  New Posts New Posts RSS Feed - DFN 4 Pins - Side (Not Bottom Only)
davidhadley View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote davidhadley Quote  Post ReplyReply Direct Link To This Post Topic: DFN 4 Pins - Side (Not Bottom Only)
    Posted: 23 Mar 2021 at 2:08am
Hi All,
I'm trying to create a 4 pin DFN (Oscillator) with side terminals so I need a toe but all settings seem to be for bottom only (periphery).
Is it possible to set to Flat No-Lead Side (as seems an available option in the terminal preferences).
Many thanks Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2021 at 8:52am
Are you sure it's a 4-pin DFN?
I would use the mfr. pattern and build it in FP Designer.
All unique patterns are created there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidhadley Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2021 at 12:23am
https://www.digikey.co.uk/products/en?keywords=SIT8008BI-12-33E-36.000000E
I cant use manufacturers recommendation as I've been told by production pads are too large and cause issues.
Wondering why when you select 4-pin DFN it defaults to No Lead Side but then when you put calculations in it changes to No Lead Bottom Only (Periphery)?
I have manually changed calculations to get what I want (0.2 toe, 0 side, 0 heel) but interested to know if there's a way of selecting No Lead Side for these types.
Many thanks,
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2021 at 8:47am
DFN's and LGA's are in the same component family.
The Terminal Leads are 100% under the package.
Therefore a Periphery solder joint goal is the only option.
However, the part that you are referring to is not a DFN package. It's a Side Concave Oscillator
