Purpose
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Purpose
The purpose of The Footprint Expert Guideline is to establish a comprehensive, standardized methodology for the development, naming, dimensioning, and documentation of printed circuit board (PCB) footprints and pad stacks for both surface mount and through-hole electronic components. This guideline provides consistent rules and mathematical models for the creation of manufacturable, assembly-ready PCB footprints intended to improve design quality, interchangeability, automation, and communication throughout the electronic product development process.
This document defines terminology, density level strategies, solder joint objectives, courtyard requirements, naming conventions, drafting standards, pad stack rules, and tolerance considerations used in the generation of PCB footprints and associated library data. In addition, it provides recommended footprint methodologies and package family definitions for a broad range of electronic component types, including surface mount, leaded through-hole, area-array, and specialized package styles.
The guideline is intended for use by PCB library developers, ECAD librarians, PCB designers, manufacturing engineers, assembly engineers, component engineers, and software systems involved in automated footprint generation and verification. The objective is to promote uniformity and repeatability in PCB footprint creation while supporting efficient manufacturing, inspection, assembly reliability, and long-term library maintenance.
The recommendations contained within this guideline are based on accepted industry practices, mathematical modeling techniques, and practical manufacturing considerations. The information may be used independently or alongside applicable industry standards, including those published by the IPC, IEC, and FED, to support the creation of consistent and reliable PCB footprint libraries.
Call us - 847-557-2300
