  New Posts New Posts RSS Feed - IPC-7352 Footprint Naming Convention: Through-hole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7352 Footprint Naming Convention: Through-hole
The land pattern naming convention uses component dimensions to derive the land pattern name.
The first 3 - 6 characters in the land pattern name describe the component family.
The first number in the land pattern name refers to the Lead Spacing or hole to hole location to insert the component lead.
All numbers that follow the Lead Spacing are component dimensions.
These characters are used as component body identifiers that precede the value and this is the priority order of the component body identifiers -
  • P = Pitch for components with more than two leads
  • W = Maximum Lead Width (or Component Lead Diameter)
  • L = Body Length for horizontal mounting
  • D = Body Diameter for round component body
  • T = Body Thickness for rectangular component body
  • H = Height for vertically mounted components
  • Q = Pin Quantity for components with more than two leads
  • R = Number of Rows for connectors
Notes:
All component body values are in millimeters and go two places to the right of the decimal point and no leading zeros.
All Complexity Levels used in the examples are "B".
Component, CategoryLand Pattern Name
Capacitors, Non-Polarized Axial Diameter Horizontal MountingCAPAD + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Capacitors, Non-Polarized Axial RectangularCAPAR + Lead Spacing + W Lead Width + L Body Length + T Body thickness + H Body Height
Capacitors, Non-Polarized Axial Diameter Vertical Mounting CAPADV + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Capacitors, Non-Polarized Axial Rect. Vert. Mtg.CAPARV + Lead Spacing + W Lead Width + L Body Length + T Body Thickness + H Body Height
Capacitors, Non-Polarized Radial DiameterCAPRD + Lead Spacing + W Lead Width + D Body Diameter + H Body Height
Capacitors, Non-Polarized Radial RectangularCAPRR + Lead Spacing + W Lead Width + L Body Length + T Body thickness + H Body Height
Capacitors, Non-Polarized Radial Disk ButtonCAPRB + Lead Spacing + W Lead Width + L Body Length + T Body thickness + H Body Height
Capacitors, Polarized Axial Diameter Horizontal MountingCAPPAD + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Capacitor, Polarized Radial DiameterCAPPRD + Lead Spacing + W Lead Width + D Body Diameter + H Body Height
Diodes, Axial Diameter Horizontal MountingDIOAD + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Diodes, Axial Diameter Vertical Mounting DIOADV + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Dual-In-Line PackagesDIP + Lead Span + W Lead Width + P Pin Pitch + L Body Length + H Component Height + Q Pin Qty
Dual-In-Line SocketsDIPS + Lead Span + W Lead Width + P Pin Pitch + L Body Length + H Component Height + Q Pin Qty
Headers, VerticalHDRV + Lead Span + W Lead Width + P Pin Pitch + R Pins per Row + L Body Length + T Body Thickness + H Height
Headers, Right AngleHDRRA + Lead Span + W Lead Width + P Pin Pitch + R Pins per Row + L Body Length + T Body Thickness + H Height
Inductors, Axial Diameter Horizontal MountingINDAD + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Inductors, Axial Diameter Vertical Mounting INDADV + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Inductors, Non-Polarized, Radial DiameterINDRD + Lead Spacing + W Lead Width + D Body Diameter + H Body Height
Inductors, Polarized, Radial Diameter INDPRD + Lead Spacing + W Lead Width + D Body Diameter + H Body Height
Jumpers, WireJUMP + Lead Spacing + W Lead Width
Mounting Holes Plated with Support PadMTGP + Pad Size + H Hole Size + Z Inner Layer Pad Size
Mounting Holes Non-Plated With Support PadMTGNP + Pad Size + H Hole Size + Z Inner Layer Pad Size
Mounting Holes Non-Plated Without Support PadMTGNP + Pad Size + H Hole Size + Z Inner Layer Pad Size + K Keep-out Diameter
Mounting Holes Plated with 8 Vias MTGP + Pad Size + H Hole Size + Z Inner Layer Pad Size + 8 Vias
Pin Grid Array’sPGA + Pin Qty + P Pitch + C Pin Columns + R Pin Rows + L Body Length X Body Width + H Component Height
Resistors, Axial Diameter Horizontal MountingRESAD + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Resistors, Axial Diameter Vertical Mounting RESADV + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Resistors, Axial Rectangular Horizontal MountingRESAR + Lead Spacing + W Lead Width + L Body Length + T Body thickness + H Body Height
Single-In-Line PackagesSIP + Body Width + W Lead Width + P Pin Pitch + L Body Length + H Component Height + Q Pin Qty
Test Points, Round LandTP + Lead Width
Test Points, Square LandTPS + Lead Width
Test Points, Top Land Round & Bottom Land SquareTPRS + Lead Width
WirePAD + Wire Width
Call us - 847-557-2300
