  New Posts New Posts RSS Feed - Adding Minimum Annular Ring for Keepout
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Adding Minimum Annular Ring for Keepout
    Posted: 03 Sep 2025 at 7:41am
Add a minimum annular ring for keep-out for non-plated holes in 'Tools > Options > Terminals > Through-hole'.
The current method of making the non-plated hole keep-out the same size as the Anti-pad does not work it you need a keep-out clearance larger or smaller than the Anti-pad.
