Forum Home Forum Home > General > Website / Forum
Status: Online
    Posted: 21 Oct 2024 at 9:30am
  • IPC-7351B
  • IPC-7352
  • PCB Libraries (IPC-7351C)
  • Your Custom Footprint Name
Example:
QFN w/Thermal Pad
