Maximum or Nominal Body Dimensions For Legend
Batiskaff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Topic: Maximum or Nominal Body Dimensions For Legend
    Posted: 28 Jun 2019 at 11:57am
Which are package dimensions are preferred to use to draw the legend outline (nominal or maximal body dimensions)?
Any general requirements for this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 12:01pm
The Maximum Body Dimensions, because then you can see the Legend after assembly.
You can also QC the placement accuracy of the assembly process.
If the component is covering the Legend on one side and highly exposed on the other side may indicate assembly flaws.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 12:27pm
Thank you.
This page was generated in 0.096 seconds.
