SODF OR DFN
dramos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Topic: SODF OR DFN
    Posted: 15 Apr 2026 at 10:23am
Hi Tom and Team,
I was working in this SOD-523 diode, onsemi part number RB751S40T1G .
Suddenly, I had a doubt with a value because the length of the pin is 0.30mm REF, I was thinking to use +/-0.05mm of tolerance but I said to my self: "how PCBFE resolve this question? and I've gone to the Parts area and bingo! it is ready to download.
After downloading I opened it and It was not similar to a SOD-523, it seems more a DFN component.
Could we consider this kind of components a DFN and why?
My first impression has been: the footprint is no correct but then... and why not?
I attached the downloaded file as well.
My component was more "traditional"
I attached as well my component fpx
Anyway I am not very happy with my footprint and as now we have a new feature where we can modify the corners of a footprint when the pad is rounded rectangle or chamfered pad.
Using this feature I created the inner corners of the component squared  and outer corners rounded. the inner corners are under the component and perhaps are more close to s DFN...
What's your opinion?
Thanks for your comments, they are always really appreciated.
Regards,
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2026 at 10:47am
This package is definitely a SODFL package.
A DFN is a BTC package where the terminal lead are completely under the package body.
DFNs do not have terminal leads that protrude outside the package body.
SODFL:
DFN:
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2026 at 11:49pm
Dear Tom and Team,
Yes, I thought the same about SODF and DFN.
So I consider that the footprint I created is correct.
In the other hand, it is my question about the shape of the internal corners of the pad.
On our company, when we create a footprint we build it with Nominal density option and Most density option. The program allows to do it in a very fast and easy way.
In both cases, the value Side and Heel is 0.00. It could be similar to the value 0.00 that we have in the Periphery parameter on a DFN.
Furthermore, there are some SODF components where the lead is below the body, for example the mentioned RB751S40T1G.
Yesterday, when I saw the component that I downloaded I started thinking that perhaps it had sense and It could be done using the new features that Altium developed.
I know that it could be a crazy idea, but I would like to start this discussion with you because in PCBFE you have a big and long knowledge. You've been involved in footprints for decades. In my company there is not a dedicated librarian to share with him this kind of ideas.
Anyway, thanks for your comments.
david
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 10:56pm
Hi Team,
I am coming again with the same idea. I've been working now with a SOD-323F diode from DIODES.
I would like to read your comments, not only Tom and Nick, about what do you think about the idea of modify the radio of the inner corners of the pad or even making them completely squared.
Here my reasoning is similar to thermal tabs, we build them completely squared to fit them perfectly on the pad.
Here I believe that if we decrease the inner radio perhaps we could make the pad even smaller. Now there is an aprox. distance of 0.12mm between the center of inner side of the pin and the center of the inner side of the pad. But this distance is not real because the corners are rounded and if the component is moved this distance to the right or to the left the corners of the pin are going to be outside the pad.
The possibility of this movement is real. There is a lot of space between the pin and the external border of the pad. I believe that could be a reasonable thought.
Looking forward to hearing your comments.
david
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 21 minutes ago at 9:03am
The terminal leads for DFN packages are 100% under the package body.
The Diodes SOD323F is in the SODFL component family.
The SODFL terminal leads are under the body and also protrude beyond the package body.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 37 minutes ago at 1:47pm
Thanks for your fast reply!!!
We are in the same page about the type of the diode.
The main difference between both types is that the SOD has Toe, Heel and side values for some density levels.
I would like your idea to mix both on SOD, from the Toe add the solder joint and from the Heel make it completely squared without radio on corners because it is under the body.
Regards,
david
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 4 minutes ago at 2:20pm
Under body DFN terminal leads have a Periphery pad calculation based on the terminal lead tolerances so that the resulting pad stack can handle the terminal lead in the maximum material condition.
In this case the pad stack would have the same shape as the terminal lead - rectangle.
90% of the solder joint strength is under the Flat Lead. But assembly would like to see visible wetting in the toe for visual inspection.
The Toe, Heel and Side are there to allow the solder under the terminal lead to flow outward during reflow.
All bottom terminal lead pad stacks are slightly larger than the terminal lead to allow the lead to settle into the solder paste during reflow.
Making the pad size the same as the terminal lead size is not recommended. But since the pad stack periphery is slightly larger than the terminal lead, the pad shape needs to be the same as the terminal lead as there is no room for rounded rectangle pad shape without exposing the terminal lead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 7 minutes ago at 12:17am
Many thanks for your comments. They are very valuable. We are completely in the same page.Smile
When you mention "But assembly would like to see visible wetting in the toe for visual inspection" is there any standard that mention it? Perhaps IPC-A-610 ?
Best regards,
david
