Molded Body 3D STEP Missing
fabioclimb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fabioclimb Quote  Post ReplyReply Direct Link To This Post Topic: Molded Body 3D STEP Missing
    Posted: 11 Dec 2020 at 5:31am
I'd like to report that the 3D Step model is not generated by selecting SMD Molded Body Capacitor Polarized.
thank you in advance!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2020 at 9:41am
I can't reproduce this. I'm using Library Expert V2020.03.
kaplanent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kaplanent Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2022 at 10:51am
Wow, I just noticed this issue with the CAPPM footprints.
I have all our Molded footprints in a separate library.
I thought the library was corrupt, but all other families of molded output the STEP file.
I guess I hadn't had the need for a new molded cap footprint in over a year.
So you're not the only one.
I guess we will have to update to the latest version as there is no other 2020 update.
Alan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2022 at 11:11am
The Molded Body component family uses the JEDEC DO-214 as the main model.
Note: the "D" dimension MUST be at least 0.80 mm larger than the "D1" dimension or the 3D STEP model will be corrupt.
The Terminal Lead thickness is 0.20 mm on both sides, and it needs 0.20 mm lead bend radius.
If you still have a problem, you will have to upgrade to V2022.02 pre-release (is the latest version right now). Or the last release V2022.01.
This page was generated in 2.734 seconds.
