Standard Reference Designators
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Standard Reference Designators
ASeparable AssemblyLSLoudspeaker, Buzzer
ARAmplifierMMeter
ATAttenuator; IsolatorMGMotor-Generator
BBlower, MotorMH*Mounting Hole
BTBatteryMKMicrophone
CCapacitorMPMechanical Part
CBCircuit BreakerPConnector, Plug, Male
CPConnector Adapter, CouplingPSPower Supply
CNCapacitor NetworkQTransistor
CRBreakdown DiodeRResistor
DDiodeRNResistor Network
DCDirectional CouplerRTThermistor
DLDelay LineRVVaristor, Variable Resistor
DSDisplay, LampSSwitch
ETerminalTTransformer
FFuseTBTerminal Board, Terminal Strip
FD*FiducialTCThermocouple
FLFilterTP**Test Point, In-circuit Test Points
GGenerator, OscillatorTZTranszorb
GNGeneral NetworkUInseparable Assembly, IC Pkg.
HHardwareVRVoltage Regulator
HYCirculatorWWire, Cable, Cable Assembly
JConnector, Jack, FemaleXFuse holder, Lamp holder, Socket
KContactor, RelayYCrystal, Oscillator
LCoil, Inductor, Bead, Ferrite BeadZMiscellaneous
*These class letters would not appear in a parts list as they are part of a PCB and not an active electronic component.
**Not a class letter, but commonly used to designate test points for maintenance purposes.
Note: The above list is not exhaustive. See the standard list of class designation letters in ANSI Y32.2/IEEE Standard 315.
Call us - 847-557-2300
