ConsoleOptions.opt is getting reinstated?
ckhalleran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ckhalleran Quote  Post ReplyReply Direct Link To This Post Topic: ConsoleOptions.opt is getting reinstated?
    Posted: 23 Apr 2021 at 7:00am
New install here for the leased enterprise version (and I haven't read all the PDF's yet)
After starting Footprint Expert, I go to Tools, Options, and make some changes (for example, I tried setting "Create Footprint Name Using Units" to "Mils".
I click FILE SAVE, and I see that my ConsoleOptions.opt has been updated (new date and time). I open it in Textpad and can see the line now has "FPNamingUnits="MILS"
Then I closed Footprint Expert and started it again. I see that ConsoleOptions.opt has been updated (new time). In Textpad, I see it now has FPNamingUnits="MM"
I also tried doing a "save as" to Chris.opt... but that file doesn't have the text "FPNamingConv"
Also, when I start Footprint Expert, the bottom line shows Option Source = Internal Defaults. If you have customized settings, is there a way to have it automatically use those customize settings automatically when you start the program?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2021 at 10:04am
Here is a fix for this issue.
Right Mouse Button (RMB) on the Footprint Expert task bar icon and select "Unpin From Taskbar"
Then open the folder where the main .exe is located: Footprint Expert 2021 Enterprise Edition.exe
The default folder is: C:\Program Files (x86)\PCB Libraries\Footprint Expert 2021 (or Cloud)
RMB on the Footprint Expert 2021 Enterprise Edition.exe file and select "Pin to Taskbar".
This should fix the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 10:52am
A V2021.04 Footprint Expert Enterprise pre-release with additional bug fixes was released today - www.pcblibraries.com/downloads
Select the Text below the blue bar.
