  New Posts New Posts RSS Feed - Through-hole Naming Convention Suffix?
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Through-hole Naming Convention Suffix?
    Posted: Yesterday at 12:16am
I noticed Through-hole Naming Convention doesn't contain an N suffix.
However Surface Mount contains the suffix 'N' when using Nominal Density Level in Options.
Can you explain this point?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:09am
The 3-Tier library system only pertains to Surface Mount footprints.
There is only 1-Tier for through-hole and we refer to it as 'Proportional' pad stacks where the pad diameter is 1.5 times the hole diameter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:17am
Also, when a Surface Mount footprint uses the Mfr. Recommended Pattern or the footprint is non-standard, there is no Density Level for these footprints as they are the mfr. recommended patterns.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 49 minutes ago at 5:50am
So the mentioned statement means there is no suffix N in below cases also through hole, is this correct?
"When a Surface Mount footprint uses the Mfr. Recommended Pattern or the footprint is non-standard, there is no Density Level for these footprints as they are the mfr. recommended patterns."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 31 minutes ago at 9:08am
Yes
