  New Posts New Posts RSS Feed - How Do You Download The New V2014 Release?
Matthew Lamkin View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Topic: How Do You Download The New V2014 Release?
    Posted: 30 Apr 2014 at 1:06am
How are we supposed to download the new release?
http://www.pcblibraries.com/downloads/FPX%21Library_Expert_2014.asp takes me to a page with the following links.
Viewer does nothing, Upgrade to pro?
That leads to a download the lite version link that then links back to the same links page as above.
Give us a clue chaps....
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 3:31am
I also have problems but get taken to a "password" reset page.  When I enter my e-mail address and forum user name I get "Error 16: the password reset request could not be processed".
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 3:36am
I get taken to the same page as Mathew now.
Post Options Post Options   Thanks (2) Thanks(2)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 3:42am
I had the password problems too, ending up using IE instead of the normal Firefox so no cookies or password apps were involved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 4:22am
Yeah, I was using Firefox where it had issues.
layouter88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote layouter88 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 8:04am
same problem
new password, login now possible
but I do not find a link to download the SW
PADS, STEP, all lead to 2013 downloads
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 8:44am
Please start from here http://www.pcblibraries.com/forum/version-history_forum1.html and if you're not watching this forum page I highly recommend that you select "Forum / Watch This Forum" to get instant software release information.
This is where you can download the latest versions and even "sneak releases".
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 8:47am
that's the link I'm using, from Nick's post, but it goes to a new login page which after I've logged in again takes me to the same page as Mathew inserted into his first post on this topic.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 9:15am
Matthew - the distributors are currently being setup; you will be emailed later today with details.
James - Please make sure you use the email linked with your purchase (Crowcon).
Layouter88 - Please make sure you use the login that is linked with your purchase. In your case, the 'web' address.
The databases have been consolidated, and in the process there may be some issues we need to clarify. However, for the most part the data is pretty accurate and should only allow you to download the version that you have purchased. If you do not see version 2014 and only 2013, a link was now added where you can purchase the upgrade. This is a new page, and in the future, I would also like to add the purchase history here, Key ID, and other infomration you may find helpful.
Here is what the download options should look like now, if yours doesn't look like either, please logout and log back in and it will. If you get the third set of options but you purchased, please confirm that the email you are logged in with is what you purchased with. If it is, contact me offline and I'll get the problem fixed right away.
GrungyRemnant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrungyRemnant Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2014 at 9:32am
I too cannot download the new version.  The links are not working.
Any other suggestions?
This page was generated in 0.233 seconds.
