Molded Body - Cap, Polarized Calculations
ccyman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ccyman Quote  Post ReplyReply Direct Link To This Post Topic: Molded Body - Cap, Polarized Calculations
    Posted: 13 Nov 2026 at 4:11pm
Is there perhaps a setting I need to fix in the calculator when using it out of the box for Molded Body - Capacitor, Polarized?
The toe and heel results are not what I'm expecting to see based on the settings defined.
Since I can't upload images, here's what the settings were:
Component dimensions filled in were (mm):
A = 2.00 max
b = 2.20 +/-0.2
D = 3.50 +/-0.2
E = 2.80 +/-0.2
L = 0.80 +/-0.3
Terminal Density Level
Inward Flat Ribbon L-Lead. Height > 1.20, <= 2.20 mm
Density Level = Nominal
Toe = 0.05 mm
Heel = 0.45 mm
Side = 0.00 mm
Calculator results are:
G = 1.33 mm
X = 1.63 mm
Y = 2.40 mm
This results in a toe of 0.088mm (I was expecting 0.05mm) and a heel of 0.442mm (I was expecting 0.45mm).
These results are from Footprint Expert 26 (26.10, 10/30/2026).
Cindy
This page was generated in 0.437 seconds.
