PADS Layout Diodes Do Not Need Pin Mapping
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: PADS Layout Diodes Do Not Need Pin Mapping
    Posted: 07 Dec 2013 at 11:47am
When creating a diode it uses pin numbers "C" and "A" in the decal. This is the new method pads uses I think around version 2007.
If you look at the part for the decal in pads version 9.5  the "Define mapping of part type pin numbers to Pcb decal" is enabled. If you use alphanumeric pin numbers in the decal you cannot also remap them in the part by enabling this button.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Artwork Master ITALY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2013 at 2:06pm
It is Not necessary change the names in part editor if you have already personalized the names in the decal. (suppost that the program permit to personalize the names in decal).
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2013 at 9:31pm
That is not the problem.  Define mapping of part type pins is set when you want to change numeric pins in the decal to alphanumeric in the part. If you already have alphanumeric in the decal you do not need to use that flag. if you do pads gives you an error when you open the part.
This page was generated in 0.517 seconds.
