IPC-7352 incorrect table content?
eCADLER_94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eCADLER_94 Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7352 incorrect table content?
    Posted: 19 May 2026 at 3:48am
I believe that table 3-6 "Leadless Components with Concave/Castellated Termination" cannot be correct. Let's take the Nominal column, here the Toe would be 0.15mm and the Heel 0.45mm.
In my opinion, it doesn't make much sense to pull the pad that far back. Also confusing is the note "to find Z dim" next to the Heel(JH). The formula for Z (overall length of land pattern) is:
Z = Lmax +2xJt
This therefore has nothing to do with the Heel.
In my opinion, the table values of Toe and Heel are swapped.
Do you see it that way too?"
Best regards
Johannes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2026 at 7:30am
I think you are correct.
IPC got the Toe and Heel values backward.
This page was generated in 0.109 seconds.
