Molded Body - Cap, Polarized Calculations |
ccyman
Topic: Molded Body - Cap, Polarized CalculationsPosted: 1 hour 46 minutes ago at 4:11pm |
Is there perhaps a setting I need to fix in the calculator when using it out of the box for Molded Body - Capacitor, Polarized? The toe and heel results are not what I'm expecting to see based on the settings defined. Since I can't upload images, here's what the settings were: Component dimensions filled in were (mm): A = 2.00 max b = 2.20 +/-0.2 D = 3.50 +/-0.2 E = 2.80 +/-0.2 L = 0.80 +/-0.3 Terminal Density Level Inward Flat Ribbon L-Lead. Height > 1.20, <= 2.20 mm Density Level = Nominal Toe = 0.05 mm Heel = 0.45 mm Side = 0.00 mm Calculator results are: G = 1.33 mm X = 1.63 mm Y = 2.40 mm This results in a toe of 0.088mm (I was expecting 0.05mm) and a heel of 0.442mm (I was expecting 0.45mm). These results are from Footprint Expert 26 (26.10, 10/30/2026).
Thanks, Cindy |
