FPX File Definition
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: FPX File Definition
The FPX file library is a collection of package dimensions for standard parts and manufacturers recommend patterns for non-standard parts. Standard part footprints are created in the calculator using one of the 144 surface mount or through-hole templates. Non-standard parts are created using the FP Designer module in Footprint Expert.
All connectors are non-standard parts except headers that have a symmetrical pad pattern with one pad stack and the pins are evenly placed using the same X/Y grid system. Any semiconductor that requires more than one pad stack length or width is a non-standard package. Any discrete component that its terminal lead form is not listed in the surface mount standard terminal leads is considered a non-standard package.
The Calculators save this information in the FPX file library:
  1. Package Dimensions
  2. 3D STEP Color
  3. Manually inserted Drafting Symbols
  4. Manually inserted Keepout
  5. Manufacturer Recommended Pattern
  6. Manually Updated Pin Names or Reordered Pins
All other footprint features are generated in Tools > Options. When you open a FPX file calculator part, the package dimensions will auto-populate the package dimensions in the correct cells. The resulting footprint is derived by combining the package dimensions with the Terminal Solder Joint Goal Settings for that component family and the Drafting Rule Settings for silkscreen, assembly, courtyard, component, terminal and origin outlines. The package and terminal tolerances also play a role in the pad stack calculation.
You can create multiple Option files with different rule settings and use the same FPX file to create multiple libraries. Set up Options to solder mask define pad stacks for Flex circuits. Or set up rules with larger solder joint goals for Wave Solder. Or create an Option file with rules from an assembly shop or rules for a specific customer. Use the same FPX file to create multiple libraries for different applications.
For non-standard FP Designer parts, a lot more data is saved in the FPX file. FP Designer footprint data that is saved in the FPX file include:
  1. 3 Package dimensions
  2. Pad Stack Data
  3. Courtyard Excess
  4. Manually inserted Drafting Symbols
  5. Automatic Assembly Polarity Location
  6. Manually inserted Keepout
  7. Footprint Rotation
  8. Physical Description
  9. Manufacturer Name
  10. Case Code
  11. Part Number
  12. Pin Names
  13. Footprint Origin Location
  14. Footprint Name
  15. 3D Color
The FPX file comes with these column headers, but you can add additional columns:
  1. Footprint Name
  2. Physical Description
  3. Case Code
  4. Manufacturer
  5. Part Number
  6. Logical Description
  7. Mounting Type
  8. Datasheet
  9. Part Status
  10. Footprint Date
  11. Comments
The FPX file has built in features that help automate and organize library data. When you select a Calculator component family and enter the package dimensions and Save to FPX Library, Footprint Expert autogenerates the Footprint Name, Physical Description, Mounting Type, Part Status and Footprint Date. The Manufacturer Names are embedded into the program. When the Manufacturer cell is selected, just enter the first couple letters of the Manufacturer Name and a list of Manufacturers appear in a dropdown menu selection.
By typing a 'T' in the Manufacturer cell, every manufacturer name that begins with 'T' will appear in the dropdown menu.
Type 'TE' and the list will only include manufacturer names that include 'TE'.
Type 'TEX' and the list will only include manufacturer names that include 'TEX'. Texas Instruments is the only manufacturer that begins with TEX. Select Texas Instruments and it will auto-populate the Manufacturer cell.
This will ensure that all the spelling of every manufacturer is consistent.
The Case Code and Part Number must be manually entered or copy/paste from a datasheet.
Once the full Part Number is populated, you can Right Mouse Click that cell and a dropdown menu will appear with these options:
When 'Internet Browser' is selected, the default web browser will display all the websites that support that Part Number.
When 'Parts on Demand (POD)' is selected, the default browser will open www.pcblibraries.com/POD allowing you to download that part into your /downloads folder. Then you can import the FPX file into your Master Library and create the footprint out to your CAD tool.
When 'Manufacturer Home Page' is selected, the main page to that Manufacturer will open in your default browser., You can copy/paste the part number into the search box to locate the datasheet.
Note: The Part Number search requires the Manufacturer Name cell to be populated.
The same feature is available if you have the correct Case Code cell entered.
The 'Datasheet' cell can be https:// or a network drive path to a PDF datasheet.
The 'Mounting Type' cell can be auto populated by entering a S for Surface Mount or T for Through-hole or M for Mixed Technology.
Here are the control features for the Library Editor.
  • Open an existing FPX file library
  • Save the current FPX file (this icon will turn gray when the file is saved)
  • Create a New FPX file
  • Import an FPX file into an existing FPX file
  • Batch Build a selection of parts to CAD tool
  • Unlimited Undo
  • Unlimited Redo
  • Search for text in the FPX library
  • Remove all highlighted Markers
  • Show a list of component family Categories
  • View the selected footprint
  • Open the Datasheet
Delete a Row by selecting the gray button to the left of the Footprint Name and Right Mouse Click and select 'Delete Row'.
Add a new blank row by Right Mouse Click and select 'New - Row' or 'New - Rows'.
Add a new column by Right Mouse Click and select 'New - Column'. Create as many columns as you need.
Call us - 847-557-2300
