Surface Mount Solder Joint Goal Tables (Min/Max)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Surface Mount Solder Joint Goal Tables (Min/Max)
The Min/Max Calculation section was originally inspired by IPC-7351 and subsequently by the superseding IPC-7352 - Generic Guideline for Land Pattern Design. The solder joint goals were derived from the IPC J-STD-001G - Requirements for Soldered Electrical and Electronic Assemblies. For more details, see Appendix I.
Gullwing Leads (SOP, QFP, SOT, DPAK, SOD)
Rectangular and Square-End Cap (Chips)
Inward L Lead Oscillator and Small Outline L-Lead (SOL)
Outward L-Lead (SOT)
Cylindrical End Cap (MELF)
Small Outline No-Lead (SON, QFN)
Small Outline Components, Flat Lead (SOFL, SODFL)
Flat Lug Lead (DPAK)
Small Outline Flat No-Lead Bottom (DFN, LGA, PSON, PQFN)
Under-Body Outward L-Lead (Aluminum Electrolytic Capacitor, Crystal)
Inward Flat Ribbon L-Lead (Molded Body)
Concave & Convex Chip Array and Leadless Chip Carrier (LCC)
J-Leads
Column and Land Grid Array (CGA & LGA)
Corner Concave Oscillator
Collapsing and Non-Collapsing Ball Grid Array (BGA)
Call us - 847-557-2300
This page was generated in 0.076 seconds.
