  New Posts New Posts RSS Feed - Footprint for TO-220 Vertical
Batiskaff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Topic: Footprint for TO-220 Vertical
    Posted: 27 Feb 2020 at 10:55pm
I try to create the footprint for
The datasheet doesn't content any recommendation.
If i create it in calculator than the pads cover each other
partially. I want to redraw the pad dimension manually.
Is there any general recommendations to create the elongate pad?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 8:23am
The Pin Pitch is 2.54 mm (100 mil).
The pads should not overlap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 9:18am
I am sorry,  the right datasheet is here:
see page 11.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 9:32am
Then you make the "D" and "D1" dimensions different.
You must bend the leads.
You decide the dimension value that you want to bend 2 leads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 11:33am
As i understand, constrict + stretch  the pads is undesirable.
For example, footprint on page 15:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 11:55am
Do you want the oblong pad version? I'll build it for you.
Simple 5-minute task in FP Designer.
