  New Posts New Posts RSS Feed - CADSTAR - Exit Direction Information
O.Mueller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.Mueller Quote  Post ReplyReply Direct Link To This Post Topic: CADSTAR - Exit Direction Information
    Posted: 25 Nov 2013 at 3:09am
Hello All,
After export a TH component to CADSTAR, the exit direction is set per default to North/South/East/West only.
How can a manipulate the settings to all 8 sectors.
Regards Olaf
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.Mueller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2013 at 12:14am
Hello All,
It's a bug in CADSTAR since V14.0.
If the Header information in the .cpa is under Version .17 the :
(EXITS N E S W)
Is ignored and "Free Angle" is checked.
So I need a button in Library Expert that I will not have "(EXITS N E S W)" informations,  if they fix CADSTAR.
Regards Olaf
Post Options Post Options   Thanks (0) Thanks(0)   Quote Artwork Master ITALY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2013 at 3:27am
Try to add the following: (EXITS NW N NE E SE S SW W)
Maybe it will correct the problem.
If it will be OK tell it to this forum so Chrisa_pcb can correct the translator.
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2013 at 9:08am
Does the Legacy(older than v14) Cadstar support the 45 degree exits? Or is it just v14? I.e. do you want the new form on all versions, or just v14?
I've constrained it to v14 for the time being, let me know on the other versions. It'll be in .17.
