  New Posts New Posts RSS Feed - pcb model selection for TO-220F
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: pcb model selection for TO-220F
    Posted: 7 hours 24 minutes ago at 12:25am
For this part” MBR30100CTF-G1” in this datasheet “"
1-What PCB Model should we use to  create Footprint ?
2-confirm Parameter “D1” is the distance to the middle of first row pins.
3- Parameter “D1” requested in nominal value can we calculate it as the average of maximum and minimum values
4- Distance to middle of pin=distance to back of pin + 1/2 (Lead thickness)
Nom distance to back of pin = (2.92+2.52)/2
Nom 1/2 (Lead thickness) = (0.65+0.45)/4
D1=2.72+0.275
D1=2.995
please add more details for how to select Model fo cases like this
