DFN 4 Pins - Side (Not Bottom Only) |
Topic: DFN 4 Pins - Side (Not Bottom Only)Posted: 24 Mar 2021 at 8:47am |
DFN's and LGA's are in the same component family.
The Terminal Leads are 100% under the package. Therefore a Periphery solder joint goal is the only option. However, the part that you are referring to is not a DFN package. It's a Side Concave Oscillator. ![]() |
davidhadley
Posted: 24 Mar 2021 at 12:23am |
https://www.digikey.co.uk/products/en?keywords=SIT8008BI-12-33E-36.000000E
I cant use manufacturers recommendation as I've been told by production pads are too large and cause issues. Wondering why when you select 4-pin DFN it defaults to No Lead Side but then when you put calculations in it changes to No Lead Bottom Only (Periphery)? I have manually changed calculations to get what I want (0.2 toe, 0 side, 0 heel) but interested to know if there's a way of selecting No Lead Side for these types. Many thanks, David
Posted: 23 Mar 2021 at 8:52am |
Are you sure it's a 4-pin DFN?
I would use the mfr. pattern and build it in FP Designer. All unique patterns are created there. |
davidhadley
Thanks(1)
Posted: 23 Mar 2021 at 2:08am |
Hi All,
I'm trying to create a 4 pin DFN (Oscillator) with side terminals so I need a toe but all settings seem to be for bottom only (periphery). Is it possible to set to Flat No-Lead Side (as seems an available option in the terminal preferences). Many thanks
