| 05-08-1634 S6 |
Small Outline Transistor, SOT-23 Type, 0.95 mm pitch; 5 pin, 2.90 mm L X 1.625 mm W X 1.00 mm H body |
| 05-08-1635 S5 |
| 05-08-1636 S6 |
Small Outline Transistor, SOT-23 Type, 0.95 mm pitch; 6 pin, 2.90 mm L X 1.625 mm W X 1.00 mm H body |
| 05-08-1637 TS8 |
Small Outline Pkg (SOP), 0.65 mm pitch; 8 pin, 2.90 mm L X 1.625 mm W X 1.00 mm H body |
| 05-08-1637 TS8 |
Small Outline Transistor, SOT-23 Type, 0.65 mm pitch; 8 pin, 2.90 mm L X 1.625 mm W X 1.00 mm H body |
| 05-08-1638 SC6 |
Small Outline Transistor, SOT-23 Type, 0.65 mm pitch; 6 pin, 2.00 mm L X 1.25 mm W X 1.00 mm H body |
| 05-08-1639 SC8 |
Small Outline Transistor, SOT-23 Type, 0.50 mm pitch; 8 pin, 2.00 mm L X 1.25 mm W X 1.00 mm H body |
| 05-08-1640 G16 |
Small Outline Pkg (SOP), 0.65 mm pitch; 16 pin, 6.20 mm L X 5.29 mm W X 1.99 mm H body |
| 05-08-1640 G16 |
Small Outline Pkg (SOP), 0.65 mm pitch; 16 pin, 6.20 mm L X 5.30 mm W X 2.00 mm H body |
| 05-08-1640 G20 |
Small Outline Pkg (SOP), 0.65 mm pitch; 20 pin, 7.20 mm L X 5.30 mm W X 2.00 mm H body |
| 05-08-1640 G24 |
Small Outline Pkg (SOP), 0.65 mm pitch; 24 pin, 8.20 mm L X 5.29 mm W X 1.99 mm H body |
| 05-08-1640 G24 |
Small Outline Pkg (SOP), 0.65 mm pitch; 24 pin, 8.20 mm L X 5.30 mm W X 2.00 mm H body |
| 05-08-1640 G28 |
Small Outline Pkg (SOP), 0.65 mm pitch; 28 pin, 10.20 mm L X 5.30 mm W X 2.00 mm H body |
| 05-08-1640 G36 |
Small Outline Pkg (SOP), 0.65 mm pitch; 36 pin, 12.80 mm L X 5.30 mm W X 2.00 mm H body |
| 05-08-1640 S24 |
Small Outline IC (SOIC), 1.27 mm pitch; 24 pin, 15.395 mm L X 7.493 mm W X 2.642 mm H body |
| 05-08-1641 GN16 |
Small Outline Pkg (SOP), 0.635 mm pitch; 16 pin, 4.89 mm L X 3.899 mm W X 1.75 mm H body |
| 05-08-1641 GN16 |
Small Outline Pkg (SOP), 0.635 mm pitch; 16 pin, 4.895 mm L X 3.90 mm W X 1.75 mm H body |
| 05-08-1641 GN16 |
Small Outline Pkg (SOP), 0.635 mm pitch; 16 pin, 4.896 mm L X 3.90 mm W X 1.75 mm H body |
| 05-08-1641 GN20 |
Small Outline Pkg (SOP), 0.635 mm pitch; 20 pin, 8.65 mm L X 3.90 mm W X 1.75 mm H body |
| 05-08-1641 GN24 |
Small Outline Pkg (SOP), 0.635 mm pitch; 24 pin, 8.649 mm L X 3.899 mm W X 1.75 mm H body |
| 05-08-1641 GN24 |
Small Outline Pkg (SOP), 0.635 mm pitch; 24 pin, 8.65 mm L X 3.90 mm W X 1.75 mm H body |
| 05-08-1641 GN28 |
Small Outline Pkg (SOP), 0.635 mm pitch; 28 pin, 9.89 mm L X 3.90 mm W X 1.75 mm H body |
| 05-08-1641 GN28 |
Small Outline Pkg (SOP), 0.635 mm pitch; 28 pin, 9.893 mm L X 3.899 mm W X 1.75 mm H body |
| 05-08-1642 GW36 |
Small Outline Pkg (SOP), 0.80 mm pitch; 36 pin, 15.418 mm L X 7.506 mm W X 2.64 mm H body |
| 05-08-1642 GW36 |
Small Outline Pkg (SOP), 0.80 mm pitch; 36 pin, 15.42 mm L X 7.51 mm W X 2.64 mm H body |
| 05-08-1642 GW44 |
Small Outline Pkg (SOP), 0.80 mm pitch; 44 pin, 17.83 mm L X 7.51 mm W X 2.64 mm H body |
| 05-08-1642 GW44 |
Small Outline Pkg (SOP), 0.80 mm pitch; 44 pin, 17.932 mm L X 7.506 mm W X 2.64 mm H body |
| 05-08-1650 F14 |
Small Outline Pkg (SOP), 0.65 mm pitch; 14 pin, 5.00 mm L X 4.40 mm W X 1.10 mm H body |
| 05-08-1650 F20 |
Small Outline Pkg (SOP), 0.65 mm pitch; 20 pin, 6.50 mm L X 4.40 mm W X 1.10 mm H body |
| 05-08-1651 FW48 |
Small Outline Pkg (SOP), 0.50 mm pitch; 48 pin, 12.50 mm L X 6.10 mm W X 1.10 mm H body |
| 05-08-1651 FW48 |
Small Outline Pkg (SOP), 0.50 mm pitch; 48 pin, 12.50 mm L X 6.10 mm W X 1.20 mm H body |
| 05-08-1652 FW56 |
Small Outline Pkg (SOP), 0.50 mm pitch; 56 pin, 14.00 mm L X 6.10 mm W X 1.10 mm H body |
| 05-08-1660 MS8 |
Small Outline Pkg (SOP), 0.65 mm pitch; 8 pin, 3.00 mm L X 3.00 mm W X 1.10 mm H body |
| 05-08-1661 MS10 |
Small Outline Pkg (SOP), 0.50 mm pitch; 10 pin, 3.00 mm L X 3.00 mm W X 1.10 mm H body |
| 05-08-1662 MS8E |
Small Outline Pkg (SOP) with tab, 0.65 mm pitch; 9 pin, 3.00 mm L X 3.00 mm W X 1.10 mm H body |
| 05-08-1663 FE28 |
Small Outline Pkg (SOP) with tab, 0.65 mm pitch; 29 pin, 9.70 mm L X 4.40 mm W X 1.20 mm H body |
| 05-08-1663 FE16 |
Small Outline Pkg (SOP) with tab, 0.65 mm pitch; 17 pin, 5.00 mm L X 4.40 mm W X 1.10 mm H body |
| 05-08-1663 FE20 |
Small Outline Pkg (SOP) with tab, 0.65 mm pitch; 20 pin, 6.50 mm L X 4.40 mm W X 1.20 mm H body |
| 05-08-1663 FE20 |
Small Outline Pkg (SOP) with tab, 0.65 mm pitch; 21 pin, 6.50 mm L X 4.40 mm W X 1.20 mm H body |
| 05-08-1663 FE24 |
Small Outline Pkg (SOP) with tab, 0.65 mm pitch; 25 pin, 7.80 mm L X 4.40 mm W X 1.20 mm H body |
| 05-08-1663 FE28 |
| 05-08-1664 MSE10 |
Small Outline Pkg (SOP) with tab, 0.50 mm pitch; 11 pin, 3.00 mm L X 3.00 mm W X 0.86 mm H body |
| 05-08-1664 MSE10 |
Small Outline Pkg (SOP) with tab, 0.50 mm pitch; 11 pin, 3.00 mm L X 3.00 mm W X 1.10 mm H body |
| 05-08-1666 MS12 |
Small Outline Pkg (SOP) with tab, 0.65 mm pitch; 13 pin, 4.039 mm L X 3.00 mm W X 1.10 mm H body |
| 05-08-1666 MS12 |
Small Outline Pkg (SOP), 0.65 mm pitch; 12 pin, 4.039 mm L X 3.00 mm W X 1.10 mm H body |
| 05-08-1666 MSE12 |
| 05-08-1667 MSE16 |
Small Outline Pkg (SOP) with tab, 0.50 mm pitch; 17 pin, 4.039 mm L X 3.00 mm W X 1.10 mm H body |
| 05-08-1668 MS12 |
Small Outline Pkg (SOP), 0.65 mm pitch; 12 pin, 4.038 mm L X 3.00 mm W X 1.10 mm H body |
| 05-08-1669 DD10 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 11 pin, 3.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1669 MS16 |
Small Outline Pkg (SOP), 0.50 mm pitch; 16 pin, 4.039 mm L X 3.00 mm W X 1.10 mm H body |
| 05-08-1674 BGA |
Ball Grid Array (BGA), 1.27 mm pitch, rect.; 84 pin, 15.00 mm L X 9.00 mm W X 5.12 mm H body |
| 05-08-1691 UD16 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 4 pin X 4 pin, 3.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1692 UF16 |
Quad Flat No-Lead (QFN) with tab, 0.65 mm pitch; square, 4 pin X 4 pin, 4.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1693 UH32 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 8 pin X 8 pin, 5.00 mm L X 5.00 mm W X 0.80 mm H body |
| 05-08-1695 DE/UE12 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 13 pin, 4.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1695 DE12 |
| 05-08-1695 DF12 |
| 05-08-1695 UE12 |
| 05-08-1696 UFD24 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; rect., 7 pin X 5 pin, 5.00 mm L X 4.00 mm W X 0.75 mm H body |
| 05-08-1696 UFD24 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; rect., 7 pin X 5 pin, 5.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1697 UF24 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 6 pin X 6 pin, 4.00 mm L X 4.00 mm W X 0.75 mm H body |
| 05-08-1697 UF24 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 6 pin X 6 pin, 4.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1698 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 9 pin, 3.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1698 DD8 |
| 05-08-1699 DD-10 |
| 05-08-1699 DD10 |
| 05-08-1699 DFN-10 |
| 05-08-1700 UD16 |
| 05-08-1701 UHF38 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; rect., 12 pin X 7 pin, 7.00 mm L X 5.00 mm W X 0.80 mm H body |
| 05-08-1702 DDB8 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 9 pin, 3.00 mm L X 2.00 mm W X 0.80 mm H body |
| 05-08-1703 DC6 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 7 pin, 2.00 mm L X 2.00 mm W X 0.80 mm H body |
| 05-08-1703 DC6 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 7 pin, 2.00 mm L X 2.00 mm W X 0.85 mm H body |
| 05-08-1704 UK48 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 12 pin X 12 pin, 7.00 mm L X 7.00 mm W X 0.80 mm H body |
| 05-08-1705 UP64 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 16 pin X 16 pin, 9.00 mm L X 9.00 mm W X 0.80 mm H body |
| 05-08-1706 DHC16 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 17 pin, 5.00 mm L X 3.00 mm W X 0.80 mm H body |
