  New Posts New Posts RSS Feed - Pad Stack With Notch
rdl86626 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdl86626 Quote  Post ReplyReply Direct Link To This Post Topic: Pad Stack With Notch
    Posted: 10 Jan 2014 at 8:29am
Is it possible to create a part (say a surface mount cap) with one pad having a notch cut out at one corner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2014 at 8:53am
Absolutely! Use the Footprint Designer module to define your custom padstack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2014 at 3:13pm
You can view how to create/define custom padstacks in most of the videos found here:
http://www.pcblibraries.com/training
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2014 at 8:51pm
In the Pad Stack Designer Select –
  1. Surface Mount
  2. Pad Shape Rectangle
  3. Enter your pad size length and width
  4. Corner Style “BOTH” (so that you can also create radius corners on the remaining 3 corners)
  5. Chamfer Size
  6. Chamfer Location
As far as creating a "Notch" like an "L" shaped pad, FP Designer can not do that yet.
