Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Adding Pin 1 Dot on Assembly Layer
    Posted: Yesterday at 7:40am
Rather than having a chamfer corner for the assembly pin 1 polarity marker.
Add a Dot on the assembly layer with required parameters to change the size, height text, line width.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:47am
Does anybody else want this feature? Let us know.
tgrodnicki View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tgrodnicki Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 41 minutes ago at 10:50pm
Some inductors have a dot on their bodies to indicate polarity. That's how I mark it in my footprints. I do this using the Drawing Elements - Symbol/Shapes tool (icon). If this were to be automated, it would also be helpful to have control over the dot's position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 49 minutes ago at 3:42am
yes, you correct , this point need to be added it will save more  by avoiding do it manual for each part, especially not saved in fpx file( if it done by drawing shapes icon)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 21 minutes ago at 8:10am
Adding Pin 1 Post Assembly Inspection Dots on Silkscreen is automatic.
Turn this feature on in Options > Drafting > Silkscreen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tgrodnicki Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 11 minutes ago at 10:20am
We are discussing the dot on the Assembly layer and whether it should be added automatically like for the Silkscreen layer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 57 minutes ago at 11:34am
Do you like the Assembly Polarity Dot better than the Chamfer?
Add an Option to switch between the Chamfer or the Dot?
Add sizing controls like the Silkscreen Dot for diameter?
Where would it go, in the corner of the Assembly Outline (whatever corner pin 1 is) or by Pin 1?
How far into the assembly Outline and what about micro footprints?
You see how complicated this gets?
