Naming Convention |
Post Reply ![]() |
Author | |
mnperry ![]() Active User ![]() Joined: 12 Jan 2021 Status: Offline Points: 10 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Oct 2022 at 6:18am |
The standard IPC naming standard does not have a separate category as in your naming standard for example: Ferrite Bead, Chip (that I can see anyway)
The IPC naming standard states to use FB_Mfr.'s Part Number This is the name Footprint Expert gave to BLM15BD750SN1D: BEADC1005X55. (I just did a quick test.) In the Footprint Expert settings, for the naming standard to use, I chose: IPC-7351B and NOT PCB Libraries. Am I missing seeing the use of "BEADC..." in the standard IPC naming standard? Sorry if this is picky, but we are developing our internal standards and are hoping (and praying) to be as consistent as possible. Thanks! Mike |
Tom H ![]() Admin Group ![]() ![]() Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5296 |
The IPC-7351B is 12 years old.
It will be replaced with IPC-7352 in January. IPC-7352 has Ferrite Bead.......BEADC |
Perfect! Thanks Tom.
_sergey_ ![]() Active User ![]() Joined: 12 Mar 2019 Status: Offline Points: 30 |
There is a problem with the naming of components. Created 2 variants of one axial lead component: 1 Component close to the board (A=E) 2 Component with 1mm clearance to board (A=E+1) The problem is that the program creates one footprint name for both variants. For correct binding to 3D models, unique footprint names are required.
The Through-hole Land Pattern Naming Convention is right out of the upcoming new release of IPC-7352.
You should manually add a Variant to the end of the Footprint Name for the "E" dimension if the Axial Lead package is sitting off the PCB. You should have joined the IPC Land Pattern committee. |
kfisher ![]() New User ![]() Joined: 09 Feb 2016 Status: Offline Points: 8 |
How does the IPC-7352 naming convention compare with the
PCB Libraries naming convention was originally approved by the IPC 1-13 Land Pattern Committee for inclusion in the IPC-7351C 5 years ago. We originally called the PCB Libraries naming convention IPC-7351C, but IPC contacted us and asked us to remove all instances of IPC-7351C from our website and the Footprint Expert software 3 years ago. So we renamed IPC-7351C to PCB Libraries and copyrighted it. This prevented IPC from using it in IPC-7352. However, IPC took some of the modifiers like "Thermal Pad Size", "Gull Wing Terminal Lead Size", and "BGA Ball Diameter" and added it to the end of the IPC-7351B naming convention. IPC-7352 also includes through-hole technology and a naming convention for PTH footprints that Dieter Bergman and I developed 10 years ago and hasn’t been changed since. |
One of the benefits that drew us to the "PCB Libraries" naming convention over 7351B was avoidance of name overlap. In your opinion, do the modifiers incorporated as 7352 bring the IPC standard up to the same level of the "PCB Libraries" naming convention, or is there still an advantage to staying where we are?
And, where are some of the biggest differences that remain between the "PCB Libraries" and 7352 naming conventions?
Not 100%.
IPC-7352 only adds the terminal lead length for Gull Wing leads. PCB Libraries (IPC-7351C) added the terminal length for all terminal lead sizes like Flat Lead for QFN, SON, CAPAE, Corner Concave Oscillators, J-Lead SOJ, etc. |
Post Reply ![]() |
Tweet
