Forum Home Forum Home > PCB Footprint Expert > Symbol Expert - BETA TEST
  New Posts New Posts RSS Feed - Can't create STEP for Molded Body
rrix View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote rrix Quote  Post ReplyReply Direct Link To This Post Topic: Can't create STEP for Molded Body
    Posted: 30 Dec 2020 at 6:43pm
When I create a 3D STEP file for Component Type Molded Body, the window shows Done, but the file isn't in the target directory. Worked fine for DPAK and SOL component types. I'm using the Demo part with beta version 2021.01 .
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2020 at 6:51pm
Make sure that the Molded Body (plastic) is at least (minimum) 0.70 mm Less Than the overall Lead Span. The "D1" dimension is normally 1.00 mm +/- 0.20, less than the "D" dimension.
You need room for the 0.20 mm Lead Frame thickness and its bend radius can form on each end.
Other than that, please post your bug issues in the "Bug" forum so we can assign a programmer to investigate.
