  New Posts New Posts RSS Feed - Polarity on Assembly
dramos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Topic: Polarity on Assembly
    Posted: 01 Mar 2022 at 7:30am
I would like to know of configure the orientation of the polarity mark for different packages.
I am using version 2022.02 and for example, a SODFL the mark is in the middle and I would like to know of to change it to one side (chamfer) top or bot.
Thanks for your time and help. :)
dramos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 10:52am
V2022.03 is released and it fixes 15 bugs and adds 2 new features.
The automatic Assembly Polarity marker for SOD and SODFL is in the middle.
You want the Assembly Polarity to be a Chamfered corner.
I will discuss this with the programmer to see if we can change the default location.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 12:58pm
The SOD, SODFL and 2-pin Side Concave Package will have a Chamfer Assembly Polarity Marker in V2022.04 pre-release coming later this week.
Thank you for reporting this inconsistency in the assembly outline polarity marking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 11:22pm
Thanks to you and to all the team due to the good work you are doing on PCBL !!!
Regards,
dramos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 5:12pm
The SOD, SODFL and 2-pin Side Concave assembly polarity marking have been updated in the new V2022.04 pre-release - www.pcblibraries.com/downloads
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 12:30am
thanks for the info, I will install it :)
Regards,
dramos
