Superior Thermal Performance: Because the flat leads are positioned directly underneath the component body, the heat dissipation path to the PCB copper pads is incredibly short. This design offers up to 25% lower thermal resistance compared to standard packages.
  • Ultra-Low Profile: These packages typically feature a maximum height profile of just 1.00 mm to 1.20 mm. This represents a profile reduction of 25% or more compared to traditional alternatives, making them ideal for high-density stack-ups.
  • Increased Surge Capacity: Many flat lead designs incorporate an internal clip-attach structure rather than fragile wire bonds. This structural change boosts transient forward surge-current survival.
Common Applications: The combination of enhanced thermal dissipation and minimized Z-axis height makes SODFL variants highly desirable for:
  • Portable Electronics: Ultra-thin smartphones, smartwatches, and portable power banks.
  • Power Conversion: Secondary rectification and freewheeling diodes in compact AC/DC or DC/DC converters.
  • Circuit Protection: High-efficiency Schottky rectifiers, Zener voltage stabilizers, and Transient Voltage Suppression (TVS) applications.
Capacitor, Aluminum Electrolytic (CAPAE)
Capacitor, Aluminum Electrolytic (CAPAE): A specialized housing used for components that provide high volumetric capacitance in a relatively compact space. Constructed by winding an anode foil, paper separators saturated with liquid electrolyte, and a cathode foil into a cylinder, these packages are polarized and feature distinct physical markers to indicate the negative terminal.
IEC: 60384-26
Unlike monolithic ceramic capacitors, these parts are housed in distinct mechanical form factors dictated by their mounting style, ripple current capability, and spatial constraints.
SMD aluminum electrolytic capacitors are typically packaged in cylindrical metallic aluminum "cans" sitting atop a square, black plastic insulating base. The base bends the terminal leads flat under the component body to create solder pads for reflow soldering.
Polarity Indicator: A highly visible black or dark colored crescent/stripe painted directly onto the top face of the metallic cylinder denotes the negative pad.
Common Aluminum Electrolytic Capacitor Sizes
Case Code
Diameter x Height
Common Values
A
4.00 mm x 5.40 mm
1uF to 10uF (50V)
B
5.00 mm x 5.40 mm
10uF to 22uF (35V)
C
6.30 mm x 5.40 mm
47uF to 100uF (16V)
D
6.30 mm x 7.70 mm
100uF to 22uF (25V)
F
8.00 mm x 10.20 mm
220uF to 470uF (35V)
G
10.0 mm x 10.20 mm
470uF to 1000uF (16V)
Crystals (XTAL)
Crystals (XTAL): A specialized, surface mount housing designed for passive timing components. Unlike multi-pin active oscillators that require separate power, a 2-pin crystal package only contains the raw quartz blank and two electrical terminals. It relies entirely on the microcontroller's internal inverter circuit to generate a clock signal.
Construction and Hermetic Sealing: Because quartz crystals are highly sensitive to moisture, dust, and atmospheric pressure changes, the packages utilize a hermetic (airtight) seal.
  • The Body: The base is typically constructed from a multi-layer technical ceramic material.
  • The Lid: A metal seam-welded lid or a glass-sealed ceramic lid covers the top. This metal lid is often grounded internally or externally to shield the sensitive crystal blank from Electromagnetic Interference.
SMD crystal packages are standardized by their physical length and width dimensions. The industry has shifted heavily toward smaller footprints to fit dense modern electronics.
Common SMD Crystal Packages
Case Code
Package Dimensions
L x W x H Range
Typical Uses
5032
5.0 x 3.2 x 1.0 -1.20 mm
Microcontrollers
3225
3.2 x 2.5 x 0.7 - 0.90 mm
Ease of Routing
2520
2.5 x 2.0 x 0.5 - 0.60 mm
loT Modules
2016
2.0 x 1.6 x 0.45 mm
Smartphones
Side Concave Packages 2-pin
Side Concave Packages: A surface mount electronic component housing where the electrical terminations or leads are recessed into indented, semicircular, or "scalloped" channels along the vertical sidewalls of the component body. Unlike standard convex component packages where leads protrude outward (like Gullwing leads) or flat surfaces, the concave architecture places the solderable terminals inside these inner grooves.
Assembly and Manufacturing Impact
  • Solder Joint Integrity: Early designs favored concave configurations under the assumption that isolating the paste within the inner channel would mitigate solder bridging. Modern automated optical inspection (AOI) data shows that the absolute spacing on the PCB pad layout dictates bridging protection far more than the concave shape itself.
  • No-Lead Visual Inspection: Certain modern variations of side concave packages overlap with side-wettable flanks seen in Dual Flat No-Lead (DFN) configurations. This recess allows solder paste to travel upward into the side groove, creating a visible fillet that validates a solid mechanical bond during high-speed assembly inspection.
Dual Flat No-Lead (DFN): A surface mount electronic component housing with a near-zero profile that replaces traditional extending leads with flat, metal contact pads on its underside.
JEDEC: MO-236. TO-276
Key Design and Structural Features
  • Bottom-Surface Pads: Electrical contacts sit flush with the bottom plastic mold compound, eliminating vulnerable, bendable pins.
  • Thermal Pad: Most DFN packages feature an exposed center metal pad that is soldered directly to the PCB to channel heat away from the silicon die.
  • Ultra-Low Profile: The compact design minimizes component height and weight, making it ideal for mobile devices and high-density boards.
  • Excellent Thermal Dissipation: The exposed center pad creates a direct thermal highway, allowing high power processing in a tiny footprint.
  • Low Parasitic Impedance: Eliminating long lead wires reduces internal resistance and inductance, enhancing high-frequency signal performance.
  • Cost-Efficient: The simplified lead frame design uses less raw material and is highly cost-effective to manufacture at scale.
Assembly and Inspection Challenges
  • Hidden Solder Joints: Because the connections sit underneath the package, traditional visual inspection cannot verify electrical connectivity or find voids.
  • Side-Wettable Flanks (SWF): Modern DFN variants feature a specialized cut or plating on the side edge of the pad. This allows solder to wick up the outer wall, creating a visible fillet for Automated Optical Inspection (AOI).
  • Solder Mask and Stencil Design: Precise stencil opening design is required for the thermal pad to prevent "floating," where excess solder lifts the component and prevents the perimeter signal pads from making contact.
Small Outline Transistor SOT23 (SOT Form Factor)
Small Outline Transistor SOT23 (SOT Form Factor): A highly popular, compact, plastic-molded surface mount device (SMD) package. Widely used for diodes, BJT transistors, MOSFETs, and voltage regulators, it features Gullwing leads extending from its two long sides and is favored for its space efficiency in modern electronics. Typically, 3 pins, though 5-pin (SOT23-5) and 6-pin (SOT23-6) variants are heavily used for small logic ICs and operational amplifiers. Because SOT-23 packages lack a dedicated thermal pad underneath, heat must be dissipated through the copper traces on the PCB. To optimize cooling, expand the copper connected to the pins (particularly the wider drain or collector pin).
JEDEC: TO-236; (SOT23-5): MO-178; (SOT23-6): MO-193
Gullwing SOT23 Type Form Factor Component Families
EIA
JEITA
Pin Pitch
Pin Qty
SOT23-3
SC59
0.95
3
SOT28
SC70-8
0.65
8
SOT323
SC70
0.65
3
SOT346
SC59A
0.95
3
SOT353
SC88A
0.65
5
SOT363
SC88
0.65
6
SOT416
SC75
0.50
3
SOT753
SC74A
0.95
5
Small Outline Transistor SOT143 (SOT)
Small Outline Transistor SOT143 (SOT): A low-profile, plastic surface mount package featuring four Gullwing leads. Derived directly from the standard SOT-23 geometry, it is uniquely characterized by having one lead that is visibly wider than the other three. This asymmetrical pin layout enforces a built-in reverse-polarity protection, making it a staple for high-frequency radio frequency (RF) transistors, Schottky/PIN diodes, TVS protection arrays, and voltage supervisor circuits.
JEDEC: TO-253, TO-261
PCB Design & Footprint Guidelines
  • Orientation Verification: Because of the asymmetrical fourth lead, CAD footprint library creation must map exactly to the manufacturer's pinout. The wider pad acts as an un-cloneable indicator for automatic vision-inspection and pick-and-place indexing.
  • RF Grounding & Thermal Benefits: The broadened lead is not just a layout guide; it dramatically drops package inductance. This provides an exceptionally clean ground path for RF designs. Furthermore, it serves as the package’s primary thermal conduit to the board, so pulling a substantial copper pour out from this wide pad is recommended.
  • Solder Bridging Risk: Although the side-to-side pitch is spacious, the end-to-end clearance requires exact solder mask dam tracking to prevent solder bridging across the small gaps
Small Outline Transistor SOT223 (SOT)
Small Outline Transistor SOT223 (SOT): A medium-power, plastic surface mount device package. It is widely chosen for discrete semiconductors and integrated circuits that require robust thermal handling in a compact layout, such as linear voltage regulators, power MOSFETs, and load switches.
JEDEC: TO-261
Key Physical Characteristics
  • Lead Configuration: It typically features four leads total: three standard Gullwing pins on one side of the body and one large, exposed tab on the opposite side.
  • The Thermal Tab: The large tab is mechanically and electrically continuous with the center pin (Pin 2). It provides a direct, low-resistance thermal path to conduct heat away from the silicon die into the PCB.
  • Body Dimensions: The main plastic body measures roughly 6.50 mm x 3.50 mm with an overall profile height of 1.65 mm. Including the leads, the total width span is approximately 7.00 mm.
  • Pin Pitch: The distance between the centers of the three adjacent pins is 2.30 mm for 4-pin and 1.50 mm for 5-pin and 1.27 for 6-pin.
PCB Footprint & Layout Guidelines
  • Thermal Management & Copper Pour: Because the package dissipates more power than smaller standard packages like the SOT-23, its performance relies heavily on your PCB layout.
    • Connect a large copper pour directly to the pad of the large thermal tab.
    • Drop a matrix of thermal vias into the tab pad to transfer heat to internal or bottom-side ground/power planes. Without adequate copper area, the component will overheat and trigger thermal throttling or fail prematurely.
  • Electrical Isolation Considerations: The large tab is typically tied to a specific net (often Vout or GND), depending on the component). Ensure that neighboring signal traces or component pads maintain safe electrical clearance from the enlarged copper pour surrounding this tab pad.
  • Soldering and Solder Mask: Because the pin pitch is a relatively wide 2.30 mm, the package is highly forgiving for both automated assembly line reflow ovens and manual prototyping hand-soldering. However, ensure your footprint includes a precise solder mask cutout for the thermal tab to prevent solder pooling from shifting the smaller pins out of alignment during reflow.
Small Outline Flat Lead (SOFL)
Small Outline Flat Lead (SOFL): A surface mount integrated circuit (IC) package characterized by a low-profile rectangular body and flat, non-extended leads rather than standard protruding Gullwing pins. It bridges the gap between traditional small outline packages (SOP/SOIC) and bottom-termination flat packs, providing a space-efficient layout tailored for tight vertical clearances and high-frequency, automated PCB assembly.
JEDEC: MO-293
  • Flat Lead Structure: The leads do not wrap or form distinct Gullwings. They lie flush against the underside or periphery of the device, which minimizes parasite inductance.
  • Dual-Sided Orientation: Pins or landing pads typically extend along two opposite sides of the rectangular body.
  • Low Profile: The "Flat" designation prioritizes a thin z-axis height, perfect for tight enclosures like laptops, memory modules, and portable smart devices.
  • Exposed Thermal Pad (Often Included): Many variations incorporate an internal die attach paddle exposed on the bottom side. This pad solders directly to the PCB to conduct heat away efficiently.
Design Parameters
When creating an IPC-7351 standardized footprint for an SOFL package, engineers focus on several specific features:
  • Pitch: Typically ranges between 0.50 mm to 1.00 mm depending on the subcategory variant.
  • Pads: Footprints require flat, rectangular SMD copper pads.
  • Solder Mask: Non-Solder Mask Defined (NSMD) pads are preferred to guarantee high registration accuracy.
  • High Signal Integrity: Shorter, flatter leads drastically lower parasitic capacitance and inductance, making them superior for high-speed switching applications.
  • Excellent Heat Dissipation: Direct bottom-pad soldering turns the PCB's ground planes into large heat sinks via thermal vias.
  • Space Efficiency: Frees up vertical height and tighter pitch allows dense layout clustering.
DPAK
DPAK: A standard surface mount transistor package designed for high-power semiconductor devices. It features a large metal tab that solders directly to the PCB to dissipate heat. It is widely used for voltage regulators, MOSFETs, and power diodes.
JEDEC: MO-169, MO-235, MO-306, TO-251, TO-252, TO-268
  • Thermal Tab: A large metal backside tab acting as the primary drain/collector connection and heat sink.
  • Three-Terminal Layout: Typically features two smaller leads and one large clipped lead or tab.
  • Surface Mount Design: Eliminates the need for through-holes, speeding up automated assembly.
Design Parameters
  • Lead Pitch: Standard distance between the smaller pins is 2.30 mm (0.090 inches).
  • Thermal Vias: Footprints require an array of vias under the tab to transfer heat to internal copper layers.
  • Solder Paste Stencil: The large tab pad requires a windowpane stencil pattern to prevent component floating and solder splattering.
  • High Power Handling: Safely manages higher currents and voltages than standard small-outline packages.
  • Low Thermal Resistance: Direct copper-to-copper bonding ensures rapid heat transfer away from the silicon die.
  • Robust Mechanics: The large soldered surface area provides high mechanical stability against vibration.
Manufacturer Recommended Pattern
Component manufacturers do not provide a reference dimension that links their recommended pattern to the physical package. You can create the pattern in the CAD tool, but you cannot accurately add the drafting outlines for silkscreen, assembly, component, terminal, and courtyard without a reference dimension between the physical package and the recommended solder pattern.
Oscillator, J-Lead (OSCJ)
Oscillator, J-Lead (OSCJ): A surface mount, plastic-molded enclosure specifically designed for crystal oscillators, clock generators, and frequency control devices. It adapts the traditional Small Outline J-Lead (SOJ) format into a 4-pin or 6-pin specialized housing, featuring pins that curl downward and inward beneath the device body resembling the letter "J". This configuration provides an alternative to standard leadless ceramic packages (LCC) by adding robust mechanical flexing capabilities to critical timing circuits.
  • Inward-Curled J-Leads: Unlike protruding Gullwing leads that extend outward, J-leads tuck directly under the plastic body. This structural choice saves significant board real estate over standard SOIC components.
  • Plastic Molded Body: Typically features a rugged, molded plastic encapsulation housing the quartz crystal blank and its active oscillation IC circuitry.
  • Standardized Pinouts: Usually configured as a 4-pin or 6-pin module. In a standard 4-pin configuration, the pinouts follow this layout:
    • Pin 1: Tri-State Enable/Disable or No Connect
    • Pin 2: Ground (GND)
    • Pin 3: Output Frequency Clock
    • Pin 4: Supply Voltage (VDD)
Design Parameters
When laying out a footprint for an OSCJ component on a board, designers prioritize the following IPC-compliant geometries:
  • Footprint Pads: The copper pads must extend slightly outward and inward relative to the J-lead apex to guarantee a proper solder fillet formation along both the inner and outer curve of the lead.
  • Pitch: Large-form plastic OSCJ packages typically leverage a generous lead pitch, commonly at 2.54 mm or 5.08 mm, ensuring high electrical isolation between high-frequency outputs and supply traces.
  • Common Dimensions: These packages are usually larger than modern ceramic variants, with a popular historical standard footprint measuring roughly 14.00 mm x 9.8 mm.
  • Thermal & Shock Compliance: The J-lead structure functions like a miniature spring. This flexibility absorbs mechanical shock, vibration, and Coefficient of Thermal Expansion (CTE) mismatches better than rigid, leadless ceramic packaging.
  • Solder Joint Visual Inspection: Because the J-lead curls along the outer side of the body, the solder heel and toe fillets remain visibly accessible for automated optical inspection (AOI).
  • High Pre-Solder Resiliency: The tucked lead geometry keeps the component leads protected from accidental bending or misalignment during shipping, tape-and-reel feeding, or handling prior to reflow.
Oscillator, L-Lead (OSCL)
Oscillator, L-Lead (OSCL): A surface mount enclosure designed for quartz crystal oscillators and clock generators. It features L-shaped leads that extend outward and bend downward to form a flat seating plane flush with the PCB surface. This geometry mimics a standard Gullwing style but is specialized for the weight, height, and frequency constraints of surface mount timing modules.
  • Outward-Extended L-Leads: Leads protrude from the sides of the package and bend downward and outward, forming an "L" shape.
  • Highly Visible Solder Fillets: The extended foot of the "L" lead sits entirely outside the component body outline, allowing for straightforward automated visual inspection.
  • 4-Pin or 6-Pin Layout: Typically follows standard oscillator pin configurations (VDD), Ground, Output, and Enable/Disable).
Design Parameters
  • Footprint Pad Extension: Footprints require a longer pad length extending beyond the lead tip (toe) to ensure a strong solder fillet.
  • Pitch Standards: Typically features a standard pitch of 2.54 mm or 1.27 mm for robust isolation of high-frequency clock signals.
  • Coplanarity: Requires strict lead coplanarity tolerance (usually within 0.10 mm) to ensure all L-feet sit perfectly flat on the solder paste during reflow.
  • Superior Solder Joint Inspection: Unlike leadless (LCC) or J-lead variants, the entire solder joint is fully visible from above, making it highly compatible with basic Automated Optical Inspection (AOI) systems.
  • Excellent Mechanical Reworkability: The exposed outward leads make it one of the easiest oscillator packages to rework, manually desolder, or probe during debugging.
  • Stress Relief: The bend in the L-lead provides mild compliance, absorbing physical board flex and thermal expansion stresses better than leadless ceramic packages.
Oscillator, Corner Concave (OSCCC)
Oscillator, Corner Concave (OSCCC): A standardized, surface mount ceramic or plastic packaging format designed specifically for highly miniaturized crystal oscillators and clock generators. Rather than using extended metal leads like J-leads or Gullwing pins, an OSCCC package utilizes castellated solder pads recessed directly into the vertical corners of the component's body. This design maximizes component density on dense circuit boards while ensuring robust high-frequency electrical isolation.
  • Corner Castellations (Concave Terminals): Solder contacts form semi-cylindrical metallized grooves or scallops on the outermost four corners of the device. Solder wicks up these inner vertical channels during reflow.
  • Leadless Profile: The total absence of outward-extending leads eliminates risk of bent pins, ensuring a completely flat bottom seating plane.
  • Hermetically Sealed Body: Usually constructed with a ceramic substrate capped by a metal lid to insulate the sensitive internal quartz resonator or MEMS core from atmospheric moisture and environmental aging.
  • Standard 4-Pin Output: The classic corner configuration natively routes the standard 4-pin functional diagram:
    • Corner 1: Tri-state Control / Enable / No Connect
    • Corner 2: Ground (GND)
    • Corner 3: Frequency Output Clock Signal
    • Corner 4: Supply Voltage (Vpp)
  • Pad Geometry: PCB landing pads are placed directly underneath each corner. They must extend slightly outward beyond the component perimeter to accommodate the side solder fillet.
  • Silkscreen Expansion: Because the metal pads occupy the actual corners of the rectangular body, layout engineers must provide an expanded or modified silkscreen outline to ensure the component outline remains visible during manual inspection.
  • Pin 1 Indicator: Due to tightly packed corner spaces, standard circular silkscreen dots may conflict with the copper pads; specialized footprint rules apply to shift the Pin 1 indicator clear of the solder joints.
  • Ultra-Low Parasitic Inductance: The direct corner contact pathway eliminates the inductive loop area inherent to long J-leads or L-leads, preserving signal integrity for high-speed GHz-range clock signals.
  • Excellent Solder Fillet Inspection: Because the metallized contact curves up the vertical outer corner edge, inspection cameras can verify a robust, shiny solder joint heel from the side via Automated Optical Inspection (AOI).
  • Maximum Density Space Savings: Features one of the smallest package envelopes available for clock circuits, saving substantial PCB space compared to plastic-molded leaded components.
  • Self-Alignment: Surface tension from the molten solder paste pulls the corner cutouts uniformly onto the target footprints during reflow oven cycles, minimizing skewing or rotational placement errors.
Oscillator, Side Concave (OSCSC)
Oscillator, Side Concave (OSCSC): A standardized, surface mount ceramic or plastic packaging format for quartz crystal oscillators and clock generators. It features castellated solder pads recessed into the flat side edges of the component's body rather than the corners. This design offers a compact, leadless layout that optimizes trace routing and signal path isolation.
  • Side Castellations (Concave Terminals): Semi-cylindrical, metallized grooves are located along the long or short side edges of the rectangular housing. Solder wicks up these inner vertical channels during reflow.
  • Leadless Profile: The absence of protruding metal pins eliminates the risk of bent leads, providing a completely flat underside seating plane.
  • Hermetically Sealed Substrate: Constructed with a rugged ceramic body and a metal lid to protect the internal quartz or MEMS resonator from mechanical stress and moisture.
IPC Footprint & Design Parameters
According to IPC-7351B package standards, the naming format follows OSCSC + Length × Width × Height - Pin Count:
  • Pad Geometry: PCB land pads are positioned flush with the side walls of the oscillator. Pads must extend outward slightly past the package edge to allow a visible side solder fillet to form.
  • Signal Isolation: Placing pads on the sides keeps the component corners clear, allowing routing traces or ground shield fills to pass cleanly around the corners of the component body.
  • Pin 1 Orientation: Because the pads sit mid-side, the package corners are ideal for clear silkscreen dots or chamfered edges to mark Pin 1.
  • Minimized Parasitic Inductance: Short, leadless contact paths minimize inductive loops, ensuring stable performance for high-frequency clock signals.
  • Side-Fillet Optical Inspection: Solder wicks into the side concave channels, allowing easy verification of a robust joint via Automated Optical Inspection (AOI).
  • Self-Alignment: Surface tension from molten solder draws the side castellations symmetrically onto the PCB land pads, reducing component rotation or shifting during reflow.
  • Board Space Efficiency: Offers a very tight, low-profile footprint ideal for dense hardware layouts like telecommunication modules, networking cards, and single-board computers.
Side Concave (4-Pin) Diode and LED
Side Concave (4-Pin) Diode and LED: A specialized, leadless surface mount footprint standard defined by IPC-7351. Instead of utilizing standard peripheral leads or bottom pads, this package features four metallized semi-cylindrical cutouts (castellated grooves) recessed symmetrically into the side walls of its ceramic or epoxy body. It is primarily implemented for multi-diode arrays and multi-color RGB LEDs, where vertical board profile, trace isolation, and optical inspection are paramount.
  • Side-Wall Castellations: The electrical contacts curve upward along the vertical perimeter, creating a concave indentation on the left and right sides.
  • Low-Profile Leadless Structure: Eliminating outward-facing pins lowers the package clearance, saving surface space and preventing accidental lead bending or damage during automatic component picking.
  • Polarized Geometries: Components utilize an uneven chamfered corner, a molded notch, or an offset keyway pin configuration to denote diode cathode placement and prevent reverse assembly orientation.
Common Electrical Configurations
Because this package format breakout provides four distinct terminal points, it typically services two component families:
  • Multi-Color (RGB) LEDs: Houses a shared internal node alongside separate color dies. Semicustom variants break out as either a Common Anode configuration (one positive terminal, three separate color cathodes) or a Common Cathode configuration.
  • Integrated Diode Bridges / Arrays: Integrates a series of four independent rectifier diodes or protection Zeners mapped in a single network (e.g., standard full-wave bridge rectifier or multi-channel ESD clamping array).
Footprint & PCB Layout Parameters
When defining this component footprint inside CAD suites like Altium Designer or IPC Footprint Expert, engineering rules mandate precise layout specs:
  • Pad Extension (Toe Out): PCB land copper must extend beyond the physical side walls of the device housing. This ensures molten solder paste wicks upward into the semicircular channel, generating a visible heel fillet.
  • Solder Mask Openings: Footprints require Non-Solder Mask Defined (NSMD) clearances around the side terminals to prevent masking material from encroaching into the castellated pocket, which could cause cold-joint connectivity failure.
  • Clearance Routing: By keeping the outer corners of the rectangular component body free of metallic terminals, designers can safely route signal traces or drop ground via anchors right up against the corners of the housing envelope without risk of short-circuiting.
  • Robust Optical Inspection (AOI): Automated optical cameras can easily view the solder fillet ascending the vertical side channel from a top-down or slight-angle camera perspective, an option missing from under-body LGA packages.
  • Self-Centering Properties: During the reflow oven process, liquid surface tension pulling on all four concave pockets naturally realigns the chip center directly onto the target pads, reducing rotational skewing or floating.
  • Low Parasitic Loop Inductance: Shorter internal lead pathways significantly minimize high-frequency parasitics, allowing protection diodes to react to high-speed transients rapidly.
Side Flat Chip Array
Side Flat Chip Array: A surface mount passive component housing that integrates a matrix of multiple discrete components – such as resistors or capacitors - into a single leadless chip utilizing flat perimeter terminations. Unlike side concave chip arrays which use semi-cylindrical scalloped indentations (castellations), a side flat array features flat, continuous rectangular metal bands wrapped symmetrically around the sides of its body. This design creates a smooth, straight-edged perimeter optimized for precise component placement, highly predictable solder joint geometry, and dense layout clustering.
  • Flat Peripheral Terminations: The electrical contacts consist of smooth, flat metallized bands that do not feature any scallops, curves, or indentations. They sit completely flush against the smooth outer vertical edges of the array housing.
  • Monolithic Ceramic Body: Fabricated using a singular co-fired ceramic block (such as alumina), which isolates the internal resistive elements or capacitive layers from one another.
  • Symmetrical Layout Pinouts: Commonly deployed in 4-pin (2-isolated elements) or 8-pin (4-isolated elements) arrays, splitting the terminations evenly along the two opposing long sides of the chip.
Footprint & Naming Parameters
According to the IPC-7351 standard footprints, flat chip arrays follow a dedicated naming convention:
  • Standard Code: Flat component arrays utilize the CAPAF (Capacitor Array, Flat) or RESAF (Resistor Array, Flat) prefixes followed by pitch and mechanical dimensions (RESRAF + Pin Count + P Pitch + Length x Width x Height + L Lead Width x Lead Length).
  • Predictable Toe Fillets: Because the pads are flat and uniform, calculating the mathematical footprint model requires less toe protrusion (Jt) relative to concave packages, yielding minor space savings along the outer perimeter.
  • Narrow Solder Mask Dams: Precise placement of solder mask web dams between the closely packed adjacent flat pads is crucial to block any solder bridging between the individual resistor/capacitor networks during high-temperature reflow.
Side Concave Chip Array
Side Concave Chip Array: A surface mount passive component housing that integrates a matrix of multiple discrete components - such as resistors or capacitors - into a single leadless chip. Rather than using protruding pins or flat bottom pads, it features multiple semi-cylindrical metallized grooves (castellations) recessed into its side walls. This format effectively places multiple independent components side-by-side in a single structural body to maximize assembly density and efficiency.
  • Serrated Side Castellations: The left and right perimeter edges look like scallops or waves. The electrical terminations run up these vertical indentations, creating separate isolated contact pathways.
  • Monolithic Rectangular Body: Constructed from a single piece of high-grade ceramic (co-fired alumina) or glass-epoxy material. This body isolates the internal passive elements from one another.
  • Even Pin Distributions: Most commonly deployed in 4-pin (2-element), 8-pin (4-element), or 16-pin (8-element) configurations, with the contacts split symmetrically on opposite long sides.
These packages follow a precise naming structure to describe their physical boundaries, using the format RESCAV + Pin Count + P + Pitch _ Length x Width x Height + L Lead Width x Lead Length.
Example: RESCAV8P127_500X200X70L40X80
  • Pitch-Driven Layout: The spacing between the centers of adjacent side concave pads is tightly controlled, typically standardizing at 0.50 mm or 0.80 mm.
  • Toe Pad Extension: PCB landing pads must extend outward beyond the physical perimeter of the ceramic body to ensure the solder forms a strong, rising vertical joint.
  • Solder Mask Dams: Pocket clearances must have precise mask dams between the closely packed side-by-side pads to prevent solder bridging during reflow.
Performance & Manufacturing Advantages
  • High Packing Density: Combines up to eight individual resistors or capacitors into a single physical component footprint, saving significant board space over discrete layout methods.
  • Excellent Solder Fillet Visibility: Solder naturally wicks up the side-wall concavities. This creates clear, visible fillets that are easily verified by Automated Optical Inspection (AOI) systems.
  • Anti-Tombstoning: Small individual 0201 or 0402 discrete passives frequently stand up on one end during reflow (tombstoning) due to unbalanced solder forces. The larger, heavier monolithic body of a chip array completely eliminates this assembly defect.
  • Trace Routing Paths: Because the terminations are confined strictly to the sides, the space underneath the array and around its outer corners remains completely clear, providing valuable routing room for underlying circuit traces.
Convex Chip Array
Convex Chip Array: A surface mount passive component housing that integrates a matrix of multiple discrete components (most commonly resistors) into a single leadless chip utilizing outward-protruding (convex) terminal pads. Unlike side concave chip arrays that feature semi-cylindrical recessed scallops, a convex array features smooth, bumps or lobes that extend outward beyond the main ceramic body line. It is the most ubiquitous, standard design format for high-volume resistor networks, digital bus pull-ups, and parallel damping terminations.
  • Outward-Bending (Convex) Leads: The individual terminations are 5-sided blocks that bulge slightly outward from the chip side walls, optimizing contact area.
  • Larger Corner Terminations: For most industry-standard convex packages, the four outermost corner pads are manufactured physically wider than the inner terminal pairs to anchor the component securely.
  • Monolithic Ceramic Structure: Built on a shared high-purity alumina ceramic base substrate. Multiple independent resistive element paths are laser-trimmed and covered under a protective epoxy overcoat glass layer.
  • Pin Formats: Symmetrically split along opposite long sides, most frequently deployed in 4-pin (2-element), 8-pin (4-element), or 16-pin (8-element) packages.
Footprint parameters, convex packages follow a strict naming structure to properly generate standard library footprints:
  • Standard Prefixes: Uses CRAC (Capacitor Array, Convex) or RESC (Resistor Array, Convex) followed by pitch and dimensions:
    • RESCAX + Pin Count + P Pitch _ Length x Width x Height + L Lead Width x Lead Length.
    • Example: RESCAXS10P64_330X210X70L45X35
  • Asymmetrical Solder Pads: Because the component corner pins are wider than the inner pins, the CAD footprint must feature custom, wider corner pads relative to the inner pairs. Switching a PCB layout from a concave part to a convex part always mandates a solder pad re-spin.
  • Standard Spacing (Pitch): Typically engineered on a precise 0.50 mm or 0.80 mm center-to-center lead pitch to align perfectly with automated SMT placement grids.
Small Outline Package (SOP/SOIC)
Small Outline Package (SOIC/SOP): A rectangular plastic body with Gullwing leads extending outward from its two longer sides. It originally replaced bulky through-hole DIP (Dual In-line Package) components by shrinking the footprint area and vertical height by up to 70%.
SOP JEDEC: MO-117, MO-118, MO-142, MO-152, MO-153, MO-180, MO-182, MO-230, MO-249, MO-271
SOIC JEDEC: MO-046, MO-059, MO-099, MO-119, MO-120, MO-132, MO-135, MO-137, MO-150, MO-154, MO-164, MO-174, MS-012, MS-013, MS-024, MS-025
  • Gullwing Leads: Metal pins extend out from the long edges of the package and bend downward and outward, forming a shape like a gull's wing.
  • Dual-Sided Pinout: Terminations are arranged symmetrically on opposite sides of the component body, typically numbering from 8 pins up to 64 pins.
  • Plastic Encapsulated Body: Standard configurations utilize a rugged, flame-retardant molded epoxy resin to insulate the internal silicon die.
  • Pin 1 Identification: A chamfered (beveled) edge on the body, a deep notch at one end, or a laser-etched dot indicates Pin 1 location.
Body Width Variations: SOIC packages are categorized primarily by their body width (measured across the plastic body, excluding the leads). Using the wrong width in your footprint design will prevent the component legs from touching the copper pads:
  • Narrow Body (3.90 mm): Commonly used for lower pin counts, such as 8-pin, 14-pin, and 16-pin devices (e.g., standard logic gates, op-amps).
  • Wide Body (7.50 mm): Typically used for higher pin counts or high-voltage chips, such as 20-pin, 24-pin, and 28-pin devices (e.g., microcontrollers, transceiver chips).
Standard small outline footprints follow the naming format:
  • SOIC or SOP + Pin Count + P Pitch _ Body Length x Lead-Span x Height + L Lead Width x Lead Length
  • (where Lead-Span is the tip-to-tip distance across the extended legs).
  • Example: SOP24P50_650X640X120L60X22
  • SOIC Standard Pin Pitch: The center-to-center distance between adjacent pins is universally standardized at 1.27 mm. This was the original SO package in the 1980s.
  • SOP Standard Pin Pitch: The center-to-center distance between adjacent pins is universally standardized at 0.80 mm, 0.65 mm, 0.50 mm and 0.40 mm
  • Pad Extension (Toe, Heel, and Side): PCB landing pads must extend beyond the physical footprint of the Gullwing tip to allow a prominent solder meniscus to climb the outer face of the lead.
  • Thermal Pad Variant (SOIC-EP): High-power variations include an Exposed Pad (EP) on the underside. This bottom pad requires a large ground-plane copper pad on the PCB filled with thermal vias to conduct heat away.
  • High Reflow Reliability: The mechanical flexibility of Gullwing leads acts as a suspension system, absorbing board flexing and CTE (thermal expansion) stresses without fracturing the solder joints.
  • Straightforward Inspection & Repair: Because the pins protrude completely outside the component body, solder joints are 100% visible to standard Automated Optical Inspection (AOI) and can be easily hand-soldered or reworked with a standard soldering iron.
  • Excellent Automated Handling: The flat top surface and rigid, widely spaced pins make it ideal for vacuum pick-and-place nozzles, ensuring fast assembly speeds and low rejection rates.
Small Outline J-Lead (SOJ): A rectangular, plastic-molded surface mount integrated circuit (IC) package characterized by two parallel rows of pins that curve inward underneath the chip body into a distinctive "J" shape. This design allows the component to occupy roughly 30% to 50% less board space than traditional Dual In-line Packages (DIP). It provides an incredibly robust, mechanically resilient option for high-density electronic designs. Historically, the package found its primary utilization housing high-speed memory devices.
JEDEC: MO-063, MO-065, MO-077, MO-088, MO-091, O-105, MO-121, MO-123, MO-124, MO-147, MO-165, MO-181, MS-023, MS-027
Key Mechanical & Technical Specifications
  • Lead Pitch: Typically standardized at 1.27 mm between pin centers.
  • Body Widths: Most common JEDEC-compliant standards specify 7.50 mm and 10.20 mm body widths.
  • Pin Counts: Ranges broadly depending on memory architecture, typically spanning 16 to 40 pins.
  • Lead Arrangement: Terminals protrude exclusively from the two longer parallel edges of the component.
Core Structural Advantages
  • Mechanical Durability & Handling: Unlike Gullwing packages (such as the standard SOIC), the inward-folded J-leads offer exceptional bending resilience. The component can withstand aggressive automated handling, feeding tubes, and drop impacts without the leads deforming.
  • Optimized Space Efficiency: Because the leads tuck directly beneath the plastic body rather than extending outward, the total PCB footprint area is minimized. This layout frees up critical space on dense printed circuit boards.
Thermal Stress Absorption: The structural curvature of a J-lead acts as a microscopic spring. During severe thermal cycling, the leads flex to absorb differential thermal expansion stresses between the plastic package and the epoxy PCB substrate, protecting solder joints from cracking.
Architectural Variations: While the standard SOJ outlines remain fixed, minor application variations exist across the semiconductor landscape:
  • SOIJ (Small Outline Insulated J-Lead): Often used interchangeably with SOJ, occasionally referencing specific Japanese EIAJ dimension configurations.
  • High-Density Modules: Custom SOJ variants like the 42-lead package were actively registered by JEDEC to accommodate expanding memory address buses.
Modern Industry Context: While highly successful through the late 1980s and 1990s, the SOJ package is rarely selected for modern, cutting-edge system designs today. High-density electronics have largely transitioned to Ball Grid Array (BGA) and ultra-thin, fine-pitch packages satisfy the demand for hundreds of interconnected pins in ultra-slim form factors. However, SOJ components remain vital in legacy aerospace systems, industrial automation replacements, and retro-computing hardware upkeep.
Small Outline No-lead (SON)
Small Outline No-lead (SON): A highly compact, low-profile plastic surface mount integrated circuit (IC) package characterized by the absence of traditional protruding Gullwing or J-shaped leads. Instead, electrical contacts are established via metallized terminal pads located on the underside perimeter, completely flush with the bottom surface of the component body. Because contacts are arranged exclusively along two opposite parallel edges, it differentiates itself from the four-sided Quad Flat No-lead (QFN) format. It is also widely designated across the semiconductor industry as a Dual Flat No-lead (DFN) package by some component manufacturers.
JEDEC: MO-196, MO-197, MO-229, MO-232, MO-240, MO-245
  • Fine Lead Pitch: Typically standardized at narrow spacings ranging from 0.40 mm to 0.50 mm, though variants expand up to 0.90 mm.
  • Ultra-Thin Profile: Standard seated heights average around 0.85 mm, with ultra-thin configurations shrinking down to a mere 0.35 mm.
  • Pin Density: Commonly deployed for smaller pin-count components, scaling tightly from 4 to 72 pins in specialized rows.
  • Thermal Enhancements: Usually incorporates a large central Exposed Pad (EP) on the package base to function as a primary heat sink.
Performance & Structural Advantages
  • Superior Thermal Dissipation: The central exposed copper die-pad is soldered directly onto the PCB’s thermal land. This eliminates the thermal barrier of encapsulated plastic, letting heat flow seamlessly through plated thermal vias into internal PCB ground planes.
  • High-Frequency Electrical Signal Integrity: Eliminating long, external lead wires massively lowers parasitic inductance, resistance, and capacitance. Consequently, SON components demonstrate clean signal performance, making them ideal for high-speed RF, wireless, and power conversion applications.
  • Drastic Space Savings: By pulling the terminal contacts entirely under the body, the required PCB footprint shrinks significantly compared to standard SOICs. This yields high-density component clustering on complex boards.
Critical PCB Footprint & Design Guidelines: Designing a footprint for fine-pitch SON packages demands strict attention to assembly tolerances:
  • Solder Joint Filleting: Extend the copper land pads 0.40 mm to 0.50 mm beyond the package body perimeter (toe length). This provides proper solder paste wetting and allows for automatic optical inspection (AOI) verification.
  • Bridging Prevention: For standard 0.50 mm pitch devices, restrict the PCB pad width to 0.28 mm or narrower. This guarantees that a solder mask web can fit safely between individual pads, preventing manufacturing shorts.
  • Thermal Pad Segmentation: Avoid pasting a giant solid block of solder over the center exposed pad. Split the stencil aperture into a segmented grid pattern (covering 40% to 80% total area). This lets volatile flux gases escape during reflow, preventing the component from lifting or creating excessive voiding.
Pull-back Small Outline No-lead (PSON)
Pull-back Small Outline No-lead (PSON): A highly specialized variant of the standard Small Outline No-lead (SON) footprint where the metallized terminal pads are deliberately recessed (pulled back) away from the outer edges of the plastic mold body. Because the electrical contacts do not reach the side walls of the IC, the molded plastic encapsulation completely encloses the outer perimeter. This structural design maximizes board routing space, reduces the risk of accidental electrical shorting, and eliminates visible external solder fillets. Component manufacturers frequently label this package family as PSON or Plastic Small Outline No-lead.
JEDEC: MO-209, MO-252
The "Pull-back" Mechanism Explained: In a standard SON or DFN/QFN package, the copper lead-frame terminal pads are cut during the singulation process, leaving exposed raw copper edges on the sides of the chip. In contrast, a PSON package pulls the terminal ends inward.
  • Recess Distance (Pull-back): Terminal pads are typically shifted inward by 0.075 mm to 0.15 mm from the nominal package outline.
  • Lead Pitch: Maintained at standard fine-pitch intervals of 0.50 mm or 0.65 mm.
  • Low Profile: Height dimensions mirror thin variants, frequently standardizing around 0.75 mm to 0.85 mm.
  • Thermal Interface: Incorporates a large central exposed die pad to ensure low thermal resistance.
Architectural Benefits & Engineering Trade-offs
  • Creepage and Clearance Advantages: By burying the conductive terminal pads underneath the insulating plastic body, PSON packages drastically improve creepage and clearance distances between adjacent traces on high-density layouts. This makes them popular for compact power management ICs (PMICs) and low-voltage switching regulators.
  • Reduced Perimeter Footprint: Because the pads do not extend to the edge, PCB designers can bring peripheral components, ground fills, or trace routing closer to the IC boundary without violating safety clearances.
  • Inspection Challenges (The Solder Fillet Trade-off): During surface mount technology (SMT) reflow, the hidden pads prevent the formation of an external side solder fillet. Because there is no visible side wetting, Automatic Optical Inspection (AOI) systems cannot verify the joint integrity by looking at the perimeter. Electronics manufacturers must rely on Automated X-Ray Inspection (AXI) to guarantee that the hidden pads are properly wetted.
PCB Design & Stencil Requirements: Creating a reliable footprint configuration for a PSON package requires specific modifications to your IPC-compliant CAD library:
  • Pad Inward Extension: Unlike standard SON packages where pads extend outward to form a toe fillet, PSON footprints require the copper pads to expand slightly inward toward the center thermal pad to guarantee sufficient contact area.
  • Solder Mask Webbing: Due to the pulled-back contacts, maintain a strict solder-mask-defined (SMD) or non-solder-mask-defined (NSMD) trace boundary based on the manufacturer datasheet to prevent molten paste from migrating out from under the chip.
  • Aperture Design: Stencils should use a reduced thickness (typically 0.125 mm) with trapezoidal laser-cut walls to maximize paste release on the small, recessed footprints.
Ceramic Flat Package (CFP)
Ceramic Flat Package (CFP): A highly specialized, hermetically sealed surface mount integrated circuit (IC) package utilized almost exclusively in military, aerospace, and high-reliability deep-space electronics. It features a ceramic base and lid bonded together with parallel rows of thin metal ribbons or Gullwing leads extending from its sides. Unlike commercial plastic packages, the CFP provides total immunity to moisture ingress, chemical corrosion, and intense radiation fields, making it the industry benchmark for operating in extreme, unforgiving environments.
JEDEC: MO-018, MO-020, MO-021, MO-022, MO-023, MO-032, MO-070, MO-092, MO-098, MO-106, MO-115, MO-146, MS-033
  • Hermetic Construction: Utilizes high-purity aluminum oxide ceramic bodies co-fired with tungsten or gold-plated Kovar metal configurations.
  • Lead Pitches: Typically features standard fine-pitch spacings of 1.27 mm or 0.635 mm.
  • Pin Counts: Highly customizable, ranging from small 14-pin logic gates up to high-density 84-pin or 100+ pin complex microprocessors.
  • Lead Forms: Components are often shipped with flat, unformed metal ribbon leads, allowing assembly houses to custom-bend them into Gullwing configurations prior to soldering.
Architectural Performance Advantages
  • Ultimate Hermeticity & Environmental Immunity: Plastic encapsulated chips eventually absorb ambient moisture, which can cause internal corrosion or "popcorning" during thermal shock. CFP packages use a glass or gold-tin eutectic weld to fuse the ceramic lid to the base. This provides a true hermetic seal that completely blocks moisture, gases, and atmospheric contaminants.
  • Low Thermal Expansion Matching: The coefficient of thermal expansion (CTE) of aluminum oxide ceramic is much lower than standard FR-4 epoxy board substrates but matches perfectly with specialized polyimide or metal-core PCBs used in aerospace. This parity prevents structural mechanical warping and trace shear stress when components experience sudden, massive temperature swings.
  • Exceptional Outgassing Resistance: In a vacuum environment like space, volatile organic compounds within standard plastic components evaporate (outgas) and condense onto sensitive optical lenses, solar arrays, or high-voltage circuits. Because ceramic and glass are inorganic, CFP packages exhibit virtually zero outgassing, ensuring payload safety.
Small Outline L-Lead (SOL)
Small Outline L-Lead (SOL): A variation of the surface mount integrated circuit package where the parallel rows of pins exit the side of the plastic mold compound, bend downward, and then curve inward underneath the IC body. While a traditional "L-lead" or Gullwing package flares outward to maximize solder joint visibility, the inward L-lead folds back under the component body. This structural geometry functions very similarly to a J-lead package (SOJ), but utilizes flat, right-angle ribbon leads instead of rounded, J-shaped wires. This specialized configuration delivers a low-profile, mechanically stable connection tailored for strict high-density board layouts.
  • Lead Profile: Features flat ribbon leads bent at a sharp 90-degree angle that point directly toward the center axis of the chip.
  • Lead Pitch: Typically spaced at standard intervals of 1.27 mm or fine-pitch variations of 0.65 mm, depending on the vendor's package registry.
  • Footprint Efficiency: Reduces total board area consumption by roughly 20% to 35% compared to an outward-facing Gullwing SOIC layout.
  • Component Height: Maintains a low seated profile, typically between 1.50 mm and 2.50 mm.
Engineering Advantages
  • Enhanced Lead Alignment & Coplanarity: Because the leads fold tightly against the underside of the component body, they are significantly less prone to accidental deformation or bending during shipping, automated tape-and-reel feeding, and high-speed pick-and-place handling. This rigidity preserves strict coplanarity across all pins prior to reflow.
  • Structural Stress Mitigation: The flat, right-angled section tucked beneath the chip provides uniform surface contact with the PCB pads. This distributes mechanical shock and differential thermal expansion loads evenly across the joint, lowering the likelihood of trace shear failure or brittle fracturing.
  • High Concentration Board Clusters: Eliminating outward-flaring Gullwings allows PCB designers to route traces, place vias, or locate decoupling capacitors immediately adjacent to the plastic body walls without risking electrical shorts.
SMT Manufacturing & Layout Considerations: Implementing an inward SOL component requires unique adjustments to your stencil printing and quality control workflows:
  • Footprint: The copper target pads must shift completely beneath the nominal component outline. A tiny toe extension (around 0.15 mm to 0.25 mm) should be maintained past the bend shoulder to establish a minimal visible solder boundary.
  • Aperture & Paste Control: Because the leads sit directly under the plastic shell, precise solder paste volume is necessary. Excess paste cannot migrate outward safely and may result in solder balling or bridging under the package body.
  • Inspection Constraints: The inward bend heel fillet is from top-down optical line-of-sight. While basic Automated Optical Inspection (AOI) can check for gross skewing or toe wetting under the package, high-reliability assemblies use Automated X-Ray Inspection (AXI) to fully verify the structural voiding and bond quality underneath the body.
Plastic Leaded Chip Carrier (PLCC)
Plastic Leaded Chip Carrier (PLCC): A Square or rectangular surface mount integrated circuit (IC) package featuring J-shaped leads arranged along all four perimeter edges. Like the two-sided SOJ package, its pins exit the side of the plastic mold compound and curve inward underneath the component body. PLCCs can be soldered directly onto a PCB footprint or plugged into specialized through-hole or surface mount PLCC sockets. This multi-functional integration made them an industry standard for housing erasable and programmable devices like microcontrollers, flash memory, and BIOS chips throughout the 1990s and 2000s.
JEDEC: MO-044, MO-047, MO-087, MO-107, MO-110, MS-006, MS-007, MS-016, MS-018
  • Lead Pitch: Standardized globally at a wide, highly manufacturable 1.27 mm spacing.
  • Form Factors: Available in Square shapes (equal pin count on all four sides) and Rectangular shapes (asymmetric pin distribution).
  • Pin Counts: Typically scales across standard JEDEC sizes, spanning 20, 28, 44, 52, 68, and 84 pins.
  • Package Height: Thick relative to modern packages, typically ranging from 3.18 mm to 4.57 mm.
Architectural Advantages & Socket Utility
  • In-System Swappability via Sockets: The defining advantage of the PLCC is its compatibility with sockets. When soldered to a socket, a PLCC chip can be extracted using a specialized tool and replaced without desoldering. This provides a low-cost method for updating firmware, modifying BIOS code, or swapping out damaged controllers in the field.
  • Robust Lead Protection: Because the J-shaped pins curl directly underneath the heavy plastic body, the pins are completely shielded from accidental bending during bulk shipping, manual handling, or insertion into high-friction test sockets.
  • Excellent Thermal and Flex Compliance: The structural curvature of the four-sided J-leads functions as an omnidirectional spring. When a PCB undergoes thermal expansion or mechanical flexing, the leads flex along both axes to absorb the stress, protecting the underlying solder joints from cracking.
Modern Industry Application: While largely phased out of ultra-compact commercial electronics in favor of QFP, QFN, and BGA packages, PLCCs and their corresponding sockets remain heavily utilized in industrial automation controllers, telecommunications infrastructure, legacy computing hardware maintenance, and automotive diagnostic equipment.
Quad Flat Package (QFP)
Quad Flat Package (QFP): A square or rectangular surface mount integrated circuit (IC) package featuring Gullwing (L-shaped) leads extending outward from all four perimeter edges. This design allows it to accommodate much higher pin counts than two-sided packages like SOIC or SOJ. The QFP serves as a critical bridge between low-pin-count small outline packages and complex ball grid arrays. It became the global industry standard for housing microcontrollers, digital signal processors (DSPs), and application-specific integrated circuits (ASICs) throughout consumer electronics, automotive modules, and industrial hardware.
JEDEC: MO-071, MO-082, MO-084A, MO-108, MO-112, MO-173, MO-198, MO-212, MS-022, MS-029
JEDEC (with thermal): MO-114, MO-189, MO-204, MS-026
  • Lead Pitch: Typically ranges from fine to ultra-fine pitches, spanning 0.40 mm, 0.50 mm, 0.65 mm, 0.80 mm.
  • Pin Counts: Highly scalable, commonly ranging from 32 pins up to 200+ pins.
  • Component manufacturer Body Profiles: Package thicknesses vary widely across component manufacturers. However, the standard footprint name prefix for all these variations is QFP.
    • LQFP (Low-Profile QFP): Standardized at a fixed body thickness of 1.60 mm.
    • TQFP (Thin QFP): Slimmed down to a maximum body thickness of 1.20 mm.
    • VTQFP (Very Thin QFP): Maximum body thickness of 0.80 mm.
    • PQFP (Plastic QFP): Older, thicker variants ranging from 2.00 mm to 3.40 mm, often featuring protective bumper corners.
Core Engineering & Assembly Advantages
  • Exceptional Solder Joint Inspectability: Because the Gullwing leads flare outward away from the plastic package body, every single solder connection is completely visible from above. This allows high-speed Automatic Optical Inspection (AOI) systems or manual inspectors to verify heel and toe wetting fillets easily without requiring expensive X-ray imaging.
  • High Interconnect Density: Distributing interconnect pins along all four edges significantly decreases the required PCB surface area compared to dual-side leaded packages. This allows dense, multi-channel microcontrollers to fit onto compact circuit boards.
  • Compliance and Stress Absorption: The mechanical "S" or "L" bend in each Gullwing lead acts as a microscopic spring. When the underlying PCB expands, contracts, or flexes due to thermal changes and mechanical vibrations, the leads absorb the stress to prevent the solder joints from cracking.
Structural Variations
To meet expanding power and thickness constraints, the QFP design has evolved into several specialized configurations:
  • HQFP (Heat-sink QFP): Integrates a metal heat spreader or an exposed copper pad on the top or bottom surface to dissipate thermal energy from high-power chips.
  • CQFP (Ceramic QFP): Replaces the plastic compound with a hermetically sealed ceramic body for extreme aerospace, defense, and high-reliability deep-space environments.
PCB Footprint & Design Constraints: Designing a reliable footprint for fine-pitch QFPs requires tight layout tolerances to prevent manufacturing defects:
  • Solder Bridging Prevention: For fine pitches (0.40 - 0.50 mm), the copper pads must be narrow (typically 0.22 mm to 0.28 mm wide). This leaves a safe gap for a solder mask dam (web) between adjacent pads to prevent molten paste from bridging during reflow.
  • Toe and Heel Fillets: The PCB Toe Fillet should be 100% the nominal height of the terminal lead and the Pad Heel should be the distance from the Terminal Heel to the nominal package body to give the solder paste room to form proper structural fillets.
Coplanarity Sensitivity: Because QFP leads are thin and extend outward, they are easily bent during shipping or manual handling. If a single lead is lifted out of alignment by more than 0.08 mm to 0.10 mm, it will fail to touch the solder paste pad, resulting in an open circuit.
Ceramic Quad Flat Package (CQFP)
Ceramic Quad Flat Package (CQFP): A Premium, hermetically sealed surface mount integrated circuit (IC) package designed specifically for aerospace, defense, deep-space, and high-reliability industrial applications. It features flat ribbon or Gullwing leads extending from all four perimeter edges of a high-purity ceramic body. By combining the four-sided, high-pin-count architectural layout of a standard Plastic Quad Flat Package (QFP) with the absolute environmental immunity of co-fired ceramic materials, the CQFP functions as the industry-standard housing for space-grade FPGAs, high-speed microprocessors, and complex digital signal processors (DSPs).
JEDEC: MO-081, MO-090, MO-104, MO-111, MO-125
  • Hermetic Material: Constructed from multilayer aluminum oxide or aluminum nitride ceramic, sealed with a gold-tin (AuSn) eutectic alloy or glass-frit weld.
  • Lead Pitch: Typically standardized at fine-pitch spacings of 0.635 mm or 1.27 mm to handle high routing densities.
  • Pin Counts: Highly scalable to support complex silicon architecture, commonly ranging from 68 pins up to 352+ pins.
  • Lead Delivery State: Frequently shipped in a "flat" unformed state protected by a metal tie-bar matrix. Assembly facilities trim the tie-bar and bend the ribbon leads into customized Gullwing shapes just prior to PCB placement.
Critical Engineering & Performance Advantages
  • Absolute Hermeticity: Unlike standard plastic packages that slowly absorb atmospheric moisture over time, the CQFP's ceramic-to-metal seals form an absolute gas-tight barrier. This prevents moisture ingress, eliminating internal corrosion, wire-bond degradation, and the destructive "popcorning" effect during rapid thermal transitions.
  • Radiation Hardening Support: Space environments present intense cosmic and solar radiation fields that degrade standard commercial silicon. The dense ceramic composition and heavy gold plating of CQFP housings provide an inherent layer of physical shielding against alpha particles and electromagnetic interference (EMI).
  • Coefficient of Thermal Expansion (CTE) Matching: The CTE of aluminum oxide ceramic closely matches advanced substrate materials like polyimide-glass, metal-core boards, or copper-invar-copper (CIC) cores. This parity minimizes structural shear stress on the solder joints when aerospace modules undergo extreme temperature cycling from 65° C in orbit to +150° C during atmospheric re-entry.
  • Exceptional Thermal Dissipation: High-pin-count CQFPs frequently integrate a massive metal or ceramic base plate (exposed pad) on either the top or bottom surface. Soldering or mechanically clamping this pad to a dedicated PCB thermal plane drastically reduces junction-to-case thermal resistance.
PCB Design & Specialized Assembly Rules: Due to the strict quality demands of aerospace standards (such as NASA-STD-8739.3 or MIL-STD-883), laying out a footprint and assembling a CQFP requires rigorous process controls:
  • Tie-Bar Trimming & Lead Forming: Unformed flat ribbon leads must be processed using ultra-precise, automated tool dies to create uniform Gullwing configurations. Manual bending is prohibited in high-reliability workflows, as minor variations compromise lead coplanarity and induce micro-cracks in the lead plating.
  • Toe, Heel, and Side Fillet Validation: Footprint target pads must extend significantly past the formed lead boundaries (the toe is equal to the terminal lead thickness, and the Heel is equal to the terminal heel to the nominal package edge). This allows the solder paste to form distinct, highly visible fillets required for strict visual inspection without automated X-ray dependency.
  • Mechanical Tie-Downs and Underfills: Because ceramic bodies are heavy, intense launch vibrations can snap thin copper traces or crack solder joints. Space-grade layouts often dictate the application of specialized silicone or epoxy underfills beneath the component body to decouple mechanical G-forces from the electrical contacts.
Quad Flat No-lead (QFN): A highly popular, low-profile surface mount integrated circuit (IC) package characterized by a square plastic body with no protruding lead wires. Instead, it utilizes metallized terminal pads arranged along all four edges of its underside perimeter, completely flush with the bottom surface of the component. It is the four-sided counterpart to the Small Outline No-lead (SON) package and is widely favored for modern smartphones, consumer electronics, and high-frequency RF modules due to its miniature footprint and excellent electrical characteristics.
JEDEC: MO-220, MO-241, MO-243, MO-248
  • Fine Lead Pitch: Standardized at tight sub-millimeter intervals, most commonly 0.40 mm, 0.50 mm, 0.65 mm and 0.80 mm.
  • Ultra-Low Profile: Seated package heights are exceptionally slim, typically ranging from 0.75 mm down to 0.40 mm.
  • Pin Counts: Highly scalable for small-to-medium logic circuits, ranging from 8 pins up to 100+ pins.
  • Thermal Core: Features a prominent central Exposed Pad (EP) on the underside to facilitate direct thermal and electrical grounding.
Core Engineering & Performance Advantages
  • Minimal Parasitic Inductance: By eliminating long, external Gullwing or J-shaped leads, the internal wire bonds or flip-chip bumps connect almost directly to the PCB copper. This short path drastically reduces parasitic inductance, resistance, and capacitance, allowing QFNs to operate cleanly in high-speed digital and high-frequency RF applications.
  • High-Efficiency Thermal Path: The central exposed metal die pad is designed to be soldered directly to the board's copper plane. This configuration allows heat generated by the silicon die to bypass the plastic encapsulation completely, transferring directly into internal PCB copper layers via plated thermal vias.
  • Substantial PCB Space Savings: Because the contacts are pulled entirely underneath the perimeter of the component body, a QFN consumes up to 60% less board area and 30% less height than an equivalent leaded package like a Quad Flat Pack (QFP).
PCB Footprint & Manufacturing Challenges: Designing an IPC-7351 compliant footprint for a fine-pitch QFN package requires balancing compact spacing with assembly reliability:
  • The Solder Fillet Dilemma (Toe Fillets): QFN lead-frames are typically cut during factory singulation, leaving raw, unplated copper exposed on the outer sides of the chip. This exposed copper oxidizes rapidly. During reflow, solder paste will wet the bottom pad perfectly but may fail to climb up the outer side wall. Because there is no reliable side fillet, Automatic Optical Inspection (AOI) systems struggle to verify joint quality, often necessitating Automated X-Ray Inspection (AXI).
  • Wettable Flanks (An Assembly Fix): To solve the AOI issue, many modern QFNs feature a step-cut or plated cavity on the outer edge called a Wettable Flank. This manufacturing process keeps the outer edge of the pad plated with gold or tin, forcing the solder paste to form a visible vertical fillet that standard AOI cameras can easily verify.
  • Thermal Paste Segmentation: To prevent the component from floating or tilting during reflow, the solder paste stencil aperture over the large center pad must not be a single giant opening. Designers must divide the center stencil aperture into a segmented matrix grid (covering 50% to 75% of the area) to let volatile flux gases escape without creating massive solder voids.
  • Solder Mask Dams: For ultra-fine pitches (≤ 0.50 mm), the space between individual perimeter pads is incredibly narrow. Maintain a strict pad-to-mask clearance boundary to ensure the PCB fabricator can successfully place an insulating solder mask web between the pads, preventing solder bridging.
Pull-back Quad Flat No-lead (PQFN)
Pull-back Quad Flat No-lead (PQFN): A high-power surface mount package. It features exposed metal pads underneath its perimeter rather than traditional extending pins. The "pull-back" design exposes wettable flanks on the package edges, allowing for visible solder fillets during automated optical inspection (AOI) to guarantee reliable board mounting.
JEDEC: MO-208
Key Package Characteristics
  • Design & Layout: Instead of extending leads, electrical and thermal connections are made through flat contact pads located on all four sides of the package's underside.
  • Thermal Management: The bottom of the package features one or more exposed copper die-pads (or heat sinks). These act as direct thermal pathways to pull heat efficiently away from the silicon die and into the PCB.
  • Wettable Flanks: The "pull-back" feature means the package body slightly recedes from the outer edges of the terminal pads. This exposes the side of the leads, allowing solder to creep up and form a visual fillet.
  • Electrical Performance: Because there are no long, protruding leads, electrical parasitics (such as lead inductance and signal resistance) are dramatically reduced
Advantages and Applications
  • PQFN packages are highly favored for power-dense electronic applications where space is limited but thermal loads are high. The wettable flank "pull-back" design is particularly crucial for automotive, aerospace, and high-reliability industrial applications, where board manufacturers rely on visual or X-ray inspections rather than blind electrical tests to ensure zero-defect assembly.
  • For board-level assembly, specific footprints and stencil designs are required to ensure robust solder coverage between the package pads and the circuit board.
Leadless Chip Carrier (LCC)
Leadless Chip Carrier (LCC): A rugged, surface mount integrated circuit package that uses flat metal pads instead of pins. It features a ceramic body, making it highly resistant to extreme temperatures and harsh environments.
JEDEC: MO-027, MO-041, MO-042, MO-075, MO-085, MS-003, MS-004, MS-005, MS-009, MS-014
  • No Physical Leads: Electrical connections are made via gold-plated metallic pads (castellations) tucked into the perimeter of the package.
  • Ceramic Construction: The hermetically sealed ceramic body provides exceptional protection against moisture, heat, and shock.
  • High-Reliability Inspection: The castellations extend up the sides of the package, creating visible solder joints for easy inspection.
  • Thermal Expansion Match: Its thermal expansion rate closely matches specific PCB substrates like ceramic-core boards, preventing solder joints from cracking.
  • LCC packages are widely used in military, aerospace, and high-temperature industrial systems due to their durability and airtight seal. Because they lack long lead wires, they exhibit very low parasitic inductance and capacitance, making them ideal for high-frequency RF and microwave applications.
  • However, because ceramic is rigid, soldering LCCs directly to standard FR4 fiberglass boards can lead to joint failure under thermal stress. For commercial applications where standard FR4 boards are used, designers typically switch to the Plastic Leaded Chip Carrier (PLCC), which uses flexible "J-shaped" metal leads to absorb this physical stress.
Ball Grid Array, Collapsing Ball (BGA)
Ball Grid Array, Collapsing Ball (BGA): A high-density, surface mount integrated circuit package that uses an array of solder spheres for electrical and thermal connections. In this specific configuration, standard eutectic or near-eutectic solder balls melt completely during the reflow process, causing the package height to drop or "collapse" onto the PCB pad.
JEDEC: MO-149, MO-156, MO-158, MO-159, MO-192, MO-195, MO-205, MO-294, MO-298, MO-301, MO-302, MO-304, MO-307, MO-308, MO-311, MS-028, MS-034
  • Grid Array Layout: Connections cover the entire bottom surface of the package rather than just the perimeter, maximizing pin count per unit area.
  • Controlled Collapse: The solder balls flow entirely during assembly, relying on surface tension to align the package and self-center it over the PCB pads.
  • Standoff Control: The final height between the package and the PCB is determined by the volume of the solder paste, pad sizes, and the weight of the component.
  • Short Signal Paths: Eliminating wire leads lowers parasitic inductance and resistance, resulting in excellent high-speed electrical performance.
  • Collapsing BGA packages are the industry standard for high-performance processors, FPGAs, chipsets, and dense memory modules. The self-aligning nature of the collapsing balls dramatically reduces assembly defects during automated manufacturing. Additionally, the full grid layout provides ample paths for ground and power shielding, lowering electromagnetic interference (EMI).
  • Because the balls collapse completely, careful engineering of the PCB pad geometry is critical. Designers must choose between Non-Solder Mask Defined (NSMD) pads for higher mechanical trace reliability, or Solder Mask Defined (SMD) pads for stricter standoff height control and resistance to thermal stress cracking.
Ball Grid Array, Non-collapsing Ball (BGA)
Ball Grid Array, Non-collapsing Ball (BGA): A high-density, surface mount package designed to maintain a rigid, predictable standoff height during assembly. Unlike standard BGAs, the solder spheres do not melt during the reflow process; instead, a separate, lower-melting-point solder paste connects the rigid spheres to the PCB pads.
  • Fixed Standoff Height: The high-melting-point spheres remain solid during reflow, ensuring a guaranteed clearance gap between the package and the PCB substrate.
  • High-Melting Materials: The spheres typically consist of high-lead alloys (like 90Pb/10Sn) or copper-cored columns that survive standard reflow temperatures (220°C to 260°C).
  • Reliable Void Clearance: The fixed clearance gap allows flux residues to be easily washed away and prevents the package from tilting or shorting out adjacent pads.
  • Stress Relief: The rigid standoff absorbs differential thermal expansion between large ceramic packages and standard FR4 boards, preventing joint cracking.
  • Non-collapsing BGAs are often referred to as Ceramic Ball Grid Arrays (CBGA) or plastic packages with specialized core balls - are heavily utilized in high-reliability servers, aerospace guidance systems, and telecom infrastructure. The guaranteed standoff height is highly beneficial for routing heavy RF signals, as it keeps parasitic capacitance between the chip substrate and the motherboard perfectly uniform.
  • Because the structural sphere does not melt, achieving a reliable joint requires precise control over the volume of the printed solder paste. For this reason, Solder Mask Defined (SMD) pads are frequently preferred on the PCB side to strictly control the wetting area and maximize the fatigue life of the joint under heavy thermal cycling.
  • Via-in-Pad technology is normally used to fanout these fine pitch non-collapsing BGAs.
Land Grid Array (LGA)
Land Grid Array (LGA): A high-density surface mount integrated circuit package that replaces protruding leads or solder balls with an array of flat, gold-plated copper pads (lands) on its underside. Unlike BGA packages, an LGA does not come with pre-attached solder spheres, making it much thinner and allowing it to be either soldered directly to a PCB or mounted into a specialized hardware socket.
JEDEC: MO-222
  • Flat Contacts: The interface consists entirely of flat, coplanar metal pads arranged in a grid across the bottom surface of the component.
  • Low Profile: Eliminating solder balls minimizes the standoff height, creating an ultra-thin package profile ideal for space-constrained designs.
  • Dual Mounting Options: Can be permanently soldered down via surface mount technology (SMT) or placed into an LGA socket for easy replacement, upgrading, or testing.
  • Superior Signal Integrity: The exceptionally short electrical path between the silicon die and the motherboard yields minimal parasitic inductance, maximizing high-speed data performance.
  • Robust Coplanarity: Without delicate pins or fragile solder balls to bend or damage during handling, the package is mechanically highly robust prior to assembly.
  • LGA packages are the industry standard for high-performance computing hardware, such as desktop and server microprocessors (Intel, Xilinx, NVIDIA, AMD, Analog Devices CPUs), where socketing allows for modular upgrades. Because of their excellent thermal dissipation and low signal distortion, they are also widely adopted in high-frequency RF modules, network switches, 5G baseband processors, and miniature MEMS sensors.
  • When soldering an LGA directly to a PCB, manufacturing requires strict control. Because the standoff height between the package and the board is minimal (often less than 0.10 mm), getting the solder paste stencil thickness correct is vital to avoid short-circuits between pads. Additionally, proper venting pathways must be designed into the PCB layout to allow volatile flux gases to escape during the reflow process, preventing voids in the solder joints.
Column Grid Array (CGA)
Column Grid Array (CGA): An ultra-high-density, high-reliability surface mount package designed specifically to handle extreme thermal and mechanical stress. Instead of using solder balls or flat pads, a CGA utilizes an array of high-temperature solder columns on its underside. This unique structural architecture provides a flexible, tall standoff height that absorbs physical distortion between the component and the circuit board.
  • Column Array Interface: Tiny, vertical cylinders (columns) are attached to the bottom of the package substrate in a grid layout.
  • High Standoff Clearance: The extended height of the columns provides a substantial physical gap between the package body and the PCB.
  • Strain Relief Mechanics: The tall columns act like tiny springs. They flex slightly to absorb differential thermal expansion (CTE mismatch) between rigid ceramic substrates and standard FR4 circuit boards.
  • Thermal Shock Resistance: By flexing under stress, the columns prevent the solder joints from cracking during rapid, extreme temperature cycles.
  • Non-Collapsing Structure: The columns are made from high-melting-point alloys that remain completely solid during standard assembly reflow.
  • CGA packages, frequently designated as Ceramic Column Grid Arrays (CCGA) are the gold standard for aerospace, military, defense, and deep-space satellite systems. Large, complex devices like space-grade FPGAs and high-end military processors generate significant heat and must endure severe vibrational forces. Standard BGA solder joints would quickly crack under these conditions, but CGA columns absorb the stress to ensure a long operational lifespan.
  • Manufacturing with CGA components requires highly specialized process controls. Because the columns cannot collapse to self-level, the PCB planarity must be near-perfect. Additionally, due to the tight spacing and high standoff height of the columns, post-assembly cleaning processes must be carefully designed to ensure all aggressive flux residues are thoroughly washed away from underneath the large package body.
Call us - 847-557-2300
This page was generated in 2.066 seconds.
