IPC Standards for Manufacturing & Assembly |
Post Reply ![]() |
Author | |
sgdavies ![]() Advanced User ![]() Joined: 27 Aug 2012 Location: Germany Status: Offline Points: 140 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Mar 2013 at 3:31am |
I noticed that different companies specify and quote different IPC standards when sending their PCB's to Manufacture and Assembly, so I would like to get a feel which are the most commonly specified IPC standards on here? Any and all thoughts are welcome! I will start this, Currently we only specify the following:- IPC-A-600 - Acceptability of Printed Boards IPC-4101 - Specification for Base Materials for Rigid and Multilayer Printed Boards IPC-4103 - Specification for Base Materials for High Speed / High Frequency Applications IPC-4104 - Specification for Base Materials for High Density Interconnect (HDI) and Microvia Materials IPC-4202 - Flexible Base Dielectrics for Use in Flexible Printed Circuitry IPC-4203 - Adhesive Coated Dielectric Films for Use as Cover Sheets for Flexible Printed Circuitry and Flexible Adhesive Bonding Films IPC-4204 - Flexible Metal-Clad Dielectrics for Use in Fabrication of Flexible Printed Circuitry IPC-4552 - Specification for Eletroless Nickel/Immersion Gold (ENIG) Plating for Printed Ciruit Boards IPC-4553 - Specification for Immersion Silver Plating for Printed Ciruit Boards IPC-4554 - Specification for Immersion Silver Tin for Printed Ciruit Boards IPC-4562 - Metal Foil for Printed Wiring Applications IPC-6011 - Quality and Performance Specification for Riged Printed Boards IPC-6013 - Quality and Performance Specification for Flexible Printed Boards IPC-6016 - Quality and Performance Specification for High Density Interconnect (HDI) Layers or Boards IPC-SM-840 - Qualification and Performance of Permanent Polmer Coating (Solder Mask) for Printed Boards |
I have always used the IPC-A-600 - Acceptability of Printed Boards on every fabrication drawing (in the fab notes, Note 1).
But I never have used an IPC reference on my assembly drawings except IPC J-STD-001D - Requirements for Soldered Electrical and Electronic Assemblies. |
rdl86626 ![]() Advanced User ![]() Joined: 20 Jul 2012 Location: Hollister, CA Status: Offline Points: 83 |
We use IPC-A-600, IPC-4101, IPC- 6011, IPC-6012, IPC-6013, IPC-SM-840 FOR FABS
Assembly's only IPCF-STD-001 & QCI-080
Hope this helps-we do lots of military stuff.
Here is a good example of a set of fabrication notes for Lead Free (RoHS) and Class 3 and all the IPC standards that are referenced - Fabrication_Notes_Class_3.zip
lozlloyd ![]() New User ![]() ![]() Joined: 18 Dec 2012 Location: UK Status: Offline Points: 1 |
Do you also have a set of PCB Assembly drawing notes available please?
Here is a master set of PCB Assembly Notes in M/S Word. You'll need to customize them for your process. |
JamesUS ![]() New User ![]() Joined: 26 Jun 2017 Status: Offline Points: 6 |
One of the important roles that IPC standards play in PCB manufacturer's is to help designer's and manufacturer's to negotiate the trade-off's between design effort and product performance.
IPC’s work, with the goal of training and certifying manufacturing professionals to provide standardized workmanship, processes, and quality in a traceable fashion. Standard Spec Boards (PCB's) are inspected to IPC Class 2 Standards and Custom Spec Boards are inspected to either IPC Class 2 or Class 3 depending on the option to be chosen.
Post Reply ![]() |
Tweet |
