Footprint For Solderable Jumper? |
Post Reply ![]() |
Author | |
LaserAlex ![]() Active User ![]() ![]() Joined: 06 Jun 2012 Location: Seattle, WA Status: Offline Points: 27 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Feb 2017 at 2:55pm |
Does anyone have experience generating good (or bad!) footprints for solderable jumpers? I'm looking to configure a circuit board with something like this:
![]() Or this: ![]() I want something that is easy and quick to connect, but also easy to desolder and clean up for reconfiguration. If it makes any difference, the intent is to use lead-free solder. Has anyone done this, with good or bad results? Can anyone provide pointers? Better yet, dimensions / configuration or even an Altium footprint for a "known-good" solder jumper? Thanks!
Tom H ![]() Admin Group ![]() ![]() Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5126 |
Your picture is an OK example. There are just a couple rules -
Here are some alternate solder jumpers that work well - ![]() |
Thank you for the quick response, Tom!
The options with the interdigitated contacts look like they would be very easy to short reliably, but I'm worried about the difficult of cleaning them up if the configuration needed to change. I'm sure solder wick and flux could clean them out, but I really want something easy to work with. Have you personally soldered and desoldered all of these? If you were tasked with reconfiguring a thousand of these jumpers, which would you prefer had been used on the board? Thanks! -Alex
I'm an IPC CIT trainer for soldering and J-STD-001 solder joint acceptability and these patterns clean up really nice. Place a solder wick on the solder and apply the iron and the solder wick sucks up the solder and with a wire mesh touchup it should be clean to go. Old fashion pad with hole and wire is still a popular Jumper solution. Even a wire loop across 2 SMD pads with easy access to cut. No need to use a solder iron. |
Thanks, Tom. Great info!
MSM_KOPF ![]() Advanced User ![]() Joined: 02 Feb 2015 Status: Offline Points: 53 |
How should such a footprint be named ? In my current footprint there are 2 pads each 0.5 x 1.0mm with a gap of 0.2mm between the 2 long sides. (02.mm Gap due to clearance requirements) There are versions of this footprint. 1. without any solder paste for an open solderable jumper 2. with solder paste over both pads and the gap between the pads for a close jumper after reflow A resistor would be something like "RESC1608X70" Is there any naming convention or recommendations for both footprints? |
If it's a Jumper I would use:
JUMP0510WP = Jumper 0.5 X 1.0 With Paste JUMP0510WOP = Jumper 0.5 X 1.0 With Out Paste You get the idea. |
DrewRu ![]() New User ![]() Joined: 04 Oct 2019 Status: Offline Points: 1 |
It is still common to represent this as an
optional 0 Ohm resistor and many designs still use a 0-Ohm SMD link; you
just have to remember to use the right footprint for the artwork if you
want to use a solder bridge.
Post Reply ![]() |
Tweet
