  New Posts New Posts RSS Feed - How to calculate DPAK Thermal pad size?
maryam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maryam Quote  Post ReplyReply Direct Link To This Post Topic: How to calculate DPAK Thermal pad size?
    Posted: 21 Oct 2020 at 9:38am
hi,
I try to calculate DPAK thermal pin pad size using SMD Reference Calculator but it's different pad size gives.
Any suggestion on DPAK thermal pin pad size Confused
Maryam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 9:49am
The Excel spreadsheet reference calculator was not intended to calculate Thermal Pads.
You can download and install the Free V2020.02 Library Expert Pro and it has calculators for 144 component families and interfaces to 25 CAD tools and has 3D STEP output.
The Reference Calculator was intended to validate the Library Expert calculations and to show other calculator users the IPC mathematical model for calculating pad stacks.
Rmiles View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rmiles Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2021 at 12:20pm
I also have this same question help me out of it.
also tell me can I use online calculator
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2021 at 12:36pm
There is no online calculator.
There is a free calculator called V2021 Footprint Expert Pro.
