DRC errors from Altium gang mask
thomas.yunghans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thomas.yunghans Quote  Post ReplyReply Direct Link To This Post Topic: DRC errors from Altium gang mask
    Posted: 47 minutes ago at 9:17pm
I created a footprint for a 0.4mm pitch SON device (SON11P40_200X250X80L35X20T140X120N) for Altium Designer.  Because the pitch between pads was so small, PCBExpert generated a gang mask over the pads.  Apparently the software uses multiple overlapping objects to create the gang mask.  It looks like the masks are overlapping properly, but for some reason Altium generates DRC failures.  I have a solder mask sliver rule limit of 3 mils in the Altium design rules.
Am I doing something wrong?  Do you have a suggested workaround?
Tom Yunghans
3526 Glen Ave
Carlsbad, CA  92010
