Pad Stack Designer Offset Disabled |
Post Reply ![]() |
Author | |
PLTcbv ![]() Advanced User ![]() Joined: 21 Aug 2012 Location: the Netherlands Status: Offline Points: 134 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Sep 2014 at 5:07am |
In Pad Stack Designer Library Expert Lite 2014.11 this happens. When pad Y > X then Offset is disabled. ![]() When pad X > Y then Offset is enabled. ![]() Why? |
Tom H ![]() Admin Group ![]() ![]() Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5809 |
Because the Offset is under the "X" column. If you want to offset the hole, X must be greater than Y. You can always rotate the pad stack. |
Jeff.M ![]() Admin Group ![]() Joined: 16 May 2012 Location: San Diego Status: Offline Points: 483 |
Offset is only available in the X axis. As such X must exceed Y.
Post Reply ![]() |
Tweet |
