Footprint Expert 26.08 Released!!
Post Options Post Options   Thanks (2) Thanks(2)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 26.08 Released!!
    Posted: 08 Aug 2026 at 12:34pm
Version 26.08 was just released!!
Fixes & Enhancements:
    • When having 2 sessions of Footprint Expert running
      • Copying an FPX file row from one session to another session overwrites an existing row
    • When switching between Assembly Polarity Marking in the Drafting Options, the 'None' option wasn't working
    • Updated the Pad Stack Manager for Thermal Pad Paste Mask
      • Not showing the true coverage %
      • Not turning on the 'Update Pad Stack' button when a value was changed
  • Calculators:
    • Molded Body - The 'D1' dimension was removed and is now calculated to be 0.40 mm less than 'D'
      • This now allows the terminal lead to be flat against the package body
    • When the Mirror feature is used, a warning symbol will appear in the upper left corner of the viewer
    • Molded Body Thyristor not opening in viewer because the polarity was non-polarized and should have been polarized
  • Options:
    • Drafting > Courtyard - added a new option to map the courtyard outline to the Nominal Body
      • Note: the default setting is Map Courtyard to Maximum Body
  • CAD Tool Interfaces:
    • KiCad - Added rounded corners for thermal tab paste and solder mask pattern shapes
