Footprint Options on Left Panel vs Options Config |
Nick B
Topic: Footprint Options on Left Panel vs Options ConfigPosted: 2 hours 35 minutes ago at 7:48am |
Do not use the Calculator side panel options for production. They are intended to test option features. 1. The only data saved to FPX is: a. Package Dimensions b. Mfr. Recommended Pattern c. 3D Colors assignments d. Manually inserted drafting objects and keepouts All other footprint features are derived for you Master Option file. Create a master option file using "Tools > Options > File Save As > Your Name" Example: you want D-Shaped Pads for some component families. Go to "Tools > Options > Component > QFN" ![]() This message will appear and you select 'No' because you don’t want to affect every Component Family. ![]() Continue to select each component family and change the pad shape. Save your options and every time you open a QFN it will have D-Shaped pads. |
