DFN or SON Package? The Mfr. is Calling it DFN |
Post Reply ![]() |
Author | |
Hassan Moaaz ![]() Active User ![]() Joined: 05 Sep 2016 Status: Offline Points: 22 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Jul 2017 at 6:36am |
I am trying to work on some packages but unfortunately tool not support as sample DFN 8 pin it support only DFN 6 pin is it possible to update tool with this package?
Tom H ![]() Admin Group ![]() ![]() Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5795 |
The part is and Small Outline No-Lead (SON with Tab).
It's not a Dual Flat No-Lead (DFN) as they only come in 2, 3 and 4 pin versions. To see all the correct component family names, there is a document in this folder on your computer - C:\Program Files (x86)\PCB Libraries\Library Expert 2017\Documents The name of the documents are - - Library Expert Surface Mount Families.pdf - Library Expert Through-hole Families.pdf |
stanleycayochok ![]() Active User ![]() Joined: 04 Apr 2016 Status: Offline Points: 23 |
Im using Library Enterprise Edition (2019.07) and the IPC-7351C Land Pattern Naming Convention.pdf could not be found in the Documents folder. Where can I get this pdf file?
There is no IPC-7351C Naming Convention. That Guideline is not released yet.
Download the PCB Libraries, Inc. Naming Convention here - uploads/3/Footprint_Expert_Land_Pattern_Naming_Convention.zip
You should really update to V2020.03 Library Expert Enterprise as it will be taken off-line next month and replaced with a brand new 100% rewrite V2021 Footprint Expert.
However, you might want to use V2020 during the learning curve. |
Post Reply ![]() |
Tweet |
