Correct footprint name for TI DPW0005A (X2SON-5 wi
giggio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote giggio Quote  Post ReplyReply Direct Link To This Post Topic: Correct footprint name for TI DPW0005A (X2SON-5 wi
    Posted: 2 hours 36 minutes ago at 5:10pm
I need the correct footprint name, according to the PCB Libraries naming convention for the Texas Instruments package DPW0005A (X2SON-5, used for example by the SN74LVC1G07DPWR).
Package data from the TI drawing:
  • Body 0.8 × 0.8 mm, maximum height 0.4 mm
  • 5 terminals: 4 corner pads with chamfered shapes, plus one center pin (pin 3)
  • 0.48 mm pitch between pins on the same side
  • No thermal pad
This is not a classic SON, because the terminals are not only along two opposite edges. I see two options and would like to know which one is correct:
  1. Use the SON family, giving SON5P48_80X80X40....
  2. Treat it as a non-standard package), giving TI_DPW0005A (manufacturer prefix plus case code, since DPW0005A is shared by many part numbers).
Which one is correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 35 minutes ago at 6:11pm
There are 17 TI Case Code parts on www.pcblibraries.com/POD
Here's a link to the SN74LVC1G07DPWR FPX file - uploads/3/TI_DPW0005A.zip
