  New Posts New Posts RSS Feed - 6-Lead Side Concave LED Package
zentekfr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zentekfr Quote  Post ReplyReply Direct Link To This Post Topic: 6-Lead Side Concave LED Package
    Posted: 21 Sep 2022 at 2:56am
Hello!
I'm currently drawing a footprint for the KPF-3236RGBC-11 from Kingbright
There is no option "6 pins" in the dropdown list of the "Side Concave Package". There are only 2 and 4.
If I go and try "Chip Array, 2-Sided Plat and Concave", then there is a 6-pin option but no "LED" family, which results in inconsistent naming and incorrect 3D model.
For the KPTF-1616RGBC-11, all went OK because it's a 4-lead package.
What am I supposed to do?
Justin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 8:32am
The KPF-3236RGBC-11 from Kingbright needs to be created in FP Designer for now.
It will take some time to add a new component family.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zentekfr Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 1:36pm
Tom,
Can't the 6-lead variant of Side Concave Package be derived from the existing ones easily?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 2:48pm
Yes, we can probably add a 6-pin version but the 3D STEP model would look similar to the 4-pin version.
We're also ready to release V2022.12 with new features tomorrow.
We would need a couple days to add this new component family and test it and create a V2022.13 pre-release for you to test.
That will be next week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zentekfr Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2022 at 8:21am
OK great!
By the way, the default 4-lead side concave LED package does not have its pin 1 at the lower left corner. Is this expected?
LEDSC4P85:
SOL4P145:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2022 at 9:30am
Pin 1 is in the Upper Left corner because if you select the 2-pin version Pins 3 & 4 go away.
Pin 1 on all 2-pin footprints is Left.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zentekfr Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 4:19am
Actually, there are two different concerns in my question: pin 1 location and pins numbering.
Quote Pin 1 is in the Upper Left corner because if you select the 2-pin version, pins 3 & 4 go away
Well, I understand the technical reason.
Is this IEC 61188-7 compliant? Does it correspond to a physical reality?
If I understand correctly, this topic enters the "badly standardized zone", both for pin 1 and pin numbering.
For example: CD-DF406S (4 pins, side concave diode) doesn't follow the standard counter-clockwise numbering. Even Würth Elektronik isn't consistent with itself: take WL-SBCW and WL-SFCW for example, the numbering is done the opposite way! (CW vs. CCW respectively)
Nevertheless, Footprint Expert applies neither CW nor CCW numbering!
I suppose extra care must be taken for this particular family of packaging.
